VSS wiring pin out VSS wires
Old 06-12-2008, 07:23 AM
DustinRose's Avatar
Default VSS wiring pin out VSS wires
for any poor soul attempting to research a pin out for the electric VSS plug here it is
i found a couple people saying it was
groud, signal, power
but its not, i have been messing with it a couple days
if you are holding the clip in your hand, with the wires side pointing at you, and the release clip facing up it goes
1. ground (black)
2. power
3. signal
Old 06-12-2008, 09:07 AM
gringo7718's Avatar
Default Re: VSS wiring pin out VSS wires (DustinRose)
I think this is a 92-95 civic vss
Old 06-12-2008, 11:40 AM
xalents23's Avatar
Default Re: VSS wiring pin out VSS wires (gringo7718)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringo7718 &raquo;</TD></TR><TR><TD CLASS="quote">I think this is a 92-95 civic vss
Size:  78.5 KB</TD></TR></TABLE>
That is how my 1992-1995 VSS speed sensor wires are.
Old 09-07-2012, 12:53 PM
Mishako129's Avatar
Does anybody know how i can fix the wiring harness adapter that goes to the VSS? One of the pins is partially broken off.
Old 09-07-2012, 12:58 PM
Mishako129's Avatar
Will this work? Its for a OBD1 Acura and the adapter looks the same.
http://www.ebay.com/itm/VSS-SPEED-SE...#ht_500wt_1289
Old 09-07-2012, 02:44 PM
crx_si-r's Avatar
I can sell you the terminals an boots if you new them so you don't have to solder just crimp and go
Colby71
01-29-2008 06:05 PM
Ep1dem1c
07-03-2007 10:51 AM
J-g-D-s-M-r
09-12-2006 11:52 AM
joker_333
02-19-2006 11:29 AM
mike93eh
18
08-14-2005 01:56 PM
Quick Reply: VSS wiring pin out VSS wires
