#1 | |||||
#2 |
stock wheels are 15 inch. more mass will definately reduce MPG, will reduce acceleration, will increase deceleration and will also effect handling.
1986 civic Si.. B16a is in.. now to finish it.. Daily driver: 1991 Civic Si. 100 miles a day, 35mpg. ![]() track toy project: 1988 Civic sedan, d16a6 swap |
#3 | |
On top of all this, 17" rims don't look good on a Fit.
R.I.P. 300 WHP Single Cam |
#4 |
and on top of all of that, 20lbs is heavy as hell. wheels should be around 1 pound per inch or less. mine are 16s but i think im gettin better milege because they are really light.
[OS^e] |
#5 |
personally i like 17's on a fit.
#6 |
#7 |
17's look too big for a Fit, IMO. 16's are the biggest I would go. But to answer your question, yes, more mass on the outside of the wheel will result in less MPG. Your handling will actually be more crisp, due to the stiffer/shorter sidewalls, but accel, MPG will all suffer. I'd go with 16's and call it good.
And, yeah, like the other guy said, 20lbs is really heavy.
01 Geeser |
#8 |
* B A N N E D *
yeah, 16's look great on the fit. as a rule of thumb, only go 1" bigger than stock IMO
#9 |
What's wrong with a lot of rubber?
Sorry, I'm old school from the days when Honda entered F-1 and James Gardner was in the movie driving it. Even got a print signed by him from the movie. Anyway, imho, large wheels and ultra low profile tires and style over function and look totally out of place on a Fit. More rubber is a better ride, more safety, and better real-life handling. And looks lots better too, but that's just this old-phart talking. John |
#10 |
prolly throw off your tach by a little too
avoid IMPORTWERK AUTOBODY AT ALL COST... why & his profile: http://www.honda-tech.com/showthread.php?t=2357615 http://www.honda-tech.com/member.php?u=999517890 |
#11 | |
![]() guess not!
93 civic 4 do' - ls/veeeeetac turblow - under construction 07 Fit Sport - DD returning to mostly stock Check out WWW.swervemotorsports.com get yo swerve on! |
#12 |
* B A N N E D *
Yeah, 17s look great on a Fit as long as you don't run 55 series sidewalls and don't even drop the car.. then any car can look bad on any wheel
#13 |
yeah, that silver fit looks like ass. whatever. to each there own. i like the 17's on there.
#14 | |
#15 | |
Plus Zero 185/55-15 195/50-15 205/50-15 Plus One 205/45-16 215/40-16 Plus Two 205/40-17 Plus Three 215/35-18
"I came to America with nothing, now I have my own brochure!" |
#16 | |
#17 |
I use 205/45-16 with light 04 Mini Cooper rims and feel great in curves! Lost about ten miles per half tank only.
Minijob for my Honda Fit |
#18 | ||
IE: Quote:
#19 |
http://www.hotrodders.com/foru....html
It seems like every pound of rotating weight is like ten pounds of weight inside the car, although knowing having a passenger doesn't really affect your mileage, the weight shouldn't affect it much. If your wheels weigh 20 lbs in total compared to stock wheels, it's just like constantly having a 200 lbs passenger. The lower profile actually increases mileage due to reduction in flex loss, however a wider tire tread increases rolling resistance. Heavier wheel DOES affect handling. You have that much more unsprung mass and suspension has to work that much harder to keep the tires in contact with the surface when you encounter small bumps. |
#20 | |
#21 |
i knew thats what your getting at but you know its "tha Intranetz Yo"
#22 |
word. internet bad-azz numero uNO up in hizzah.
#23 |
16s would be max or me
#24 | |
2008 Honda Fit |
speedLAB member SOHC FTW. 400+whp Sohc Turbo EG - 2008 Stock Honda Fit |
#25 |
Does anyone know the weight of the stock Sport wheels?
..:::MY EK9:::... ...:::Good buyers/Sellers:::...Throwdown, LudeSH, underpressure02, FAST4DR |
| Bookmarks |
| Tags |
| 17, 92, affect, bigger, civic, cooper, fit, gas, heavier, honda, inch, mileage, mini, mpg, reduce, rims, ruckus, wheel, wheels |
