#26 | |||||
#27 |
wow very nice,
http://www.dynospotracing.com http://www.trackspeedracing.com 11.153@126.26 87x99 all motor street car!! THC |
#28 |
Derek told me that 99mil motor was 12.5comp and on cali 91 pump gas not sure if they used gas gas in any of the motors.
i think the 95 and 97 were the same comp
(89.5x97h2b)286whp214tq 11:54@115 fastest allmotor street car in OR POWERED BY PARRIS RACE ENGINES project 300+ coming soon |
#29 |
* B A N N E D *
On the 95mm motor is there any modifications necessary to the type s pistons with the blox cams? or was a thicker head gasket used?
#30 |
Yes the pistons do have to be modified to avoid valve to piston issues, there is a slight trick to it though.
Nice graph comparison Derek, i guess we will have to at least try out the ITB's. Can i get a price on a 99 stroker kit? Parris Engine Dynamics (209) 467-4909 http://ParrisEngineDynamics.com http://QuarterSportsDrag.com Holland Racing all motor unibody civic 10.16@132. A/M street cars Mike Nhew 11.7@115 Josh Gray 11.4@119 Turbo Street cars Pe Thor 10.7@135 Thang 10.44@133
AM H2B QSD 11.45@119 Coming soon to a track near you .... www.quartersportsdrag.com Joshuaglobal@yahoo.com |
#31 |
ttt iwant more info on the 99mm setup
allmotor h23vtec h2b |
#32 |
So what did this beast do today?
760/SEVEN_SIXTY/BUILT High Desert service for Motor Swaps/Builds PM for all inquiries |
#33 |
real nice
#34 | |||
Josh, Mike, and myself have spent quite a bit of time and money to make this build happen. I know for the first 97mm stroke budget build, we documented every step and made a post to put it out there for you guys to have fun with and make some decent power withought breaking the bank. I have not come up with a final price nor have I decided if we are going to sell this 99mm kit yet. If I have enough inquiries I just may consider it. Quote:
But seriously these motors really are not that expensive at all shhhhh don't tell anyone.....Imagine what the cost would be to make that power with a B Series motor or just calculate how much a K 24 swap w/ rods and pistons would cost. We beat the crap out of these engine on and off the dyno. I think the 99 stroke already has 60+ dyno pulls and 10+ passes down the track. I guess it is time to actually build a real engine.~Derek Modified by ParrisEngineDynamics at 5:17 AM 6/2/2008
Parris Engine Dynamics (209) 467-4909 http://ParrisEngineDynamics.com http://QuarterSportsDrag.com Holland Racing all motor unibody civic 10.16@132. A/M street cars Mike Nhew 11.7@115 Josh Gray 11.4@119 Turbo Street cars Pe Thor 10.7@135 Thang 10.44@133 |
#35 | |
#36 | |
King of the One Liners
AllenBuilt/RSTech Tuned All Motor F2K Coupe: 10.97 - 126.8 http://www.rstech-racing.com |
#37 |
so simple and so fast
-NOMIS IND.-CCCYLINDERHEADS.COM-GREENLOVE BICYCLES-H22SQUAD.COM- AUG SPECIAL-TIMING BELT,WATER PUMP -$100 -WE DO BUILDS,SWAPS,HEADWORK TUNE UPS- |
#38 | |
#39 |
I want a 99 stroker kit!!!!!
who else wants a stroker kit?
#40 |
If I sent you guys the h22 pistons could you do the machine work required for the 97mm crank build. Machine shops around my area are all about push rods and would never touch a 4 cylinder.
#41 |
can i get a 99 crank please
#42 |
Saw the hatch over the weekend at CMI! that car really boogies down the track!
for traction!
You can't spell Slaughter without Laughter http://images.honda-tech.com/set1/smile/emsmile.gif NOR*CAL http://images.honda-tech.com/set1/smile/emthup.gif R.I.P DSRxBernard "Bloody B" Profeta Jr. 9/29/79-3/24/08 "bigg dreamers... never sleep!!" Its never good bye homie.. |
#43 |
I would be in for a 99mm kit.
I think BC makes a kit now also. However I dont know if they are popular or well constructed.
WTB: t2w4 transmission Progress rear sway bar Dry nitrous kit |
#44 | |
Is it in you?
#45 |
if you have a 219.5 deck h 99mm strok k20 rods are 139mm or you can get scot racing rods h22 139.3mm the h22 piston is 31mm. if you do the math you well see it well give you a 0 deck h rod/ stroke ratio will be 1.40. sorry but I think you ran this set up.
http://www.stage6motorsports.com/ SIK Creations-we change colors as we go down the track! k20/k24 civic 11.7@ 114mph 1.6 60ft |
#46 |
the k20/k24 are 1mm lower and they fit.
#47 |
That actualy doesnt work, the wrist pins are different when it comes to F23 rods and K20 rods. The diameter is different and the styles are different (F23 resistance fit/K20 full floating wrist pin)
Josh G Parris Engine Dynamics (209) 467-4909 http://ParrisEngineDynamics.com http://QuarterSportsDrag.com Holland Racing all motor unibody civic 10.16@132. A/M street cars Mike Nhew 11.7@115 Josh Grey 11.4@119 Turbo Street cars Pe Thor 10.7@135 Thang 10.44@133
#48 | |
N/a or bust 8p |
#49 |
Josh G if you go to crower sit http://www.crower.com/cat/impo...shtml you see they make rods that have the same wrist pins size .866
#50 | |
Is it in you?
http://honda-tech.com/zerothread?id=2061413 |
| Bookmarks |
| Tags |
| 95mm, 97mm, 99mm, block, defferent, dyno, exhaust, f23, h22, intake, k24, numbers, pistons, stroker, tha, valve |
