#151 | |||||
#152 |
10.82 136
b16a2 22PSI t3/t67 .63 a/r
90 Civic Hatch 10.82 / 136 Piston & Rod B16 T67 24PSI |
#153 |
Yes, I finally can be somewhere on a list even though its torwards the bottom - 11.2@126mph masterpower 60-1
2008 - 96 civic hatch ls/vtec stock sleeves - 11.2@126mph E85 Live green - go on the last yellow |
#154 | |
i ported the head myself.I also cut the valve guides down. 00-01 ITR cams. Ported ITR intake. i rev it to 9k. The turbo is maxed out. On a dyno dynamics, i made 365whp at 13psi and only 407whp at 20psi. Its already at 325whp at 6300rpm on 20psi. Gets to around 400 at 7500 and flattens out to 9k But in a lighter car as yours with better suspension, its capable of much more
--SEMOTORSPORTS.COM--1995 SC34 Turbo Integra 81.5mm Ls/Vtec > 407WHP > 20psi > 10.85@133mph http://videos.streetfire.net/video/I...ery_199650.htm |
#155 | |
#156 |
its a .63 a/r 4 bolt. It actually made 444whp busting up on a dynojet before it was tuned on the dyno dynamics but the turbo was maxed out then too.
And yea im now saving to get an SC61 and a cage
#157 |
i had a feeling these turbos are somewhat overrated, but im happy with the turbo performance since you ran high 10s with only 400whp in a full weigth integra.... last ? that pump gas power, cause im going run 110 since i have a dd.........
#158 |
1996 Acura IntegraMy Garage |
2440lb is far from a full weight Integra, I am in that general weight now and my back is full gutted, no ABS, PS, Heater, Sound Deadening, Bumper supports etc.......
1.8L Integra GSR T3/T67h.o 11.01 @ 137 - E8516-20psi 1.83 60' |
#159 |
o snap, my bad i been driving a civic for so long and i gust got a 92gsr as dd i just forgot how much the intergas weight.....
#160 |
12.62@108.45 t3/t4 .57 trim 9lbs of boost!
HONDA/ASE CERTIFIED TECH 92 PGP EG8. Stock longblock 12.40@111 1.8 60' http://rstech-racing.com/default.aspx |
#161 |
11.36 @ 127 mph, T3/T04e 60 trim
w w w . i n n o v a t i v e - m o t o r w o r k s . c o m SURJE.motorsports :: EH2 Hatch :: 11.36 @ 127 mph |
#162 | |
now it has no a/c and weighs 2440 with the turbo. It has No p/s (4 lbs?) No carpet in the trunk(5 lbs?) and everything else is still there....Still Full interior with leather. Maybe someone put some lead behind your panels.
#163 |
I have a race gas tune on a switch with a more aggressive timing map for the track which makes a little more power under the curve but it still flattens out at the same spot due to the turbo.
#164 |
nice.......... once again congrats, I be happy running low 11's for a while then aim for high 10's with the same setup. after a few years im going high 9's with a more affective setup and still drive it on the street. i just need a shitload of tracktime.
#165 | |
So for some odd reason your car weight 150-200lb's lighter than an ITR from the factory just by removing 30lb of parts, let me in on your secrets plz.............. not knocking your car or anything, but either your scale was wrong or you have alot more removed than just some carpet and power steering
#166 |
i went 10.89 @ 136 on a fully built straight LS motor with a Bullseye power T3 S370 turbo. i was only shifting the car at 8200 and it was running into rev limter at about the 1,000 ft mark at 8500. it was making about 540 whp the cars weights about 2400 with me in it and it made a total of 33 lbs on that pass. we are working on some things to get it to go faster.
Team Powerline 10.76 @ 138.50 www.myspace.com/oneqkfodo www.tunedbycft.com / www.napaonline.com |
#167 | |
#168 |
1989 Honda CivicMy Garage Join Date: Sep 2002
10.52@142mph...Gt3582rls
Civic EF 680hp@34psi .... 10.08@151.28 Last edited by JDM97R; 05-16-2009 at 09:22 AM. |
#169 |
lisa kubo 9.84@ 152 gt35r
M Factory,Skunk 2,Competition Clutch,Golden Eagle,AFI,Royal purple,Hondata,Venom, Portflow Designs,Bullseyepower,Arias pistons,JCR,Supertech,Competiton race fuels,DSS www.CTRDynosports.com 209 521 DYN0 www.ctrparts.com |
#170 |
96 GSR-T - 11.01@137 - t3/t67 ho
#171 |
Mike Crawford went 9.07 @ 157 t3 hot side in 2002... 2.4 Neon auto , hot rod trim
#172 |
E-thug
Ran my new PB this weekend. 10.19@144.67 on an HTA35R.
#173 |
9.76@147mph BW AX368 T3 .70 low boost better times this weekend
NEW VW golf 4cyl Hotrod coming in 2010 www.Autoxtrem.com Sponsors Wanted! |
#174 |
Lets keep it going, any new updates???
Bad Intentions Motorsports, The secret is the tune! |
#175 |
new best 9.54@147mph and best mph 157mph
| Bookmarks |
| Tags |
| 48, 601, 63, ar, b16, civic, drag, fasttest, hondatech, precision, race, sc6152e, sc6152s, spec, stock, t3, t3601, t3t4, turbine |
