cv boot? (PICS)
Old 03-27-2008, 02:59 PM
polyhonda's Avatar
Default cv boot? (PICS)
I found this out when I was lowering my car. Is my boot messed up, could i replace just the boot or do i need to replace the whole steering rack. I dont feel anything while driving its normal, just like a scratching metal sound when I take turns.
thanks
right side
Old 03-27-2008, 03:08 PM
1992Si's Avatar
They should be replaced.
The boots are cheap, it's the labor that's going to hurt.
BTW normally CV boots refer to the axles.
Modified by 1992Si at 7:17 PM 3/27/2008
Old 03-27-2008, 03:30 PM
Malakai's Avatar
yea that isnt your CV boots/joints. That is the inner tie rods
Old 03-27-2008, 05:05 PM
fastrc2's Avatar
Default Re: (Malakai)
ok you need at least the boots, if the dirt has contaminated the inner tie rod joint, its the thing inside the boot. reguardless, to replace the boot, the outer tie rod has to come off to change the boot or the inner tie rod joint. so no metter what you will need an alignment. i would reccomend new inner tie rod joints, and i dont think any of this has anything to do with a screeching sound. overall, if you dont fix those boots, grit will rip up the radial seals on the end of the rack, which means loss of fluid from a non-repairable spot, and then you WILL need a rack
Old 03-27-2008, 05:20 PM
be8teensee1's Avatar
Default Re: (fastrc2)
i think they are cheap ( tie rod ends)just replace them . that would be your best bet ,
Old 03-27-2008, 07:08 PM
mechanix619's Avatar
Tie rods are really easy to change. Good luck.
Old 03-27-2008, 08:10 PM
lollypopking's Avatar
Default Re: (mechanix619)
The boots you are refering to are called gear bellows. They protect the greaseable link of the inner tie rod end. Replacing those is a piece of cake. Might as well replace your inner tie rod ends if they are in bad condition.
Old 03-27-2008, 09:15 PM
polyhonda's Avatar
Default Re: (lollypopking)
So I jsut replace the boot right, whats some good places around san jose
Old 03-27-2008, 09:22 PM
SirRevvs's Avatar
Default Re: (polyhonda)
Not to sound ghetto but my tie rod boots on my ej coupe have been like that for years and I haven't had any problems. They should def be closed though. Just get some zip ties or adjustable clamps and clamp the boot over the outer tie rod to where the insides aren't showing. If you replacethem you will have to get an allignment.
Old 03-27-2008, 11:43 PM
wudini's Avatar
Default Re: (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">Not to sound ghetto but my tie rod boots on my ej coupe have been like that for years and I haven't had any problems. They should def be closed though. Just get some zip ties or adjustable clamps and clamp the boot over the outer tie rod to where the insides aren't showing. If you replacethem you will have to get an allignment.</TD></TR></TABLE>
yea don't do that, change your tie rod ends.
Old 03-28-2008, 12:14 AM
polyhonda's Avatar
Default Re: (wudini)
so like I just change the outer rods, where would i buy that?
Old 03-28-2008, 12:15 AM
SirRevvs's Avatar
any auto parts store.
Sic_DA_Nine
07-02-2006 09:55 PM
Yyz
02-21-2005 11:48 AM
spicoli
01-10-2005 10:13 AM
Propulsion
08-03-2002 08:52 AM
95gsr
06-01-2002 12:32 PM
Quick Reply: cv boot? (PICS)
