DC2 ASR SwayBar Reinforcement USDM 22mm SwayBar
Old 03-21-2008, 05:56 PM
OH_1fstgsr's Avatar
Default DC2 ASR SwayBar Reinforcement USDM ITR 22mm SwayBar
To start a few things I should mention.
If you workout and lift weights don't do this the same day you do your upper body work out.
Before, Stock 1999 GSR
After, A Spec Racing w/ITR 22mm swaybar
All the parts laid out
Look at the size difference, 14mm vs 22mm
Some Closer Views
Some of the tools ASR doesn't mention that you'll need to complete the job.
I also added this. EM Racing Trunk Floor Brace.
This is a shot of my Del Sol. Do you think the GSR sway bar will bolt right up?
Modified by OH_1fstgsr at 7:10 PM 3/21/2008
Old 03-21-2008, 08:07 PM
BlueIntegraBoy's Avatar
Default Re: DC2 ASR SwayBar Reinforcement USDM ITR 22mm SwayBar (OH_1fstgsr)
Why do you have non-Integra LCAs on your Integra? The effectiveness of the sway bar is nil if the endlinks aren't connected to the LCAs.
Old 03-21-2008, 10:18 PM
LsHoney84's Avatar
Default Re: DC2 ASR SwayBar Reinforcement USDM ITR 22mm SwayBar (BlueIntegraBoy)
Hows the car's handling feel?
Also did you buy that as a kit? where did you buy it from? I like that stealthy black color.
Old 03-21-2008, 11:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Why do you have non-Integra LCAs on your Integra? The effectiveness of the sway bar is nil if the endlinks aren't connected to the LCAs.</TD></TR></TABLE>
After taking another look, the LCAs are the stock Integra LCAs. I couldn't see the endlink mount point at first due to the ABS line in the way.
Old 03-22-2008, 02:21 AM
OH_1fstgsr's Avatar
Default Re: DC2 ASR SwayBar Reinforcement USDM ITR 22mm SwayBar (LsHoney84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsHoney84 &raquo;</TD></TR><TR><TD CLASS="quote">Hows the car's handling feel?
Also did you buy that as a kit? where did you buy it from? I like that stealthy black color.</TD></TR></TABLE>
Handling feels really good. Haven't driven it very far yet but the back end seems to feel like it is sticking to road better.
I only bought the reinforcement bar and trunk brace from JHP http://jhpusa.com/catalog/. I got all the ITR parts from work. That is exactly why I got the black, STEALTHY.
Old 03-23-2008, 02:53 PM
OH_1fstgsr's Avatar
I realized yesterday that I forgot to paint/primer over the holes I had to drill out for the ASR bolts. I have to take everything back off and apply some paint/primer so it doesn't rust. Maybe next weekend.
Old 03-23-2008, 03:01 PM
super jdm yo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH_1fstgsr &raquo;</TD></TR><TR><TD CLASS="quote">I realized yesterday that I forgot to paint/primer over the holes I had to drill out for the ASR bolts. I have to take everything back off and apply some paint/primer so it doesn't rust. Maybe next weekend.</TD></TR></TABLE>
word rust is a no no
Old 04-08-2008, 04:01 AM
OH_1fstgsr's Avatar
This past weekend I took all the new stuff off.
When I originally did this work I forgot to put primer over and in the holes that I drilled out. I really wish ASR would have mentioned this in the instructions.
After three weeks small amount of rust had started to show up. OHIO weather sucks.
I ran the drill bit in the holes to clean out the rust and used some sand paper also. Taped off some paper for over spray. Cleaned the surfaces with Acetone then finally two coats of gray primer.
Sorry no pictures this time, I was up against the clock.
Old 04-08-2008, 11:55 AM
NAmodified's Avatar
my subframe was a direct bolt on. I have that exact set up. When u change the LCA's and the get some coil overs, you will feel an even bigger difference. FOR SURE! check out my ride.
Old 04-08-2008, 12:38 PM
IN VTEC's Avatar
Default Re: DC2 ASR SwayBar Reinforcement USDM ITR 22mm SwayBar (NAmodified)
I just installed the brace with a 24mm solid bar. I previously had a JDM ITR '98-spec 23mm bar and Beaks brace.
The difference isn't much driving around town, and I lost the use of my rear under tray.
The installation was pretty easy. I did have to dremel out one of the holes that I had chiseled the tack welded nut off of previously to get one of the bolts to go through.
The one gripe I have about the brace is that the lower holes for the sandwich is drilled and counterbored for a M10 fastener, but you use a M8 fastener to bolt the two halves together. They need to revise it to drill the through hole for a M8 thread.
Old 04-08-2008, 06:39 PM
DCacosta's Avatar
looks beefy!
Old 10-15-2008, 08:51 PM
vietnamezerice's Avatar
Default Re: (DCacosta)
he said that it was a del sol... i don't believe they have rear sway bars
Old 11-09-2008, 10:49 PM
CeReal's Avatar
Default Re: (vietnamezerice)
well. you dont need to but you should. i recommend though upgrading the lca while you got that bolt out.
Old 01-29-2009, 01:37 PM
9KRevLimitDC2's Avatar
Default Re: DC2 ASR SwayBar Reinforcement USDM 22mm SwayBar
Asr braces arent bolt on? Im confused about what you need a drill for...
Old 01-29-2009, 05:04 PM
Brice.Hayden's Avatar
mine bolted on fine with no issues.
Old 01-29-2009, 07:43 PM
PatrickGSR94's Avatar
You have to drill out the stock spot-welded nuts on the inside of the subframe for the larger bolts to go through.
Old 01-29-2009, 08:47 PM
94VTEC2TONE's Avatar
nice man. i still need to go back to oem endlinks. these function 7 suck
Old 03-20-2009, 04:25 AM
Mike_C's Avatar
i didn't have to with brand new hardware i just got from ASR a couple days ago. this is a '93 hatch. just throwing that data point in here
Old 03-20-2009, 05:37 AM
uh what? Is there not a reinforcement plate that fits inside the subframe for the bolts to thread into? You have to pop off those spot-welded nuts to make room for that plate.
Old 03-20-2009, 09:22 PM
dcRay's Avatar
Well if for a del sol, it doesn't come with sway bar from factory. So they don't have any nuts inside the subframes.
Old 03-20-2009, 11:12 PM
saelee23's Avatar
Originally Posted by dcray
well if for a del sol, it doesn't come with sway bar from factory. So they don't have any nuts inside the subframes.
iirc only the base model del sols didnt come with sways, si's and the vtec's did
Old 03-21-2009, 04:30 AM
OH_1fstgsr's Avatar
Hard to tell from my Del Sol pic. There are NO nuts in the subframe. Cost down manufacturing.
Old 09-09-2009, 08:01 PM
bcpEG's Avatar
yes it will bolt right up but you need a new lca arm so you can link it
Old 06-25-2016, 10:59 AM
B88
B88's Avatar
Hi.
What do I need to fit a rear subframe into my Del Sol?
Just bolt it on?
Do I need to change lcas? Is that unused hole used to bolt endinks?
Topher1987
01-09-2009 11:09 PM
implayaz9
08-09-2008 12:15 PM
djtony5
07-28-2006 10:06 PM
RAS Motorsports
10-28-2004 08:59 AM
949eg
02-02-2004 09:03 PM
Quick Reply: DC2 ASR SwayBar Reinforcement USDM 22mm SwayBar
