map sensor wiring...
ive searched and im still confused.
i have a b16a2 it was originally in my 93 civic dx hatch, now the map sensor plug was in the chassis harness ( fusebox side) and when removing the engine from my new shell, the sensor plus and wiring was in the harness.. im completley confused and need some advice PLEASE... if you need more info let me know, putting motor in a 95 cx btw(edit)
Basically there should have been a plug on your engine harness that you did not use before (hopefully taped it back and not cut it off) that will be your map wiring since in a 95 it is wired to the shock tower plugs. If it was clipped you will need to splice a new connector onto the engine harness. Should be cake.
The only question that may change that would be does your engine have the throttlebody mounted sensor or the firewall mapsensor that only had the vacuum going to the throttlebody.
Re: (Endo-land)
my map sensor is on the TB on the b16 and it was on the TB on the single cam i took out , so you guys think on the engine harness i have for the b16 it was cut off, since the plug for it is on the chassis harness in my old shell?
Just take the plug off the old car and splice it back on to the engine harness, just make sure you do a good tight job so the sensor does not get bad readings.
Re: (egmatt93)
i cut a lil deeper and i found 2 wires just sitting there but im missing a third even if there are for the map, the wires are green with a white stripe and red with a yellow stripe, once again baffled on what i should do...
Re: (egmatt93)
need some help on what to do here...
should i just pull the map sensor wiring out of the dx and run it to the ecu in the cx?
I'll give you the pinouts, i'm at work now ill post a reply within the hour with the details,
I know how you feel, I did the h22a into a EG and built a wire harness from scratch, so I feel im qualifed to remember where all the wires went in the whole ordeal, gimme a couple and ill give you some assistance.
Re: (egmatt93)
A1----brn-----------Injector #1
A2----yel-----------Injector #4
A3----red1---------Injector #2
A4----grn/yel------VTEC Solenoid Valve
A5----blu-----------Injector #3
A6----or/wht-------HO2S heater coil
A7----grn/blk1-----PGM-FI Main Relay coil
A8----grn/blk2-----Shorted to A7
A9----blk/blu-------IAC Valve
A10
A11----red2--------EGR Control Solenoid
A12----blu/red-----Condenser Fan Relay
A13----blu/wht-----MIL
A14
A15----red/blu-----A/C Clutch Relay
A16----wht/grn-----Alternator
A17----pink---------IAB Solenoid Valve
A18----orn/red-----FAS (A/T)
A19----wht----------Intake Control Solenoid Valve
A20----red/grn-----EVAP Purge Control Solenoid
A21----yel/grn1----ICM
A22----yel/grn2----Shorted to A21
A23----blk1---------GND
A24----blk2---------GND
A25----yel/blk------PGM-FI Main Relay (power)
A26----blk/red------VTEC Pressure Switch (GND)
B1----yel/blk--------PGM-FI Main Relay (power)
B2----brn/blk-------GND
B3----orn1----------AFSA (A/T)
B4----pnk-----------AFSB (A/T)
B5----blu/blk--------To A/C Switch
B6
B7----lt grn---------ATP PN Gear Posisiton (A/T)
B8----red/grn-------PSP Switch
B9----blu/red-------Starter Cut Relay
B10---orn2----------VSS
B11---orn3----------CYP
B12---wht-----------CYP
B13---orn/blu-------TDC
B14---wht/blu-------TDC
B15---blu/grn-------CKP
B16--blu/yel--------CKP
D1----wht/yel-------Battery
D2----grn/wht1-----Brake Switch
D3----red/blu-------KS
D4----brn/wht------SCS
D5
D6----lt blu or lt grn-VTEC Pressure Switch
D7----lt grn/red----Data Link Connector
D8
D9----wht/red------ALT
D10---grn/blk------ELD
D11--red/blk-------TP Sensor
D12---wht/blk------EGR Valve Lift Sensor
D13---yel/blu-------ECT Sensor
D14---wht----------HO2S Sense
D15---red/yel------IAT Sensor
D16
D17---wht/blu------MAP Sensor
D18---lt grn/blk----VREF (A/T)
D19---red/wht------EGR Valve Lift Sensor
D20---yel/wht------TP Sensor
D21---blu/wht------MAP Sensor
D22---grn/wht2----TP Sensor
This is the entire OBD1 pinout list I have worked with,
Map sensor is
A10
A14
B6
D5
D8
D16
Map sensor is
Re: (likwidchz)
cant see pic cause im at work, gonna look at it when i gett off work, thank you for ur help man i really appreciate it
Re: (likwidchz)
would u or anyone else have the pinout for the map sensor wiring in the engine harness so i can just run it through the engine harness and have it plug n play with the chassis harness?
Slacker93eg
09-12-2012 09:48 AM
