Last edit by: IB Advertising
Browse all: Exterior Guides
- Why Are My Headlights Dim?
Guide to diagnose trouble and recommended solutions
Headlights bright then dim. ELD or "loose" regulator???
#26
Re: Headlights bright then dim. ELD or "loose" regulator???
i have the same problem when i first start my none of the dash lights come on. i always thought it was because of my HIDS. the lights also dim when im at idle.
#28
1 Post
i'm having the same problem, ive changed the alternator and the battery and nothing!
the lights keep flickering and pretty much drains my battery
#29
Remove and clean all of your grounds. Make sure they are all in the correct spots. Clean and reinstall the trans and engine grounds. Remove the ground from the thermostat housing, clean, reinstall. If that does not do it and if your alternator checks fine, you either have a whacky ELD or possibly a bad battery, etc.
#30
#32
I had the same problem. I fixed the lights flickering by pulling the alternator control wire (usually green/white) out of the ecu harness. The lights stay nice and bright now but it is something to do with the ELD bc I have my fuse box relocated under the dash and it clicks loudly every time the lights brighten or dim. Pulling the wire keeps the lights normal but the fuse box still clicks.
Everybody should try to find out if their fuse box clicks also so we can finally figure this out.
The real problem I have is that my car also won't idle right and I think the two problems are related. About every 20 seconds the idle will drop and build back up once the car is warmed up. I think its maybe a ground, but I'm not sure.
#33
#34
One thing i noticed when checking the eld's function that on the diagram it says the there is a wire that goes to the ignition for 12 volts when i measure it has none, so i threw a wire to that wire and got 12.5 with the lights on and no flickering so if maybe you can put this to a accessory fuse so it is no on all the time and i wouldn't drain the battery
#35
#37
Headlight Dimming FIXED without replacing Alternator or Battery
First I tightened all the screws in the fuse box under the hood marked with red arrows, and replaced the 60A fuse in the fuse box.
By ralphypoo at 2010-10-06
Second when I tightened the cable on Terminal B on the alternator marked with red arrow, it broke off, which made me remove the terminal, tap it, and put a new stud in.
This required removing and installing the 8MM screw holding the terminal on, under terminal B.
I am not sure which part of all these steps corrected the issue, but it did, and cured the AC blower motor problem which was constantly changing speed.
#39
moral of this story i guess is check the small stuff first. I had a similar problem on my EJ7. Turns out it was a fuse issue. wasnt bad but it solved it. and i cleaned the grounds.
#40
#42
I have a 2003 Accord EX V6 with the same issue. It just started happening about 2-3 months ago. Does anyone have a diagram or instructions on how to remove or replace the ELD? Is this even possible? I was told by my mechanic that I could remove it temporarily to see if it resolves the problem and if it does, then replace it.
#43
#44
mine does that too (95 civic), but then again its putting out 21 Volts, so I'm pretty sure it's the alternator in my case but I'll make sure to check all the wires too.
#45
#46
I having this issue almost exactly as described, although I think its more severe. The engine noticably picks up torque when it hits 4k rpm and the lights get brighter. This is regardless of load on the electrical system. I've also gotten codes for low voltage to primary o2 sensor. Its seems like its progressively gotten worse so it may be some loose wires, but the 4k RPM EVERYTIME thing makes me think otherwise.
I checked the alternator and battery at idle and they seem to be fine. I'll have to perform the steps here this weekend and see what happens.
#48
Yeah I've noticed headlights and dash lights dimming at idle, and when I run the rear window defrost I get the same result.
Going to go through all of the small steps first and see where that gets me.
Alternator appears to be original. Motor has 270k km.
#49
Alright, so I tightened up all the screws in my fuse box and it seems the problem has went away. I replaced the screw that goes from the batery to the fuse box and all is well.
