OBD Plug Help :(
Old 02-19-2008, 06:41 AM
Singnakornchai's Avatar
Default OBD Plug Help :(
Hi there just brought a 98 5 door hatch VTI and want to check the diagnostics only trouble being "can I find the OBD plug". I have looken under dash near fuse, had panel out next to bonnet release but can't find the thing anywhere. Can someone please help as I have just spen 1 hour freezing my stuff off looking for the thing...
By the way great forum!!
Old 02-19-2008, 06:49 AM
crazyguy's Avatar
Default Re: OBD Plug Help :( (Singnakornchai)
u mena ecu and ecu plug? it is located at passenger kick panel
Old 02-19-2008, 07:53 AM
thesmogman's Avatar
Default Re: OBD Plug Help :( (crazyguy)
There are a couple of places the DLC connector could be..
Right beside the hood release, just next to the drivers kick panel.
Or look at the bottom of the steering column there might be a sticker that tells you where it is at. Might be behind the ashtray.
Look along the bottom edge of the plastic on the drivers side.
And last two spots are under by the gas pedal. look toward the center console. and last is on the passengers side by the center console.
By the way what is a VTI? If it is a civic it is #1
Old 02-19-2008, 09:32 AM
nub
nub's Avatar
Default Re: OBD Plug Help :( (thesmogman)
i saw you are in the u.k. is this rhd or lhd? are you looking for the obd diagnostic plug or the service check plug?
Old 02-19-2008, 11:47 PM
Default Re: OBD Plug Help :( (nub)
All thanks for the info, Nub its a rhd and it's the diagnostic plug I'm looking for. Idle is at 1500 so looking to see if any errors present that can shed some light without me having to take to local garage
Old 02-20-2008, 12:08 AM
Chicago_Boosted_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">u mena ecu and ecu plug? it is located at passenger kick panel</TD></TR></TABLE>
wow crazyguy really knows his stuff just helped me and my friend out from alot of trouble keep up the good work
Old 02-20-2008, 12:16 AM
H-T White Ops
NOFX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">By the way what is a VTI? If it is a civic it is #1</TD></TR></TABLE>
The OP has a 1998 Honda Civic VTi five-door. It'd be RHD because though most of Europe is LHD, the UK and Ireland are not.
I posted photos of a few five doors in this thread: https://honda-tech.com/zero...age=2
To the OP, I'm not sure if UKDM vehicles have DLCs like the US vehicles have to have. I'm not sure what markets this might have been included with, so I'm not exactly sureif a scan tool could be used on your car.
Here is an image of about where it would probably be if it's there though. I say "probably" because I know this is where most DLCs are, but not all. Not even all Honda DLCs are here.
If it's not there, look all along the bottom of the dash and check for any panels that pop off or open on the center console and dash parts.
Worse comes to worst, call up your local Honda dealership. They've helped me out in the past when I couldn't find a DLC on a vehicle.
Old 02-21-2008, 02:09 AM
Wow, NOFX thanks for the info. I was looking for a 16 pin as mine is 98uk model it does not have this. Thanks for all the info anyway
Mister V
07-24-2007 10:08 AM
ndulko
11-07-2006 04:02 PM
xlur8ed
Honda Civic (2006 - 2015)
03-26-2006 05:56 PM
1gEF-8
08-07-2005 10:06 AM
IgniteTeg
10-25-2001 09:23 PM
Quick Reply: OBD Plug Help :(
