> Road Racing/Autocross
Old 03-08-2008, 04:54 AM   #51
Mohudsolo
Default Re: (ED9man)
Karcepts, why would you want to mount the pump in front of the transmission? Putting it there defeats one of the reasons to bother with the electric pump, being able to keep the weight behind the axle. It's lower than a stock pump which helps some, but on the floor or firewall is better IMO.
Mohudsolo is offline Report Post   Reply With Quote
Old 03-08-2008, 10:03 AM   #52
Karcepts
Karcepts's Avatar
Default Re: (Mohudsolo)
I totally agree with desiring weight more rearward but there is very little room on the firewall area with a K-series unless you have your battery relocated and have a RHD like Kiwi where you don't have a brake master cylinder and booster in the way. It could mount on the other side of a LHD master cylinder/booster, but the weight would be very high to avoid transmission interferences and the bracket itself would have to be substantial and gusseted due to overhung loading from the nearest available mounting location. This was the most logical mounting position for my scenario. The electric pump in this location is no more forward than the belt driven unit you are removing, it is located ~12" lower, and requires a simple 1/2 lb aluminum flat plate to mount instead of a potentially heavy steel gusseted bracket if trying to form it around a brake master cylinder. The main reason to bother with the electric pump for me was to free up some extra HP. The mounting position relative to weight displacement is still an improvement over the stock belt driven unit, so it isn't proving to be disadvantageous in any way. The car I am mounting this in isn't really an all out race car; so yeah, if you don't mind throwing it inside and mounting it on the floor with you, then I agree, that would be a bit better.
www.Karcepts.com
Karcepts is offline Report Post   Reply With Quote
Old 03-09-2008, 11:21 AM   #53
Crx Jimmy
Crx Jimmy's Avatar
Originally Posted by ED9man
There are hydraulic lines running into the speed sensor that sits on the diff from the rack that control the pressure based on speed.
This is only on the cable b-series tranny's in the 88-91 crx/civic(jdm edm) and the 90-93 integra. they utilize a different pump as well. this doesnt apply to most of the cars in question which seem to be eg/ek's
Crx Jimmy is offline Report Post   Reply With Quote
Old 03-11-2008, 03:12 PM   #54
rotten
rotten's Avatar
Send a message via ICQ to rotten
Yes, but get this: basically its a little pump. If you block off that line going into the rack's pressure sensor/switch, it simulates speeds in excess of 30 MPH. So basically the amount of assist on those racks is variable up to 30 MPH and then is the same from 30 MPH onwards.
By eliminating the VSS hydraulic lines (like in a OBD1 motor & trans in a EF) you're basically underboosting the rack slightly, which is exactly what we'd want. Certainly better than having parking lot amounts of assist while going 60!
I was surprised to see that there is not boost difference on the rack after 30 MPH. I thought it was variable up to perhaps 60MPH or more. I suspect that actually the difference between 0 and 30 may be smaller than I'd original thought as well.
This is great news for me because it simplifies the power steering conversions on EFs.
THe other side of this is that on the EFs you could also use the stock VSS hydraulic lines to control the amount of assist you're getting from an electric pump. THe pump can put out full pressure, but the rack would meter what it needs based on the VSS.
rotten is offline Report Post   Reply With Quote
Old 03-11-2008, 10:51 PM   #55
ED9man
ED9man's Avatar
Send a message via AIM to ED9man
So you are saying it boosts less from 0-30 and more from 30 on? That doesn't seem to make sense. Or when you block the line it boosts as much under 30 as it does from 30 on? I would think that it would up the assist under 30 and have it plateau above 30? Also I am wondering if the VSS is beneficial because it controls the boost in the rack regardless of pump output, I am wondering if Toyota pump runs at a higher pressure/ moves more fluid and would cause the rack to be overboosted without something that keeps it in check?
ED9man is offline Report Post   Reply With Quote
Old 03-12-2008, 12:17 AM   #56
RagingAngel
RagingAngel's Avatar
rotten is simply stating that the boost from 30mph onward is constant and lower.
Below 30mph it has a higher level of boost.
If you block off the EF's VSS hydro lines, you have constant under-boosting.
RagingAngel is offline Report Post   Reply With Quote
Old 03-12-2008, 03:09 PM   #57
rotten
rotten's Avatar
Basically what Raging Angel sez. It gives more assist/boost at slower speeds up to 30 mph, where it flattens out. Blocking the VSS line simulates an over 30mph condition--basically underboosting at slow speeds, which is perfect for what we want.
I actually suspect that the difference between low speeds and high speeds may not be as much as it seems like it would be.
You're right about the VSS stuff--it basically is a little pump that builds pressure to a pressure release valve in the rack itself. It would function the same with an electric pump or the stock belt-driven unit. So at least on the 90-93 Integra racks (with the 4 ports) you should not get an overboosted scenario even if the Toyota/Subaru/Mazda whatever electric pumps provided more pressure than stock pumps.
Old 03-23-2008, 01:48 PM   #58
soulpwr
Default Re: Special Projects - Electro Power Steer (KIWI)
Freshdrive
soulpwr is offline Report Post   Reply With Quote
Old 03-23-2008, 09:31 PM   #59
SkankyEJ7
SkankyEJ7's Avatar
Default Re: (KIWI)
looks like i may need to hit a junkyard or too to find me a mr2 ps pump
2003 RSX type s
1998 civic lx
wēk´sôs ĭn'dustrēz
SkankyEJ7 is offline Report Post   Reply With Quote
Old 07-27-2008, 02:22 AM   #60
drmikey
drmikey's Avatar
Default Re: (SkankyEJ7)
I've been using this setup on my K20 EK for a couple of years now and it is excellent - although I added a 4QD speed controller to adjust the assistance pressure and also does away with the need for a high power relay.
But I now have this system for sale as I'm now racing and have to go as basic as I can. I'm after $400 and includes
MR2 pump
Custom lines
Resevoir bottle
4QD controller
All wires
K20 EK9
drmikey is offline Report Post   Reply With Quote
Old 07-28-2008, 07:48 AM   #61
rice r0cket
rice r0cket's Avatar
Default Re: (drmikey)
Has anyone considered an electric rack from the NSX and S2000?
It adds a couple lbs to the rack, but eliminates the pump and all other associated hardware. Basically half the rack gear is a worm gear, and a motor sits around it driving it.
1998 CR-V JRSC'd
1993 FD3S
http://www.racepa.com
rice r0cket is offline Report Post   Reply With Quote
Old 07-28-2008, 10:39 PM   #62
Ramirez428
Ramirez428's Avatar
Default Re: (rice r0cket)
would it even bolt up to eg/dc ek?
Ramirez428 is offline Report Post   Reply With Quote
Old 07-31-2008, 09:59 PM   #63
ErrDizzle
ErrDizzle's Avatar
nope and you need a module and sensors to control the motor. it would be great if everything was self contained and only required power wires.
EKSquad, 247Racing - don't get sunk, get flush. offset is everything
Get all the latest gear at Karmaloop.com. Use my rep code Errdizzle to receive 20% off your first purchase and 10% all other purchases there after
ErrDizzle is offline Report Post   Reply With Quote
Old 08-02-2008, 01:21 PM   #64
Jaker
Default Re: (ErrDizzle)
Why the need for the module/sensors? I haven't done any research, but from the look of that picture, there's a steering universal shaft sticking out of the rack.
Jaker is offline Report Post   Reply With Quote
Old 08-02-2008, 03:08 PM   #65
ErrDizzle
ErrDizzle's Avatar
hhmmm ok. it just looks like a steering rack with a dc motor on it. so whats going to control the motor? whats going to sense which direction to steer or how fast the steering wheel is being turned, how much assist, which direction to assist, or even how much assist to use when at high speed, etc.
it's easier to use a normal ps steering rack and just add an electric pump for our cars because the valve body on the top of the rack that connects to the pinion already figures out how much assist, which direction, etc.
Old 08-02-2008, 06:23 PM   #66
Jaker
How would it be any different to have the sensors built into the rack, and feed the input from the steering wheel via the steering column to these sensors versus having the sensors in the steering column up by the steering wheel?
EDIT:
I've done some research now. The S2000 uses the electric power steering rack, a rack mounted "torque" sensor where the steering shaft/column attaches, a power steering control module, and signals from the speed sensor and the tach. I think the speed signal needs to be the same high frequency signal that everyone pines for to permit the use of the S2000 cluster in EKs, EGs, etc... but we all know there are signal converters out there. Now the only parts left are mounting the rack in your chassis, and adapting the tie rods and the steering column attachment.
Sounds like it could be a little simpler than the MR2 power steering pump, assuming the rack mounting can be done without too much hacking. I think I might give this a try.
Anyone interested in all the MR2 power steering system components, except for the steering column sensor? I have the pump, the controller, the power relay, a bunch of wire attached to the appropriate plugs, and some sections of the power steering lines for fittings.
EDIT #2
Scrap that idea. The S2000 is a front steer car. The damned rack will make the wheels turn the wrong way.
Modified by Jaker at 8:39 PM 8/2/2008
Modified by Jaker at 8:42 PM 8/2/2008
Old 08-05-2008, 06:22 PM   #67
ErrDizzle
ErrDizzle's Avatar
how about a rhd s2k rack mounted backwards.
Old 08-05-2008, 08:21 PM   #68
Jaker
I've been thinking about that. Haven't given it enough thought yet though.
Old 08-06-2008, 03:38 AM   #69
rice r0cket
Default Re: (Jaker)
http://www.jtekt.co.jp/e/products/steering01.html
HMMMMMM...
1998 CR-V JRSC'd
1993 FD3S
Old 08-12-2008, 04:28 AM   #70
stealth50k
stealth50k's Avatar
Send a message via AIM to stealth50k
Anyone know where to buy the fittings for the hoses and the hoses themselves. A website or something would be cool. thanks
edit:
I found some good sites with the hoses and fittings for this job.
http://store.summitracing.com/...XID=5
http://www.racerpartswholesale...tings
Modified by stealth50k at 4:46 PM 8/12/2008
stealth50k is offline Report Post   Reply With Quote
Old 08-13-2008, 06:52 AM   #71
ShagNastyEK9
ShagNastyEK9's Avatar
Send a message via AIM to ShagNastyEK9 Send a message via Yahoo to ShagNastyEK9
MR2 pump
Custom lines
Resevoir bottle
4QD controller
All wires
Great price, if i had the money to spend, i would jump all over it, these pumps are hard to find used, and not cheap new, sure it will sell
90 Honda Civic EX Sedan "daily" on Volks
99 Honda Civic Hatchback shell with some goodies, for sale, PM me for details
00 Honda Civic EX Koupe, caged & suspended 4 track days, no p/s, no a/c, no radio
ShagNastyEK9 is offline Report Post   Reply With Quote
Old 08-17-2008, 08:38 AM   #72
kommon_sense
kommon_sense's Avatar
Send a message via AIM to kommon_sense
Default Re: (stealth50k)
I bought mine from http://www.anplumbing.com . However having done this now, I don't like the Earls high pressure hose. Its very difficult to work with and has a cloth/fabric coating that stains very easily. If I were to do it again, I would try russell or aeroquip.
edit:
Intentionally left blank...
kommon_sense is offline Report Post   Reply With Quote
Old 08-18-2008, 09:31 PM   #73
BlackDog914
Default Re: (Jaker)
Jaker ... I'd be VERY interested in buying the MR2 pump and bits that you have... I've just joined the forum and am restricted from PM'ing ... so... if you could e-mail me at jim@island.net maybe we could go from there... I'd also like to hear from DrMikey on the 4QD controller idea..
thanks
Jim
BlackDog914 is offline Report Post   Reply With Quote
Old 08-18-2008, 10:40 PM   #74
Jaker
Default Re: (BlackDog914)
thanks
Jim
Hey Jim.
Thanks for the interest, but I won't be doing anything anytime soon. Since I realised the S2000 is front steer (rack resides ahead of the front wheels in the chassis), and I can't use a LHD rack (the wheels would go the wrong way), I have to come up with a better idea (maybe a RHD rack flipped around).
I'll keep you in mind if I do come up with a solution.
Old 08-19-2008, 08:56 PM   #75
JOEY F.
JOEY F.'s Avatar
Send a message via AIM to JOEY F.
Default Re: (Jaker)
Wow, this is awesome. Id def be up for buying a kit when it comes out.
www.TUNINGSPL.COM
JOEY F. is offline Report Post   Reply With Quote
Bookmarks
boot, drive, ep3, gpm, hydraulic, motor, mr2, power, project, pump, racing, special, steering, stering, train
