another p28 ecu question. Auto or Manual
Old 02-08-2008, 09:21 AM
thizboii's Avatar
Default another p28 ecu question. Auto or Manual
P28-L00
Thanks
Old 02-08-2008, 09:25 AM
z6hatchboy's Avatar
Default Re: another p28 ecu question. Auto or Manual (thizboii)
92-5 ECUs (P28, P30, P61, P72, P91, P08)
5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02, G00, G01
Auto = J50, J51, 901, 902, C50, C51, C52, A50, A51, A52, L50, L51, G51
Old 02-08-2008, 09:26 AM
thizboii's Avatar
Default Re: another p28 ecu question. Auto or Manual (z6hatchboy)
that was quick! thanks. i was looking for that, So any with a L is a auto then?
Old 02-08-2008, 09:31 AM
z6hatchboy's Avatar
Im guessing so, another way to check is to take the cover off and see if theres a resistor in "RP18" in the lower right-hand bank of resistors.
Old 02-08-2008, 09:58 AM
Relic1's Avatar
L = cali-spec emissions (A=49-state spec)
0 = manual trans (5=auto)
0 = first revision of circuit board (1,2,3 = later versions)
the revision of the board doesn't really mean a lot unless you're looking to modify the hardware of the board.
RP18 in a manual trans car has a zero ohm resistor in place, this tends to confuse peope who don't know how to read it.
RP17 is a better location to use. nothing = manual trans, resistor in place = auto.
Old 02-08-2008, 10:02 AM
z6hatchboy's Avatar
Default Re: (Relic1)
Ah, thanks for the info
Old 02-08-2008, 10:14 AM
thizboii's Avatar
Old 02-08-2008, 12:53 PM
ejoner's Avatar
Default Re: (thizboii)
Not to thread jack but are the non cali ecu's any better?
Old 02-08-2008, 01:26 PM
wangkata's Avatar
check this thread it help...
https://honda-tech.com/zerothread?id=810101
Old 02-08-2008, 02:30 PM
Relic1's Avatar
Default Re: (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner &raquo;</TD></TR><TR><TD CLASS="quote">Not to thread jack but are the non cali ecu's any better?</TD></TR></TABLE>
depends on what you mean by better.
Generally speaking cali-spec ECUs have cleaner emissions due to the stricter cali laws.
If you want to get general fewer emissions = less power. But not always.
It all depends on what the honda tuners did to produce less tailpipe emissions.
blink_977
10-28-2009 09:50 AM
sicksiguy
02-07-2007 08:33 PM
lazyvietboi
08-06-2004 03:03 PM
HybriDNA
12-10-2003 06:31 PM
hondafrk
02-22-2003 08:58 PM
Quick Reply: another p28 ecu question. Auto or Manual
