> Honda CRX / EF Civic
Old 01-29-2008, 09:10 AM   #1
BrakeExpert
Banned
Default DIY: 11.1" brakes on DX knuckles at long last!!!
DIY: 11.1" Brakes on Civic DX knuckles. No need for EX or Integra knuckles!
This applies for:
1988-2000 Honda Civic DX LX VX HX CX models (don't know if HF will work)
1988-1995 Honda Civic Si without ABS (9.5" front brakes)
This will also work for any 88-00 Civic or 90-01 Integra that has DX Civic knuckles on it (9.5" brakes).
As some of you may have known, I'm nuts about brakes. Problem is that DX (and CX, LX, etc) with the 9.5” front brakes have a different shaped steering knuckle; the mounting tabs for the brakes are pulled in closer, so all of the brake options available for the big 4x100 hubs on the EX knuckles(which are a LOT of options) are not going to work on the DX knuckles. Well after enough testing and screwing with parts, I found out that the only upgrade you can put on DX knuckles was 10.3" brakes and ITR calipers. Well now I've figured out how to have the full 11.1" rotors on!
PRELUDE: This will cover how to convert your front 9.5" Honda brakes on the 88-00 Civic non-EX models into 11.1" CL front brakes. This upgrade will improve your braking performance. This setup offers a larger sweeping area, a very strong caliper, much larger pad, increased brake torque over a larger disc rotor, increased resistance to fade, and Honda reliability. This setup uses stock knuckles and stock brake hoses. If you are getting a kit from BrakeExpert, the modifications have been made and it is a bolt on uograde.
NECESSARY MODIFICATION: The rotors must be redrilled to 4x100 and custom aluminum rotor centering rings will be needed to ensure there is no radial vibration.. These redrilled rotors are safe because the lug stud holes have no sideways force exerted on them. The pressure from the lug nuts transfers throughout the whole face of the rotor's hat. The rotor is centered on the hub and the lug holes are there only to allow the studs to go through the rotor's hat and wheel's lug holes. The lug studs will not touch the rotor at all.
The rotors are a bit too tall and will hit the bracket when new. The bracket must be milled at the back where the knuckle mounting tabs are. Because this affects the caliper's contact angle, this machine work must be parallel like stock. A milling machine is required with a dial indicatior to ensure the cuts are each made the same depth to within .001". The brackets will not work stock, they will not bolt up to the knuckle and the hangar will lightly rub on the rotor's hat. The bracket should have a notch grinded at the backside to prevent it from hitting the knuckle. It should also be grinded carefully on the underside of the hangar to prevent this rubbing. I reccomend painting or coating this part to prevent any possibility of rust causing weakening over long periods of time. Also, since this is a custom setup and fitment is very tight, the retainer clips must be modified to have the part in the bracket's throat removed. This should be done with the proper dremel or metal cutting jig-saw very carefully. This is spring steel, which is difficult to cut, so be careful as a mis cut can cause the metal to break or crack in the middle.
Tools: 17mm wrench, 14mm wrench, 12mm wrench, phillips screwdriver, 19mm deep socket, socket wrench, 10mm wrench, torque wrench, rags, 10mm brake line wrench (optional), impact wrench (optional), ball scratcher (optional.)
INSTALLATION:
Ok so heres what's involved. 03 Acura CL front calipers, brackets and pads, 96 Prelude VTEC rotors, rotor centering rings, and machine work.
You will need access to a machine shop to make this work, or PM me (BrakeExpert) and I can take care of it for you.
1. Acquire all parts and tools.
2. Engage e-brake and put the car in Park or first. Jack up the nose of car and put the car on jackstands in the front.
3. Unbolt the lug nuts and remove the wheel.
4. Break the rotor retainer screws loose with the impact wrench. This may not be necessary if your screws are not rusted or you used anti-seize, but may be needed on older cars.
5. Remove the banjo bolt that connects the brake hose to the caliper. Now it gets messy, remember not to touch your car's paint with brake fluid on your hands.
6. Remove the 17mm bolts that hold the caliper to the steering knuckle. Remove the caliper.
7. Place the rotor centering ring on the hub.
8. Place the 11.1" rotor on the hub and use a lug nut to keep it in place.
9. Bolt the CL caliper with its brackets and pads onto the knuckle and torque the 17mm bolts to 80lb-ft.
10. Bolt the brake hose onto the caliper and torque to 30lb-ft if reusing your old crush washers. I reccomend new ones every time, but the old ones can get a second use if you overtighten just a bit (don't exceed 35lb-ft, you don't want to mess up these threads.
11. Pump the brake pedal enough to get the pads to clamp the rotor. The pedal will be soft since there is air in the system because it hasn't been bled yet.
12. Remove the lug nut and put the wheel on. Torque your lug nuts to 75lb-ft for aluminum wheels, 80lb-ft for steel wheels.
13. Do the same for the other side.
14. If you are upgrading the master cylinder, remove the MC by unbolting the 10mm bolts on the hardlines with a brake line wrench and then the 12mm bolts from the brake booster.
15. Bench bleed the master cylinder. If you are lazy and don't mind making a mess, fill the resovoir with brake fluid with the new MC out of the car. Use a screwdriver to push into the cylinder bore(EK/98+ Teg) or press on the piston if this is an EG/94-97 Teg. Do this about 6 times, fluid will gush out of the two holes.
16. Install the master cylinder onto the brake booster and tighten the 12mm bolts and then tighten the 10mm brake line bolts.
17. Your brakes are on. The new brakes must be bled. Use either a factory service manual for bleeding procedures, or check online for a standard bleeding procedure on hydraulic brakes. The proper bleeding order for Civics/Integras is Right Rear, then Left Front, then Left Rear, then Right Front. This is because of the crossed brake system; do not go by the method of fartest to closest (to the master cylinder). I reccomend bleeding the whole car, however if you are not changing the master cylinder (and you do not have ABS), you can bleed just the front brakes, however I reccomend bleeding all 4 brakes anyway.
18. Bleed the brakes.
19. Your brakes are on! Ensure the pedal can stop the car by removing the bricks, releasing the e-brake, and moving the car slightly. Stop the car with the pedal, if it does not stop, use the e-brake and check the brake system for bubbles by bleeding the car again.
20. Brake in your new brakes pads by standard brake pad brake in procedure. I reccomend finding an empty straightaway. Get the car upto 50mph and hit the brakes lightly, slowing the car to 10mph, but not to a complete stop. Do this about ten times, not giving your brakes time to cool in between. Your brakes will be pretty warm afterwards, so find a place to stop the car and let the brakes cool to under 100 degrees if possible.
21. Enjoy having stronger than Type-R brakes without having to source and install new steering knuckles! Enjoy having the ability to stop your car at high speeds without fading all the time!
The end result will look like this:
by BrakeExpert
Feel free to ask any questions or IM me if you need parts/machining for this setup.
Updated with better pictures.
Modified by BrakeExpert at 3:19 AM 2/20/2008
BrakeExpert is offline Report Post   Reply With Quote
Old 01-29-2008, 09:34 AM   #2
Hayasa15
Hayasa15's Avatar
Send a message via AIM to Hayasa15
nice i have been waiting for this info
DA Squad Member #61
1990 Civic STD Hatchback with a turbocharged D16Z6
1991 Integra GS 4 dr - auto x car STS #15
2002 Civic EX 4 dr on Teins with TV's for the kiddies
Hayasa15 is offline Report Post   Reply With Quote
Old 01-29-2008, 09:36 AM   #3
oreopeete
oreopeete's Avatar
Default Re: DIY: 11.1" brakes on DX knuckles at long last!!! (BrakeExpert)
yaay! is there any way you could post up step by step PICS? or at least the pics of the part after the machining is done... its gets confusing in a part or 2. thanks
95 civic cx
96 4dr ex
oreopeete is offline Report Post   Reply With Quote
Old 01-29-2008, 09:53 AM   #4
dem0nk1d
dem0nk1d's Avatar
Send a message via AIM to dem0nk1d
do you have the caliper bracket number, and caliper numbers as well? can you please list them...
95 EG Civic (R.i.P T-Boned)
89 EF Sedan (Current Project)
"keep a full interior and still be fast!!!! leave the stripped interiors to the real racecars!!!!" -sikefcrx89
"don't be a ricer! keep your bumper support kids, it might save your life." -dem0nk1d
dem0nk1d is offline Report Post   Reply With Quote
Old 01-29-2008, 11:01 AM   #5
ComeOnKip
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
Send a message via AIM to ComeOnKip
Awesome! Good write up!
Add this to the FAQ's.
We all knew what consequences could be with the crew we had at the controls, there's no harbor age for the USA-holes. I doubt there's a benign God to save our souls, cuz no one else is gonna save the USA-holes
ComeOnKip is offline Report Post   Reply With Quote
Old 01-29-2008, 12:16 PM   #6
CRX Toad
Moderator
CRX Toad's Avatar
What is the amount that must be milled out of the caliper bracket? It appears you left that out. Is it the same amount as the EX/ITR setup?
Hondworks
Need a write up on how to fix your CRX cracked climate control, PM me
CRX Toad is offline Report Post   Reply With Quote
Old 01-29-2008, 12:36 PM   #7
dem0nk1d
dem0nk1d's Avatar
Yeah do will mill the back bracket off like the other swaps? Also can you give casting numbers on the parts. Maybe when i goto the junkyard i maybe able to find another car that uses the same setup. Also what MC do you recommend using?
--- I guess i'm selling my accord calipers and brackets now...
For once Toad has locked a post down...
Old 01-29-2008, 02:05 PM   #8
spun Vtec
spun Vtec's Avatar
Send a message via ICQ to spun Vtec Send a message via AIM to spun Vtec
Default Re: (dem0nk1d)
great info!
SOHC done right. My Naturaly Aspirated d16z6 build.
97 artic silver BMW ///M3
89 Civic SI hatch p29'd sohc ITB crower3'd - scca racer
"A built B-series is like a boob job, alot of BITCHES have them and im just not impressed "
spun Vtec is offline Report Post   Reply With Quote
Old 01-29-2008, 03:23 PM   #9
Wilky
1990 Honda Civic
Wilky's Avatar
Originally Posted by spun Vtec
great info!
Wilky is offline Report Post   Reply With Quote
Old 01-29-2008, 04:32 PM   #10
24TEN
24TEN's Avatar
I'm gonna read this later after work
24TEN Garage Sale
EF/EG Parts and Rims, Click Link:
http://www.hondamarketplace.co...65178
Will be jobless after September 18th, 2008 http://images.honda-tech.com/set1/smile/emsmilep.gif
24TEN is offline Report Post   Reply With Quote
Old 01-29-2008, 04:58 PM   #11
mullet eater
mullet eater's Avatar
Default Re: (24TEN)
Thats real nice!
Life is what you make of it!
Patience is everything!
mullet eater is offline Report Post   Reply With Quote
Old 01-30-2008, 07:49 PM   #12
roastbeefrichie
roastbeefrichie's Avatar
Send a message via ICQ to roastbeefrichie
good info brakeexpert!
EF DA EG DC EK
roastbeefrichie is offline Report Post   Reply With Quote
Old 01-31-2008, 06:17 AM   #13
D50boy
D50boy's Avatar
Send a message via AIM to D50boy
Default Re: DIY: 11.1" brakes on DX knuckles at long last!!! (roastbeefrichie)
Not bad! What size wheels will be needed? I don't think i'd be able to retain my stock 13"s (89 model)
'99 B18C5 Civic Hatchback- for fun
'08 L15A Fit Hatchback- for the wife
D50boy is offline Report Post   Reply With Quote
Old 01-31-2008, 07:06 AM   #14
CRX Toad
Moderator
CRX Toad's Avatar
Default Re: DIY: 11.1" brakes on DX knuckles at long last!!! (D50boy)
15" there are very few 14" that will fit and the ones that will are pricey. So it is safe just to say 15"
Hondworks
Old 01-31-2008, 08:11 AM   #15
newby_j
Needs More Cowbell
newby_j's Avatar
Default Re: DIY: 11.1" brakes on DX knuckles at long last!!! (CRX Toad)
This Thread Needs More Cowbell!!!
H2B CRV Build
http://www.honda-tech.com/showthread.php?t=2563782
newby_j is offline Report Post   Reply With Quote
Old 01-31-2008, 08:18 AM   #16
dr_latino999
Global Instigator
dr_latino999's Avatar
Send a message via AIM to dr_latino999
Default Re: DIY: 11.1" brakes on DX knuckles at long last!!! (newby_j)
Bookmarked for future FTW reference.
One Step closer to finishing my short block: "Houston, 77mm CP's are in the sleeves, over."
Project D16 On Crack
dr_latino999 is offline Report Post   Reply With Quote
Old 01-31-2008, 10:23 AM   #17
Hayasa15
Hayasa15's Avatar
DA Squad Member #61
Old 01-31-2008, 02:11 PM   #18
BrakeExpert
Banned
You will need to take off 5mm of material, which I know seems like a lot, but this bracket is very thick and durable, and overengineered from the factory. My friend (strength and materials engineer) and I feel it will be safe and have no added vibration.
Old 01-31-2008, 03:45 PM   #19
newby_j
Needs More Cowbell
newby_j's Avatar
How are the redrilled rotors in the picture 4-lug on the oe holes. I thought that the prelude rotors were 5-lug
H2B CRV Build
Old 01-31-2008, 05:52 PM   #20
Voodooboy520
Voodooboy520's Avatar
Send a message via AIM to Voodooboy520
Pics!
91 CRX with DOHC ZC
Fs: Road Race Shifters
Voodooboy520 is offline Report Post   Reply With Quote
Old 01-31-2008, 07:10 PM   #21
BrakeExpert
Banned
No your thinkin of the 97 Prelude, the 92-96 were 4x114.3 in bolt pattern, the VTEC model having 11" brakes.
I'll have at least some pics up later tonight when I get home.
Old 02-01-2008, 12:09 PM   #22
akandok
akandok's Avatar
Send a message via MSN to akandok
subscribed
John 3:16
In the works: B20/VTEC - 12.5 CP pistons, eagle rods, S2S2 cams, gears, & Intake manifold, S2k TB, Supertech dual springs and retainers, S200.. etc etc
akandok is offline Report Post   Reply With Quote
Old 02-07-2008, 10:03 AM   #23
1989CivicSi
1989CivicSi's Avatar
Default Re: (akandok)
EFsquad member: 010
1989CivicSi is offline Report Post   Reply With Quote
Old 02-20-2008, 12:20 AM   #24
BrakeExpert
Banned
Default Re: (1989CivicSi)
At last, pics of the brackets are up! Sorry for the wait, I've been really busy. This kit is now for sale.
Old 02-20-2008, 09:56 AM   #25
JDM knowledge
what a cluster FOX...news.
JDM knowledge's Avatar
Send a message via AIM to JDM knowledge Send a message via Yahoo to JDM knowledge Send a message via Skype™ to JDM knowledge
damn im glad i saw this article. should get this stickied if it isnt.
Originally Posted by SneezinCD5 View Post
Your cool, there is no difference. I have had both and noticed nothing different between Mugen and Rota or Konig.
pffff ahahaha waitwhat?
JDM knowledge is offline Report Post   Reply With Quote
Bookmarks
1988, 2005, acura, brake, brakes, crv, crx, diy, dx, honda, hondatech, integra, knuckles, lug, nut, pad, replacement, si, torque
