> Honda Accord (1990 - 2002)
Old 01-27-2008, 10:20 AM   #1
Jim Truett
Jim Truett's Avatar
Default Inside the V6 Automatic Transmission
It's a 1999 V6 Acura CL tranny, but the case and internals are pretty much identical to the Accord V6. It's basically just like a constant mesh manual tranny with hydraulic clutch packs to select the gears. This transmission started slipping badly on a 2nd and 3rd shift. The 2nd gear clutches were worn down to the adhesive that bonds the friction material to the clutch plate. Normal thickness was .079", and these measured in at .055-.050". The standard free play in the clutch packs is between .015"-.045". With six discs worn between .024"-.029", that combined for about .160" total free play, and made the shifts very harsh.
With the end cover removed:
With the mid case removed:
1/2 clutch drum with clutches removed:
Worn 2nd gear clutches:
Installation of new friction and steel:
Never start an argument with an idiot. They will drag you down to their level, then beat you with experience.
Jim Truett is offline Report Post   Reply With Quote
Old 01-27-2008, 02:11 PM   #2
-RedneckDave-
Working
-RedneckDave-'s Avatar
Default Re: Inside the V6 Automatic Transmission (Jim Truett)
This is going right into the FAQ. This is very nice.
"I'm convinced that if Darth Vader drove an Accord, it would be yours." JG Luder
"They're serving breakfast, I guess I should stop drinking"
-RedneckDave- is offline Report Post   Reply With Quote
Old 01-27-2008, 04:41 PM   #3
213374U
213374U's Avatar
Default Re: Inside the V6 Automatic Transmission (-RedneckDave-)
Very brave
Excellent post though
CD Squad Member #052
21337's EF Sedan Build ---> http://www.honda-tech.com/showthread.php?t=2608833
FS/WTB Thread -- http://www.hondamarketplace.com/show....php?t=2622954
213374U is offline Report Post   Reply With Quote
Old 01-27-2008, 04:44 PM   #4
02 accord
02 accord's Avatar
Send a message via AIM to 02 accord
How many miles were on that?
2002 Accord SE 5 speed
Originally Posted by phootbag
You took the engine out to check a leak?
02 accord is offline Report Post   Reply With Quote
Old 01-27-2008, 05:51 PM   #5
Jim Truett
Jim Truett's Avatar
Default Re: Inside the V6 Automatic Transmission (02 accord)
111,561. I would not have gotten much more out of 2nd gear.
Old 01-27-2008, 06:09 PM   #6
YeuEmMaiMai
i got a chuckle for christmas!
YeuEmMaiMai's Avatar
hey did you pull the internal mesh filter when you put that pos back together?
HT common sense krew member #2...The plane WILL FLY club member #3...Jesus is Salvation...Whatever you can think of that is utterly nasty, I can find something that is way worse....and that is true on the Internet
YeuEmMaiMai is offline Report Post   Reply With Quote
Old 01-27-2008, 06:18 PM   #7
Jim Truett
Jim Truett's Avatar
Default Re: Inside the V6 Automatic Transmission (YeuEmMaiMai)
I checked it out. It was suprisingly clean. It's not much of a "filter".
Old 01-27-2008, 06:22 PM   #8
gianinline
gianinline's Avatar
Default Re: Inside the V6 Automatic Transmission (213374U)
Originally Posted by 213374U
Very brave
lol... something with transmission gears and the way they have to be assembled... few people would want to work on that.
CD squad #016
"it is dangerous to be right when the government is wrong" (Voltaire)
gianinline is offline Report Post   Reply With Quote
Old 01-27-2008, 06:33 PM   #9
YeuEmMaiMai
GL with that man I had a 98 LX V6 coupe that ate 3 transmissions within 11K miles........
Old 01-27-2008, 09:42 PM   #10
RS2 FAB
RS2 FAB is offline Report Post   Reply With Quote
Old 01-28-2008, 12:55 AM   #11
djphonics
djphonics's Avatar
Send a message via AIM to djphonics
Default Re: Inside the V6 Automatic Transmission (RS2 FAB)
111k is the life I'd expect to see out of an auto tranny in a Ford, but not a Honda. That's disappointing.
Cool pics though. I would personally be terrified about taking an auto apart. Those babys are complicated.
NEW DESIGNS! ---> CRX T-shirts: http://images.honda-tech.com/set1/smile/emthup.gif
http://www.cafepress.com/djphonics
1990 Accord LX 4 Door
1988 CRX Si, DOHC ZC - Sold (good luck, lil buddy!)
djphonics is offline Report Post   Reply With Quote
Old 02-03-2008, 10:59 AM   #12
Jim Truett
Jim Truett's Avatar
This is the reason I chose to rebuild it myself. When you have someone else do it, you don't know how competent they are. Also, when you get a reman from Honda, there is no way to tell what the original failure was.
My failure was from the previous owner not changing the fluid per the service guidelines.
Old 03-18-2008, 07:57 PM   #13
xci_ed6
xci_ed6's Avatar
Send a message via AIM to xci_ed6
so that was it???? Just dropped in some new 2nd gear discs and steels and slapped 'er back together?
Any other parts that you replaced/noticed/would recommend replacing?
I worked for Honda, but we never open trans cases. Just put the onld one back in the box the new one came from :D
/yourself
xci_ed6 is offline Report Post   Reply With Quote
Old 03-18-2008, 09:14 PM   #14
YeuEmMaiMai
did you inspect the differential bearings.....those things are crappy as can be.......
I am suprised that the internal filter was clean but the 2nd gear clutch pack was toasted......
Old 04-01-2008, 04:32 PM   #15
fleetw00d
fleetw00d's Avatar
Is it only the V6 automatics that have this kind of trouble? Got a friend looking for a 5th-6th generation automatic Accord for his wife. Want to let him know what to avoid.
90 LX 4dr 5 spd 296,000+, 93 LX 4dr 5 spd 105,000
93 EX 2dr auto 151,000 93 LX Wagon auto 150,000
fleetw00d is offline Report Post   Reply With Quote
Old 04-01-2008, 04:37 PM   #16
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: Inside the V6 Automatic Transmission (fleetw00d)
mainly it's the 98-02 V6 auto's IIRC.
TouringAccord is offline Report Post   Reply With Quote
Old 04-01-2008, 08:11 PM   #17
Legendaryyaj
Legendaryyaj's Avatar
Send a message via AIM to Legendaryyaj
Default Re: Inside the V6 Automatic Transmission (TouringAccord)
Avoid the TL's and CL's as well.
Originally Posted by lke2drvgsr
so i lay still pretending to sleep (cuz it woulda just been awkward if i told him to stop..)
Originally Posted by tegsallgood
i had a girlfriend once- i got my sideskirts painted and when she couldnt notice the difference i was offended and shouted " you never notice anything!" and ran away in tears. needless to say we are no longer together.
Originally Posted by ProjectDarkBlack
Take care of business, this is Honda-tech, we dont want excuses, we want RESULTS!
Legendaryyaj is offline Report Post   Reply With Quote
Old 11-14-2008, 12:14 AM   #18
JHern
JHern's Avatar
Thanks for posting these great pics. I have a 2001 Accord V6 with 98k miles. The tranny is not slipping between gears, but the shift from 1st to 2nd gear is a bit sudden (dropping from just above 3000 RPM to 2000 RPM during the shift) when accelerating from a stop. A Honda mechanic told me it is not a problem, and if it were a light would come on (is this true?).
It is not really bothersome, but I am beginning to think that I will have to get a transmission rebuild done on it some day. Frequent fluid changes will probably help prolong its life, I'm guessing. I also need to check that it is shifting at the proper RPMs.
But I'd also like to defend this car. It is really very nice. For us, a little tranny trouble, though considered a major repair, is worth it. Other than that, this car is fantastic. Great acceleration, wonderful ride, and solid construction all-around make this a great auto.
Of course, if things start to look worse, I might sell it before it gets to the point of no return if I ever change my mind on how much I love the car. This model has a great resale value.
JHern is offline Report Post   Reply With Quote
Old 11-14-2008, 09:32 PM   #19
csmiths98AV6
ah yes the good ol j30a1 auto matic tranny. ive had 4 in my accord, just bc of bs and im only supposed to be on 2 but..... yea mine went out at 160k which was really really surprising compared to alot of other accord owners. but yes these trannies are not very strong, and that is awesome that you are rebuilding it yourself
csmiths98AV6 is offline Report Post   Reply With Quote
Old 04-05-2009, 11:50 PM   #20
bsivoljr
1995 Honda Accord
bsivoljr's Avatar
cool man hey how do you know what to look for inside of this gearbox?
More specifically how do you recognize the wear or distinguish it. To a noobs eyes those clutch plates looked normal to me, key word noob but lets not focus on that too much lol. Peace Good stuff
'The engine made me do it'- EviL GeniUs
bsivoljr is offline Report Post   Reply With Quote
Old 05-13-2009, 05:41 PM   #21
tabahop
by the way seizing the opp..my tranny is all burnt out and im rebuilding it as you read this, the other problem i found on this tranny is one of the differential bearings is completely damaged and the carter has a little play with the steady part of the bearing...do you know if there's any method to adjust de free play of the differential?
tabahop is offline Report Post   Reply With Quote
Old 05-14-2009, 04:11 PM   #22
tabahop
by the way...do you reccomend an external cooler?
Bookmarks
2nd, 98, accord, automatic, autonatic, bearing, differential, flush, gear, honda, rebuild, rrans, starts, transmission, troubles, v6
