oil in the intake manifold
Old 01-24-2008, 09:02 PM
tazzsi84's Avatar
Default oil in the intake manifold
ok set up is a ls/vtec 93 ls blk 96 b16 head new rings /valvestem seals oil pump
water pump headgasket all new now i thought it might be the head studs but a
friend told me oil in the IM is a pcv problem we never changed it when building the
motor anyway could that be it cuz its burning alot of oil i took of the headers and
theres oil coming from 1 & 3 cly could it be the pcv please let me now also do i really need that damn pcv box or can i take it off
Old 01-24-2008, 09:30 PM
Juan_Mitosis's Avatar
From what I've read, a pcv valve is less than like $5, so. . . it wouldn't hurt to just try and go for it, change it, and find out if thats it.
Old 01-24-2008, 10:08 PM
tazzsi84's Avatar
Default Re: (Juan_Mitosis)
i would be pissed if thats the prob sumthing so dumb like that but imma get 1 to see if thats the prob cuz my car been sittin in my garage for a long tim cuz of this we havent been able to figue out the prob but imma try that do i get the whole box or just ask for a pcv valve
Old 01-24-2008, 10:47 PM
tougeR's Avatar
Your PCV valve is designed to suck oil vapors from the block into the intake manifold. Eliminate it all together and run a catch can in line to keep things clean and properly vent pressure from your crank case.
Old 02-02-2008, 01:09 PM
tazzsi84's Avatar
i replace the pcv but its still smokoing here r sum pics
heres the new pcv
heres inside my intake
[IMG]http://i83.pho[IMG]
now hers the exaust ports
number1
number 2
number3
number4
Old 02-02-2008, 01:13 PM
Banned
yoffer's Avatar
Number three is looking really nasty. Really should replace the pcv valve.
Old 02-02-2008, 01:22 PM
tazzsi84's Avatar
Default Re: (yoffer)
i did but its still smoking i clened all 4 of the ports then ran it with the new pcv then took of the headers n these r the pics after i ran it still burning oil
Old 02-02-2008, 01:41 PM
97Ej6mike's Avatar
Run some seafoam thru there to get it all cleaned out. Once its cleaned out, it may give you a better view of where its coming from.
Old 02-02-2008, 07:52 PM
allmotor ls's Avatar
Default Re: (97Ej6mike)
do you have any headgasket oil leaks also is there's any oil on your spark plugs
Old 02-02-2008, 08:25 PM
Civic9390's Avatar
Default Re: (tazzsi84)
You say it's still smoking?? Out of the intake manifold??? If it is check your Timing it must be off...
Old 02-02-2008, 11:02 PM
boosted_dc2's Avatar
Default Re: (Civic9390)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic9390 &raquo;</TD></TR><TR><TD CLASS="quote">You say it's still smoking?? Out of the intake manifold??? If it is check your Timing it must be off...</TD></TR></TABLE>
dont listen to this guy he has no clue what hes talking about. there is something wrong with your pcv system. its not just the valve, theres more to it than that. its smoking because its burning oil from the intake manifold.
oil out of your exhaust ports can be alot of things, blowby the rings, valve seals etc. you need to figure out where the oil is coming from. do a compression test, and leakdown test to see.
Landon
Old 02-02-2008, 11:28 PM
highrev1987's Avatar
Default Re: (boosted_dc2)
disconnect all the lines that are for the pcv and run the car, i had the same problem with mine so i ran a catch can, same thing, Rebuilt motor smoked like MAD, but now not a drop
Old 02-03-2008, 12:03 AM
StorminMatt's Avatar
Default Re: oil in the intake manifold (tazzsi84)
Youcould try replacing the PCV valve. But otherwise, excessive amounts ofoil in the PCV system is a sign of excessive blowby forcing oil mist in the crankcase throught the PCV system, and into the intake manifold.
Old 02-03-2008, 05:12 AM
APCforthewin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
dont listen to this guy he has no clue what hes talking about.</TD></TR></TABLE>
Touche sir. lol
Old 02-03-2008, 10:22 AM
tazzsi84's Avatar
im gonna replace the headgasket n the headstuds to see wat happens cuz i dont think its the rings or valvestem seals there all new
Old 02-03-2008, 11:23 AM
well its not the headgasket either, but dont listen to any of us and go spend time and money on something you dont need to do if you want.
i love when people ask for help, you tell them what to do and then they continue to do what they think is right.
good luck chief!!!
Landon
Old 02-03-2008, 11:42 AM
civicxpress's Avatar
pvc all tha way baby
Old 02-07-2008, 04:54 PM
tazzsi84's Avatar
Default Re: (civicxpress)
so i should eliminate the pcv system? and yes the num 1 and num 3 spark plugs have oil num 3 the most
Old 02-07-2008, 05:18 PM
ekBlackHatch's Avatar
i just pulled off my tb cause im sending it out to get bored (motors not in car btw) and i noticed the same problem i have alot of oil in the tb and a shat load more in the intake manifold. hmmm makes me wonder if i need to replace the pvc valve wtf y not they cheap but what about a catch can how does that work exactly and it elimanates the pvc? sorry if these are stupid questions
Old 02-08-2008, 06:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tazzsi84 &raquo;</TD></TR><TR><TD CLASS="quote">so i should eliminate the pcv system? and yes the num 1 and num 3 spark plugs have oil num 3 the most</TD></TR></TABLE>
i would do a compression test and see if you getting lower numbers in #1 and #3. if you are then its probably rings. if not then you need to evaluate your pcv system. eliminating it and installing a catch can is an easy way to be sure it will function properly.
but if it is noticably differnt in 2 of the 4 cylinders, then its probably NOT your pcv system
Landon
Old 02-08-2008, 07:20 PM
tazzsi84's Avatar
did a compresion test good numbers all across im trying to get a leakdown test see wuts up cuz its geting me mad
Old 02-08-2008, 07:25 PM
Zaraki's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tazzsi84 &raquo;</TD></TR><TR><TD CLASS="quote">did a compresion test good numbers all across im trying to get a leakdown test see wuts up cuz its geting me mad</TD></TR></TABLE>
Do a leakdown and report back.
Old 02-08-2008, 07:30 PM
Datphan's Avatar
Default Re: (Zaraki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaraki &raquo;</TD></TR><TR><TD CLASS="quote">
Do a leakdown and report back. </TD></TR></TABLE>
agree. you should do a cylinder leakage test. im highly leaning towards your piston rings. did you install it correctly?
gwiffer
11-13-2022 06:20 PM
qais_vtec
10-08-2018 12:21 AM
SIR_APPROVED
02-22-2010 10:21 PM
The Lobster
04-27-2005 01:26 PM
andrew dc
05-04-2003 07:06 AM
Quick Reply: oil in the intake manifold
