> Honda S2000
Old 01-23-2008, 06:38 PM   #26
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
Send a message via AIM to HondaKyle
Default Re: Turbo S with and without HG.. have some questions (papa5murf)
papa
Random Hero.
Originally Posted by i drive a honda View Post
you got the s2k becuase you can't afford a z3 right?
HondaKyle is offline Report Post   Reply With Quote
Old 01-23-2008, 07:49 PM   #27
LeGeND4LiFe
Send a message via AIM to LeGeND4LiFe
Default Re: Turbo S with and without HG.. have some questions (HondaKyle)
It's a good question...with a thicker headgasket, in addition to having to run more boost to make the same power, other factors come into play.
I've heard running a thicker headgasket to reduce compression also reduces the oem designed squish area in the combustion chamber, which is important in promoting efficient "fast-burn" combustion characteristics and thus preventing detonation.
Would be nice to get an experienced tuner's thoughts on the subject.
LeGeND4LiFe is offline Report Post   Reply With Quote
Old 01-24-2008, 02:59 AM   #28
Knightsport
There can be only one
Knightsport's Avatar
Default Re: Turbo S with and without HG.. have some questions (Agent Zero)
You can run a given pressure level with a given compression ratio if you pay attention to your AFR's. You just want to make sure it stays Stoich.
As societies grow decadent, the language grows decadent, too. Words are used to disguise, not to illuminate, action: you liberate a city by destroying it. Words are to confuse, so that at election time people will solemnly vote against their own interests.-Vidal
Knightsport is offline Report Post   Reply With Quote
Old 01-24-2008, 09:25 AM   #29
LeGeND4LiFe
Default Re: Turbo S with and without HG.. have some questions (Knightsport)
AFR at stoich in boost would burn up the pistons pretty quick. Tuning safely for high compression and boost have more to do with ignition timing, proper AFR in the 11-12s is a given.
Even then there will be a low margin of error detonation ceiling with a high static compression ratio, pump gas octane fuel, and boost at some point.
Old 01-24-2008, 09:46 AM   #30
fred92htch
fred92htch's Avatar
Default Re: Turbo S with and without HG.. have some questions (LeGeND4LiFe)
So, after reading all the responses, what I'm thinking is leave the stock HG, go low boost, and you don't have to crack the motor open = reliability, given that you get a good tune. This is considering 300 HP or so.
I may never want to go more boost, as a DD. If I do, then I will change the HG at that time.
02 Silver S2k, HKS, Berks, AUT plate
92 Civic dx hatch, JDM b18c, CTR cams, DC 4-1, home made cold air, Skunk2 IM, Apexi WS, Eibach, B&M fpr
93 Civic vx, stock, 69.6 best MPG
01 Pathfinder
fred92htch is offline Report Post   Reply With Quote
Old 01-24-2008, 10:23 AM   #31
Swags04
Swags04's Avatar
Send a message via AIM to Swags04
PSi doesnt really have any relation to hp. Slap a smaller turbo on their and you could run 20psi if you want.
Thicker Headgasket = lowers compression, allowing more horsepower to be made from boost.
*Nikon Equipped*
*00 GPW Honda S2000*
'If it dont make money it dont make cents'
Swags04 is offline Report Post   Reply With Quote
Old 01-24-2008, 10:45 AM   #32
Firstoost
Firstoost's Avatar
Default Re: Turbo S with and without HG.. have some questions (Swags04)
Correct, combustion pressure is related to horsepower. It comes down to the CFM that the turbo can flow to determine the power gains, not PSI. Just look at a turbo flow chart
I run 8.5psi on my gt2871r making 350whp which is fine for me on stock compression and i wouldn't even TRY to push it further. I beleive my car is VERY reliable, but i DO plan to use a 2mm HG to attain my Daily driven 400WHP and still retain the reliability i have now.
for the person starting this thread as it is VERY helpful to others who want to know these answers
GT2871R 2001 S2000 350whp and 236tq @8PSI
VTEC@4200
BERLINA MOB #021
Originally Posted by Grandpa Pralguske
When I'm feeling down, I like to whistle. It makes the neighbor's dog run to
the end of his chain and gag himself.
Firstoost is offline Report Post   Reply With Quote
Old 01-24-2008, 11:04 AM   #33
GetawayInMoscow
Send a message via AIM to GetawayInMoscow
You would be surprised how little difference the headgasket will make in terms of power output at 11:1 vs 9:1.
The headgasket is for peace of mind and to help prevent detonation. But in terms of how much HP you make per lb of boost, it's almost the same.
Evan's tuning has a nice dyno sheet up showing this, maybe I can find it...
GetawayInMoscow is offline Report Post   Reply With Quote
Old 01-24-2008, 01:41 PM   #34
m R g S r
m R g S r's Avatar
Send a message via AIM to m R g S r
Stock motor + e85 + trusted tuner should mean no problems reaching 400whp and DD'ing the car.
Manhattan College Mech. Engineering Student
2002 S2000--485whp pump gas
2009 Si Sedan--DD
m R g S r is offline Report Post   Reply With Quote
Old 01-24-2008, 07:58 PM   #35
GetawayInMoscow
Default Re: Turbo S with and without HG.. have some questions (m R g S r)
Yeah but then you need 1600cc injectors and have to run E85 all the time, which could suck depending on what part of the US you live in
Old 01-25-2008, 03:51 PM   #36
Agent Zero
Agent Zero's Avatar
Send a message via AIM to Agent Zero
Default Re: Turbo S with and without HG.. have some questions (GetawayInMoscow)
Your fuel lines would have be the size of a garden hose. You would be envious of Hummer gas mileage.
Thanks for all the responses everyone.
http://www.postgamepub.com/
Agent Zero is offline Report Post   Reply With Quote
Old 01-25-2008, 05:19 PM   #37
kabaroo
kabaroo's Avatar
ehh i run e85 on my NA motor with 550cc's and i get about the same mileage as i did last season when i was on gas.. I was a bit rich on gas but e85 isnt that bad. Its price for the octane rating more than makes up for any mileage issues which shouldnt matter in building a car like this (to a degree).
kabaroo is offline Report Post   Reply With Quote
Old 01-25-2008, 07:09 PM   #38
Flite
Flite's Avatar
Send a message via AIM to Flite
Lots of misleading information in this thread....
Flite is offline Report Post   Reply With Quote
Old 01-25-2008, 07:13 PM   #39
m R g S r
m R g S r's Avatar
Okay you DONT need 1600's for 400whp on e85.
WTF you talkin about?
Do some research, I was just trying to help and saying you dont NEED a HG, spend the extra time and $$ on a reputable tuner, not some half assed one.
2009 Si Sedan--DD
Old 01-25-2008, 10:14 PM   #40
Agent Zero
Agent Zero's Avatar
Default Re: Turbo S with and without HG.. have some questions (kabaroo)
I was trying to be funny man. sheesh lighten up. didn't you notice the after my post?
Lighten up douchearm....
Old 01-25-2008, 10:16 PM   #41
Agent Zero
Agent Zero's Avatar
Default Re: (Flite)
Ok captain fabulous... please teach us the right way....
Old 01-25-2008, 11:14 PM   #42
Brandon
Life is Suffering
Brandon's Avatar
Send a message via AIM to Brandon
Default Re: (Agent Zero)
To be honest given where you live, you'd be better off just going with low boost and a 2-3mm head gasket. I know it's a little less power but the safety net of not having to have perfect fuel mix is great for peace of mind.
I'd rather be hated for who I am, than loved for who I am not.
XBL- The Way of Stig
We like for everyone to know about the good works we do anonymously. -Jay Leno
Brandon is offline Report Post   Reply With Quote
Old 01-25-2008, 11:15 PM   #43
Agent Zero
Agent Zero's Avatar
Default Re: (Brandon)
Thats most likely what I am gonna do.
Old 01-26-2008, 01:46 AM   #44
GetawayInMoscow
My point is you would need some BIG ASS injectors. Not to mention you have to live in a place that has E85 everywhere. Not to mention E85 SUCKS for everything EXCEPT track use.
Old 01-26-2008, 01:49 AM   #45
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
how about 700CC will be fine
Random Hero.
Old 01-27-2008, 10:25 AM   #46
kabaroo
kabaroo's Avatar
explain please... cuz i disagree mucho!
Old 01-27-2008, 11:13 AM   #47
Francesco
Francesco's Avatar
Send a message via AIM to Francesco
Originally Posted by papa5murf
Here's the deal.
- If you daily drive the car and or are going to drive the car hard. Get the headgasket. (just for piece of mind).
- If you think you're going to want more power in the future, just get the headgasket now, so you can take it up to around 500rwhp without any problems. On stock compression, you're pushing the limits once you hit 380-400 or so mark.
thats basically what it comes down to.
unless you want to do it the right way and custom build a motor to lower the compression that way, but theirs really no need to.
- 05 Amuse s2000.
Facebook!
Francesco is offline Report Post   Reply With Quote
Bookmarks
