> Honda S2000
Old 01-23-2008, 05:18 PM   #1
Agent Zero
Agent Zero's Avatar
Send a message via AIM to Agent Zero
Default Turbo S with and without HG.. have some questions
Something I have been wondering....
For the sake of argument lets say I have a stock motor AP1 and have the Full Race kit ready for install.....
Now before I install a question... If I leave stock compression and run say, 8psi. I should make roughly 330-350whp. (just a guess) Now to get that same whp with a 3mm head gasket I would need about 12-15psi. (just another guess) So if this is the case what benefit would having a HG for reliability when you could get the same HP with less boost? Or am I just smoking crack?
If one of you boost junkies could explain this too me I would appreciate it a ton.
http://www.postgamepub.com/
Agent Zero is offline Report Post   Reply With Quote
Old 01-23-2008, 05:37 PM   #2
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
Send a message via AIM to HondaKyle
Default Re: Turbo S with and without HG.. have some questions (Agent Zero)
Full Race
ive seen s2000s with all stock motors putting down a little over 400WHP
If you baby it im sure it will be fine if you dont drive the piss out of it.
the full race kit is a lot tho you should look into rev hard I would only go with the full race unless your built
Random Hero.
Originally Posted by i drive a honda View Post
you got the s2k becuase you can't afford a z3 right?
HondaKyle is offline Report Post   Reply With Quote
Old 01-23-2008, 05:39 PM   #3
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
Random Hero.
Old 01-23-2008, 05:41 PM   #4
Agent Zero
Agent Zero's Avatar
Default Re: Turbo S with and without HG.. have some questions (HondaKyle)
Originally Posted by HondaKyle
Full Race
The setup was all hypothetical, I am just concerned with boost with HG vs. boost without HG.... I am well aware of what the S is capable of.
Old 01-23-2008, 05:47 PM   #5
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
get a 2MM COMETIC
It Reduces overall compression down to 9.83:1
Here is a link for one
http://automotivespeed.com/pro...d=133
Random Hero.
Old 01-23-2008, 05:50 PM   #6
Agent Zero
Agent Zero's Avatar
get a 2MM COMETIC
Again dude... You fail to see the question. I want to know the true benefit of a HG vs. not having one. Reading > you my friend.
Old 01-23-2008, 05:51 PM   #7
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
It Reduces overall compression down to 9.83:1 lol
Boost doesn't like high comp....and this is stronger then stock all the boost is gonna brake a stock one ......
Random Hero.
Old 01-23-2008, 06:04 PM   #8
papa5murf
papa5murf's Avatar
Send a message via AIM to papa5murf
Here's the deal.
- If you daily drive the car and or are going to drive the car hard. Get the headgasket. (just for piece of mind).
- If you think you're going to want more power in the future, just get the headgasket now, so you can take it up to around 500rwhp without any problems. On stock compression, you're pushing the limits once you hit 380-400 or so mark.
papa5murf is offline Report Post   Reply With Quote
Old 01-23-2008, 06:07 PM   #9
Agent Zero
Agent Zero's Avatar
Default Re: Turbo S with and without HG.. have some questions (papa5murf)
Originally Posted by papa5murf
Here's the deal.
Noted...
So am I accurate when I say that you get close to the same HP with less boost stock compression. Than say more boost less compression? Sorry, just having a hard time understanding.
Old 01-23-2008, 06:08 PM   #10
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
thanx papa!
What about the stock clutch and diff?
Random Hero.
Old 01-23-2008, 06:09 PM   #11
Agent Zero
Agent Zero's Avatar
What about the stock clutch?
Not a chance man. Hell, even I know that.
Old 01-23-2008, 06:13 PM   #12
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
just for like 8 pounds of boost ??!?!!?
Random Hero.
Old 01-23-2008, 06:14 PM   #13
Agent Zero
Agent Zero's Avatar
It wont last man. The stock clutch is not that strong.
Old 01-23-2008, 06:18 PM   #14
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
that really pisses me off ..... its hardly any power wanna buy an s2000?
Random Hero.
Old 01-23-2008, 06:20 PM   #15
Agent Zero
Agent Zero's Avatar
LOL.. I would but I already have one.
Old 01-23-2008, 06:20 PM   #16
papa5murf
papa5murf's Avatar
Yes
Think about it this way. A Stock S at the flywheel puts out 240hp at the current compression. Now lower that compression on a stock S, you won't be pushing nearly as much power (say for instance 210hp, not fact, just hypothetical number). That means you have to compensate for that extra 30 hp loss by boosting more to achieve the same power. Make sense?
Old 01-23-2008, 06:23 PM   #17
papa5murf
papa5murf's Avatar
thanx papa!
Depends on how much power you're putting down. Torque wise. I'm pushing in the area of 400rwhp/300wtq, and I'm using my stock diff. So far so good. As for the clutch, I swapped it out to a Spec Stage 1. People might think it's weak cause it's a stage 1, however, this stage 1 holds up to around 320wtq, which is more than I'm pushing.
I feel it's useless to get a stage 5 clutch that holds 500wtq if you're never going to achieve that number. It's just taking things overboard.
Old 01-23-2008, 06:24 PM   #18
papa5murf
papa5murf's Avatar
It'll work, but it won't last you too long.
Old 01-23-2008, 06:29 PM   #19
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
I just need it to last for the summer and It wont be my DD
So ill just hope it will last 4 months
Random Hero.
Old 01-23-2008, 06:31 PM   #20
Agent Zero
Agent Zero's Avatar
Make sense?
I think so. So running 8psi and pushing 300whp(stock) and (same motor) running 13psi pushing 300whp(with head gasket) = same reliability?
Again man, sorry for the redundancy I just wanna be really clear on this before I begin my build.
Old 01-23-2008, 06:33 PM   #21
papa5murf
papa5murf's Avatar
Well you also have to think about installation. You'll have to remove half of the turbo kit just so you can swap the clutch out later down the road.
Old 01-23-2008, 06:34 PM   #22
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
Im glad you posted this i was gonna post some asking a couple simpler questions
yeah some thing like that... but you dont wanna go to low with out boost a 3mm on 8 pounds would be bad
Random Hero.
Old 01-23-2008, 06:36 PM   #23
HondaKyle
2000 Honda S2000
HondaKyle's Avatar
thats ok ive got all of next winter to swap that out
Random Hero.
Old 01-23-2008, 06:36 PM   #24
papa5murf
papa5murf's Avatar
You're on the right track with the numbers. As for reliability, it's debatable. Some say yes, others say no. I'm one that says head gasket will increase reliability. One thing for sure though is that the head gasket will give you more potential in the long run (power wise).
Old 01-23-2008, 06:37 PM   #25
Agent Zero
Agent Zero's Avatar
Thanks again man. You have been a great help.
Bookmarks
