Anti-Freeze
Old 01-19-2008, 11:55 AM
Accord1234's Avatar
Default Anti-Freeze
I tried seaching but couldn't find my answer. When I drain my radiator on an 05 Accord, can I just use Prestone or do I gotta buy it from the Honda Dealership? Thanks
Old 01-19-2008, 01:22 PM
My Name is Nobody
MSchu's Avatar
Default Re: Anti-Freeze (Accord1234)
lol...
Old 01-19-2008, 02:34 PM
HondaTechAV6's Avatar
is there a reason you are renewing your coolant? your car uses honda type 2 coolant from teh factory. it doesn't need renewal until 10 years have past.
i'd highly recommend sticking with honda type 2 coolant.
Old 01-19-2008, 03:15 PM
My Name is Nobody
MSchu's Avatar
Default Re: Anti-Freeze (HondaTechAV6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTechAV6 &raquo;</TD></TR><TR><TD CLASS="quote">i'd highly recommend sticking with honda type 2 coolant. </TD></TR></TABLE>
This is a legitimate question... Why is that?
Old 01-19-2008, 05:02 PM
HondaTechAV6Clone's Avatar
Default Re: Anti-Freeze (MSchu)
hey, this is hondatechav6. this 5 post limit per 24 hours is really limiting my ability to help as much as possible. i'm a believer that these forums(i'm a member of hondaaccordforum and superhonda) are a great resource in helping people who feel dealers charge too much. with the right information people can make informed decisions based on the collective information posted in reguards to their questions.
honda type 2 coolant is formulated specificially for all aluminum engines. some antifreeze, although labeled as safe for aluminum engines, is not compatible with hondas aluminum alloy. this is especially prevalent in the elements with clogging heater cores(it's only about 1500 vehicles). the coolant used in certain vin specific elements was contaminated from the factory (although honda does not admit it is at fault) and caused massive corrosion build up in the heater core and radiator. (replacing that heater core means removing the entire dash assembly btw)
most domestic coolants have abrasive silicates and borates which adhere to the water pump seal causing premature seal failure and leakage down the road. this silicate tends to settle and collect in the coolest parts of the cooling system. this causes crud to build up and eventually block coolant passages blocking coolant flow and reducing cooling capability.
borates tend to cause pitting in the cylinder head.
keep in mind silicate inhibitors are difficult to stabilize - this reduces coolant shelf life. silicate was added to coolant for it's aluminum protection characteristics, but long term durability was never tested. other coolants simply don't contain the combination of additives needed for long engine life and water pump seal lubrication.
honda coolant does not use silicate because of the reasons listed above. although it has aluminum corrosion protection characteristics, it is not heathly for coolant seals and breaks down and collects too readily. honda uses an organic corrosion inhibitor instead of silicate. corrosion simply does not occur in the cooling system with honda coolant.
i have first hand proof of this by doing countless t-belt/water pumps and loving the lack of problems with the cooling system. however, when vehicles on their 2nd timing belt come in(after having the first t-belt/water pump done aftermarket) i find leakage from the water pump seal and corrosion build up int he radiator tubing.
if you insist on using aftermarket coolant be sure it does not contain silicate or borates and that it claims it's specifically for all aluminum engines if not honda/acura or import engines only. that will be your best shot at prolonged protection.
any coolant will work, but if you want your cooling system to funtion properly for years to come the best bet is honda type 2.
Old 01-19-2008, 05:13 PM
My Name is Nobody
MSchu's Avatar
Default Re: Anti-Freeze (HondaTechAV6Clone)
so type 2 promotes LONG TERM reliability... make sense because like you have I done countless water pumps, coolant line replacements, and heater core removals.
Old 01-19-2008, 07:07 PM
Accord1234's Avatar
The reason I am changing the fluid is because I have an appointment to have the transmission fluid changed and the dealer suggested to me to change the coolant for 79.99 because my car has 53,000 miles. I would rather just do it myself. Anyways the level on the tank is on the low mark. I guess I'll look for type 2. I gotta keep my car running strong.
Old 01-20-2008, 06:14 AM
My Name is Nobody
MSchu's Avatar
lol... the answer to your question is no, you dont need to use type two, but it is well suggested
Old 01-20-2008, 08:50 AM
exactly, heheh...sounds like i went a little over the top in my reply
anyway, coolant renewal isn't need on your car for 10 years or 120,000 miles for the first time, then every 60k/5 years. but doing it early certainly won't hurt anything!
WuWarrior
10-09-2003 03:27 AM
jbashir
07-12-2003 06:02 AM
BlackDeuceCoupe
34
03-05-2002 03:17 PM
Quick Reply: Anti-Freeze
