#1 | |||||
JDM h22a now running stronger then ever... |
#2 |
was the rod/crank damaged?
#3 |
no... just i knew that the two rod bearings spun over and melted to each other... but the crank and rod looked fine... i might have to check again...
#4 |
If the crank and rod were fine, why are you using an oversized bearing? A bearing that's 0.030" oversized is much, much thicker than the OEM size.
What were the bearing clearances used for reassembly? |
#5 |
well i went to a local import parts shop and they gave me f20 main bearings and b18 rod bearings.. i put them in and it still knocks...so i talked to the honda dealer and the parts manager said i need the exact bearings for the motor...( the matching color and all)... but thats like 300 dollars...
#6 |
You obviously didn't have a factory service manual did you?
So you "rebuilt" the engine and just toss a random set of bearings into the engine without measuring clearances or anything? If so, that engine probably has more problems than just a little knock. ![]() Chances are the crank is toast if you've run it for any amount of time after this "rebuild." $300 for bearings is a tad high, it's probably around $200 or so. I'd have to check. However that $300 is going to be cheap compared to the cost you're going to incur by having to get a new engine. |
#7 | |
did you check bearing clearances? how do you know what sized bearing you needed? |
#8 |
yea but i dont drive the car like that.... i havent driven the car for like 5 months... but the crank seems fine though... that one rod did seem a little bent in when i put the bottom back on the rod... when doing the bearings...
#9 |
Yea i think i need to get the right sized bearings for the engine...(h23) i think i need sized bearings because the rod still knocks after ive changed them....
#10 |
are you serious dude?
the damage done to the crank may not even be visible. I'd say pretty much everything is trashed now a bent rod with a new bearing is just gonna expletive up the bearing and journal even more. |
#11 |
u could have at the least plastigaged everything
#12 |
if it looked bent, did you get the rod checked/check it yourself for straightness?
this whole story seems a bit fishy to me....
"i am currently looking for a h22 engine or a v tech engine. http://images.honda-tech.com/set1/smile/emsmile.gif " -pkolaboy |
#13 |
lol i have a plastgauge now... but it might be to late... i dont noe... i think theres still hope in all this bearing shit... it it comes down to it... ill have to swap...
#14 |
You should plan to get a new shortblock.
#15 |
no man the actual rod isnt bent... just when i went to put the bottom part of the rod back on... it was harder then the others to get back on... so i dont think that the rod is acutlly bent...
#16 |
bent is a general term describing any distortion. When you spin a rod bearing, immense heat is focused onto the rod and journal. Heat causes distortions, especially when a large amount of force is being placed onto that exact area.
the least i would tell you to do is break the block down and have the mains align honed (unless completely screwed) and have the crank journals micropolished along with checking for straighness and runout Gonna need to replace the rod which spun the bearing as well. |
#17 |
did you even do anything the the rod journals?
JDMPowerhouse comming soon! |
#18 |
Master H Technician
this years April's Fools Joke is starting way too early...
If you're into cars you must understand the golden rule: You have 3 words: Fast, Cheap, Reliable... The problem is, you can only choose 2 of them. 89 Prelude Si 642whp 502tq @ 29psi H22a 1/4 mile: 10 sec club 1993 Si H22a |
| Bookmarks |
