Oil pressure gauge install Mechanical
First off this isnt about is I should use a mechanical gauge or electric so keep that out of the post. Its more about gauge installation.
My first question is from what I hear from 117 the threads on the oil pressure switch hole are 1/8 BSPT but everyone else seems to say that its 1/8 BPT. Who is correct here ? Also if it is 1/8 BSPT, from what I understand its very close to the same pitch, so would it benefit me to run a 1/8 NTP tap through the hole ? I would be doing this because it seems like 1/8 NTP to -3AN fittings are much more easily acessable than BSPT pitch.
Also it seems like many people put there gauge right where the oil pressure switch was or they put a Tee in and run both. I have seen writeups saying to run a line to the firewall and then mount the Tee there (done by Endyn). I have also heard to run the gauge from the head not the block. How critical is all this ?
And finally, where did you guage place the gauge in the car ? This is a 5th gen.
Re: Oil pressure gauge install Mechanical (lude98SH)
I removed the stock oil pressure sensor, re-tapped the hole NPT and ran it from right there. The oil light will remain off as soon as you disconnect the wire. Its kind of a pain to tee it of right there anyways since the halfshaft is so close.
Just get oil pressure off the head. There is a 1/8" BSPT plug in the side of the head right under the coil on a 5Gen that you can use.
The stock oil pressure sending unit is indeed 1/8" BSPT.
You can find a 1/8" BSPT to -4 NPT fitting from Pegasus.
Re: (117)
here is what i used i was in the same boat as you and it works great and they have great service http://www.teammfactory.com/pr...aptor
