> Honda CRX / EF Civic
Old 01-02-2008, 10:29 PM   #1
SMOOTHN
SMOOTHN's Avatar
Default My How To: Swap seats in 88-89 EF
Do you want to change the seats in your EF? Many people told me seats were almost impossible to do on EF and suggested getting after market racing seats... I refused to believe seat swaps for EF was not possible... So I gave it a shot and this was my result... NOTE: This was all done on 89 EF hatch DX... Try at own risk...
What you need is:
Donor Seat (in this this project I used Integra seat)
Needle nose pliers
Hog rings
Zip Ties (Suggest something better like metal bands or wire)
razor/box cutter
Take your needle nose and remove the rings holding the seat cover onto the pan on my Civic seat the backrest frame was held on by little metal rings... on the integra there was a zipper you need to grab witht he needle nose pliers the location of the zipper head is pictured....
Here is the Civic seat with the Skin and cushion removed, here you can see how the Civic seat has the bracket coming out of the cushion, im not sure what year they started putting the brackets further apart but it probably would've made this swap easier...
After removing both pans from the seats i did a comparison... there is no way you can make the original bracket fit the 88-89 hatch with out custom fabrication to the interior frame, I opted out of that cause lack of resources to welding...
Get your razor/box cutter and cut a hole where the seat bracket has to come out (guesstimated it)... By guessing though it made the seat a little crooked... Also do not remove the rings from the cushion as I did int he pics... it creates slack in the fabric if you dont fasten it back down correctly and the foam then holds it in place is fragile... You'll see in later pics...
I compared the backrest frames and they are almost identical in shape, which is both a plus and a sigh of relief knowing im on the track... also noticed that the holes for head rests are the same width as the integra head rests so that an extra PLUS++++
After putting the cushion on the the seat pan secure the the skin with zip ties...
Here are pictures of the flaws that I noticed after completion
Here you can see how the head rest are the same and the Integra slide/lock fits perfect...
Here it is bolted down...
Testing stage...
All the way forward
Fully reclined
Passenger View
Ending result...
Modified by SMOOTHN at 12:45 AM 1/3/2008
FOR sale
Custom LED Clusters
Vouches
SMOOTHN is offline Report Post   Reply With Quote
Old 01-03-2008, 06:27 AM   #2
ComeOnKip
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
Send a message via AIM to ComeOnKip
nice write up. some moderator *cough toad cough* should add this to the faqs. it would save on a bazillion how do i make X seats fit in Y car in this forum.
Edit: I hope you reapplied the hog rings and didn't just leave it ziptied......
We all knew what consequences could be with the crew we had at the controls, there's no harbor age for the USA-holes. I doubt there's a benign God to save our souls, cuz no one else is gonna save the USA-holes
ComeOnKip is offline Report Post   Reply With Quote
Old 01-03-2008, 06:50 AM   #3
Red_ED8
Red_ED8's Avatar
Default Re: (ComeOnKip)
Nice write up, I just finished a similar project. Swap the seat skins from my SI seats onto my DX seats. Swapped over driver seat covers onto the passenger side to prolong the life of the bolsters. And I also left it zip tied (hog rings where rusted), but I just cut them short .
My build:
Sohc ZC, chipped Pm6, P29 pistons, Y8 mani, Megan header & test pipe, 2.25 exhaust, 9 lbs flywheel, HF 5th, HX rims and building
Red_ED8 is offline Report Post   Reply With Quote
Old 01-03-2008, 08:32 AM   #4
SMOOTHN
SMOOTHN's Avatar
Ive searched and searched but nobody had a write up like this... could be more detailed but this was just an experiment... I will take more pics when i do the passenger side seat...
Could you snap some pics of your seat swap? Yea my hog rings were pretty bad too... and i dont think all the rings would fit the integra seat skin...
FOR sale
Custom LED Clusters
Vouches
Old 01-03-2008, 08:59 AM   #5
dem0nk1d
dem0nk1d's Avatar
Send a message via AIM to dem0nk1d
what a hot mess that is. i thought all you have to do is swap out pans.
95 EG Civic (R.i.P T-Boned)
89 EF Sedan (Current Project)
"keep a full interior and still be fast!!!! leave the stripped interiors to the real racecars!!!!" -sikefcrx89
"don't be a ricer! keep your bumper support kids, it might save your life." -dem0nk1d
dem0nk1d is offline Report Post   Reply With Quote
Old 01-03-2008, 10:51 AM   #6
Rease3
Rease3's Avatar
Send a message via AIM to Rease3
Default Re: (dem0nk1d)
how shit ima have to go to junkyard and pull teg seats
90 dx hatch
d16z6 swap/vitara/eagles/arp head studs/si trans/greddy knock off bov/Drag manifold w/ external wg/2.5" downpipe/open dumptube/ t3/t4 .63 trim
Rease3 is offline Report Post   Reply With Quote
Old 01-03-2008, 11:15 AM   #7
SMOOTHN
SMOOTHN's Avatar
I thought about that too... but there was something that wouldnt let me do it that way i forgot what it was... lemme go look at the seats again...
FOR sale
Custom LED Clusters
Vouches
Old 01-03-2008, 11:19 AM   #8
SMOOTHN
SMOOTHN's Avatar
Default Re: (Rease3)
yea tegs seats are real comfy...
I think the recline part bolts through the pan and the on the integra the holes are in different locations and wouldn't hold the pan in place...
FOR sale
Custom LED Clusters
Vouches
Old 01-03-2008, 11:26 AM   #9
Loserkidwac
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
Default Re: (SMOOTHN)
Nice, I opted to make custom seat rails when I put CRX Si seats in to my VX...but they aren't perfect, I wonder if this method would have been a little better...
91 CRX SI LS-T "B-Rex"
95 Civic VX R.I.P. 5-20-08
94 Del Sol VX Swapped
03 MSP #596/1750
My "B-Rex" Project Thread
Loserkidwac is offline Report Post   Reply With Quote
Old 01-03-2008, 11:30 AM   #10
SMOOTHN
SMOOTHN's Avatar
Default Re: (Loserkidwac)
i looked at the seats at the junkyard from a crx and it looks like you could just drill hols in the crx brackets to fit the EG rails... thats how i got my 94 prelude seats to fit my EG
FOR sale
Custom LED Clusters
Vouches
Old 01-03-2008, 11:42 AM   #11
Loserkidwac
I though of doing something like that, I drilled out the one side and bolted it to the CRX seat but the CRX seat was actually narrower then the EG seat so I had to make brackets for the inner rail to line up right...but this also cause my seats to sit a little closer to the doors then the originals seats...I might eventually redo them but its just a DD and they are way more comfortable then stock EG seats
03 MSP #596/1750
Old 01-03-2008, 04:34 PM   #12
SMOOTHN
SMOOTHN's Avatar
I think he did put it in the FAQ's i just checked it... Thats pretty cool!!! ... Thanks guys... Glad I could help...
FOR sale
Custom LED Clusters
Vouches
Old 01-03-2008, 05:44 PM   #13
bigrob119
bigrob119's Avatar
Nice writeup.
Although the zipties are ghetto fab, I myself am ghetto fab. This certainly would've helped with my attempt at Teg seats in my old EX sedan, 6 years ago, but now I can go cop some tan Teg seats and save myself and the wife the headache of reupholstering the stockers in my current LX ourselves.
'88 Civic STD hatch - current DD/project ~ '02 Acura 3.2TL - a few bent valves ~ '89 Civic LX - sold ~ '91 Civic EX - sold ~ '89 CR-X Si - sold ~ '88 Civic DX sdn - killed by drunk ~~~ "Power is nothing without control."
bigrob119 is offline Report Post   Reply With Quote
Old 01-03-2008, 06:55 PM   #14
braass91
braass91's Avatar
Default Re: My How To: Swap seats in 88-89 EF (SMOOTHN)
Now that I see what the skeleton of the front seats look like, esp the headrest piece, is it possible to take the headrests hardware and install them on the USDM rear seats, creating a JDMish backseat with headrests? Any clues or has anyone done it before? Thanks
ORIGINAL OWNER ONLY
'91 TAHITIAN GREEN EFer
braass91 is offline Report Post   Reply With Quote
Old 01-03-2008, 09:03 PM   #15
SMOOTHN
SMOOTHN's Avatar
Default Re: My How To: Swap seats in 88-89 EF (braass91)
im sure if you hack it up and have welding done to it it could happen...
FOR sale
Custom LED Clusters
Vouches
Old 01-21-2008, 06:39 PM   #16
THE GAME IS THICK
THE GAME IS THICK's Avatar
Send a message via AIM to THE GAME IS THICK
too lazy to read everyone else's post. will this procedure also work with a 89' CRX?
POWERLINE est. 1993
1995 Honda Civic DX Hatchback | 1999 Acura TL-P | 2006 Suzuki GSXR 1000
THE GAME IS THICK is offline Report Post   Reply With Quote
Old 01-21-2008, 07:04 PM   #17
SMOOTHN
SMOOTHN's Avatar
Default Re: My How To: Swap seats in 88-89 EF (THE GAME IS THICK)
Im sure it could... might be a little different but possible... IMHO
FOR sale
Custom LED Clusters
Vouches
Old 02-10-2008, 11:02 PM   #18
bigdonnyboi
bigdonnyboi's Avatar
Just want to add another FACT. I tried to do the same thing with my 88 std civic seats, which is the same as the above 89 seats, but i tried to swap the 92-93 ls/gs/se/gsr seats into my 88 std hatch, the 92-93 headrest is different than the 94 and up integra, its a bit more wider so it doesn't bolt on the 88 std seat, not sure for the rest of the seats from 89-91 civic/crx, also 90-91 da
Modified by bigdonnyboi at 1:35 AM 2/13/2008
bigdonnyboi is offline Report Post   Reply With Quote
Old 02-11-2008, 04:56 AM   #19
SMOOTHN
SMOOTHN's Avatar
Default Re: My How To: Swap seats in 88-89 EF (bigdonnyboi)
The seat i used was from a 94-01 integra...
FOR sale
Custom LED Clusters
Vouches
Old 02-11-2008, 06:06 AM   #20
HondaHeddie
1991 Honda CRX
HondaHeddie's Avatar
AWESOME THREAD..... THANK YOU
what would be different about a RSX into 91CRX swap?
would these same steps work?
I want to avoid any custom fab work for the same reasons as you SMOOTHN.
BTW, to all that have swapped :
(maybe this question should be a 2 part poll)
In everyones opinion, what is the best seat swap for a 19CRX that needs the least alteration?
(just disassembling the seat and swapping hdwr is not alteration as far as this question goes )
Originally Posted by Speed--Freak View Post
1. Well ,perpetual motion is a reality.
Rice belongs on sushi, NOT Hondas!!!!!
HondaHeddie is offline Report Post   Reply With Quote
Old 02-12-2008, 03:22 PM   #21
SMOOTHN
SMOOTHN's Avatar
Default Re: (HondaHeddie)
The RSX seats are probably harder to do... I wouldn't hack up the seats just to try ... If I really wanted to i could find a way, but the easier the better ... at least thats how i feel about it now... Ive been looking at cars that have out of this world modifications but originality is what i like...
FOR sale
Custom LED Clusters
Vouches
Old 03-02-2008, 09:41 PM   #22
bigdonnyboi
much easier if you just add on the 94-up integra head rest to your civic STD DX. Thats what I did. Same grey colors but different materials. Seats are leather and headrest are cloth. Nice
Old 03-03-2008, 04:22 AM   #23
361 accord
2000 Honda Accord
361 accord's Avatar
Send a message via AIM to 361 accord
can i get some before and after's at like the same angle?
2000 AccordEX-L //CG Squad member #001\\PM to join, all 6th gen accord, cl/tl welcome
Originally Posted by symbolic View Post
I hear GK has an autographed bible.
Originally Posted by George Knighton View Post
Ken Sax (nsxtasy) is older than I am.
361 accord is offline Report Post   Reply With Quote
Old 03-03-2008, 05:57 AM   #24
SMOOTHN
SMOOTHN's Avatar
here is the seat before...
FOR sale
Custom LED Clusters
Vouches
Old 10-05-2008, 05:45 PM   #25
clothespinsman
clothespinsman's Avatar
hey i just swapped 94 integra seats into my 90 crx today after reading this post. all i did was change the bottom cushion over to the crx pan and transferred the top half of the integra seat to the crx pan. it lined right up to my suprise! didn't have to change the padding or anything.
clothespinsman is offline Report Post   Reply With Quote
Bookmarks
88, 8991, 90, civic, crx, ef, game, honda, integra, rear, remove, seat, seats, sedan, swap, swaps
