> Honda CRX / EF Civic
Old 12-11-2007, 01:56 PM   #1
alscrx
alscrx's Avatar
Send a message via AIM to alscrx
Default DIY CRX JDM B16 Vtec solenoid gasket change
Ok well i have noticed oil running down the block near the tranny so i traced it and ended up being under the vtec solenoid. So i ordered the upper gasket and head to solenoid gasket from acura and decided to replace them today. So here we go:
First locate the vtec oil pressure sensor and vtec spool sensor and disconnect carefully.
Then locate all 3 10mm bolts holding on the vtec solenoid to the head.
Use a 6" extension to remove them all and push on the lower radiator hose to remove the rear bolt.
Once all the bolts are removed gently pull off the solenoid, it may be hard to get off but you'll get it.
Plug the 2 holes in the head with the tips of a rag.
This was my dirty little guy after i removed it. I am going to clean it later,you'll see why.
So here is the original JDM gasket.
I used a pick to gently remove the old gasket. It was so brittle it fell apart!
Now look at the top of the solenoid, you will see 3 more 10mm bolts. Remove these to replace the top gasket.
Here is the original JDM top gasket.
This a side by side of the old gasket and new gasket i ordered. Simply oil up the new gasket and replace. Put those 10mm bolts back in snug. You will tighten them once its on the car.
I now cleaned the solenoid since its less chance of water getting in the top part!
I couldn't locate my steam cleaner so i degreased it by hand and toothbrush for now. I will get it better with the steam cleaner later.
Now after its all cleaned, oil and replace the head to solenoid gasket.
Go and bolt it back on. Tighten all 3 10mm bolts slowly in a criss cross patternt. Once they are all snug,tighten them so no oil will leak out. Retighten the 3 10mm bolts for the top gasket nice and tight!
Reconnect the oil pressure switch and vtec solenoid connector and check your oil level.
Start the car and check for any leaks, if none then test drive it and make sure again when you come back that there are no leaks. If there are just tighten those bolts some more like i had to do and now your done
Send me your parts to be POWDER COATED!!
alscrx is offline Report Post   Reply With Quote
Old 12-17-2007, 05:29 PM   #2
mitsuman
mitsuman's Avatar
Send a message via AIM to mitsuman
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (alscrx)
08 ZX6R Special Edition|03 G35|95 Eclipse no more honda
PM me for vouches
My Project
mitsuman is offline Report Post   Reply With Quote
Old 12-17-2007, 05:34 PM   #3
xxnickpxx
xxnickpxx's Avatar
Send a message via AIM to xxnickpxx
how much were the gaskets?
92 LS B18b DA9<traded>
91 Si b16 EF
xxnickpxx is offline Report Post   Reply With Quote
Old 12-17-2007, 07:33 PM   #4
alscrx
alscrx's Avatar
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (xxnickpxx)
I think they were like 20 bucks for both plus shipping
Old 12-17-2007, 10:41 PM   #5
xxnickpxx
xxnickpxx's Avatar
yeah i tried a couple local parts stores, they all say dealer. thats not bad tho. im gunna try to find one cheaper.
91 Si b16 EF
Old 12-18-2007, 06:20 AM   #6
Furyof4
Furyof4's Avatar
Just to add:
If you have an obd-0 b16, make sure you order the vtec solenoid gaskets for a 90-91 nsx. They are the only ones that fit correctly in the older solenoids.
Originally Posted by ONEFASTASIAN View Post
i from japan, u try be lik mai peepole. com to real japan peepole laf at u wite american with slo funi looki car. u rase but u slo like sneil on rode. i fas lik reel japan car
Furyof4 is offline Report Post   Reply With Quote
Old 12-18-2007, 09:20 AM   #7
alscrx
alscrx's Avatar
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (Furyof4)
Both solenoid gaskets are from the 90-91 acura NSX
Old 12-18-2007, 10:11 AM   #8
Furyof4
Furyof4's Avatar
I saw that, I was just adding some more info to the thread.
Old 12-18-2007, 12:03 PM   #9
alscrx
alscrx's Avatar
Yeah thanks, i forgot to mention it.
Old 04-02-2008, 10:22 PM   #10
''Simon''
''Simon'''s Avatar
so is the xsi the same gasket as the sir?
EF sedan squad #167
91 b16 civic sedan
''Simon'' is offline Report Post   Reply With Quote
Old 04-03-2008, 05:08 AM   #11
Furyof4
Furyof4's Avatar
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (''Simon'')
Yes, any obd0 b16.
15825-PR3-005 FILTER ASSY., SPOOL VALVE
36172-PR3-005 FILTER ASSY., SOLENOID
Old 04-03-2008, 09:20 AM   #12
crx_si-r
crx_si-r's Avatar
Send a message via AIM to crx_si-r
i got them for a 95 Del Sol (b16 model) and they only ran me 14 for both and they were in stock. but all vtec solonoids share the same gasket. at least thats what the dealership told me.
crx_si-r is offline Report Post   Reply With Quote
Old 04-03-2008, 10:15 AM   #13
jweeks
jweeks's Avatar
Send a message via AIM to jweeks
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (crx_si-r)
for the obd0 b16 i've heard only the 90 91 nsx ones will work, and that people have tried others and they worked, but not for long.
jweeks is offline Report Post   Reply With Quote
Old 04-03-2008, 02:30 PM   #14
alscrx
alscrx's Avatar
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (jweeks)
You are wrong, They are shaped differently and do indeed rip and leak over time. The only one that fits correct on the JDM b16a is the 90-91 NSX hence the years.
Its the same shape and fits in nice, I had it since i made this post and no more leak down down the tranny
Old 04-04-2008, 10:51 PM   #15
''Simon''
''Simon'''s Avatar
thanks went to acura and orderd them today. $42 for both
EF sedan squad #167
91 b16 civic sedan
Old 04-05-2008, 05:44 AM   #16
ProMotive
ProMotive's Avatar
Send a message via AIM to ProMotive
Mine were easily under $20 when I did them on my B16 CRX. :scratches head:
Need your fenders rolled? Send me a PM
Vouches: cbk0485, seek167, jchrm80, typerman, jay16si, mportracer33, EKLIS, Verbal Intercourse, ICeDoUt, claytonkr05, allmotorjunkbox, pb16b, 6ghatch, Karcepts, Sparkks
ProMotive is offline Report Post   Reply With Quote
Old 04-05-2008, 08:49 PM   #17
''Simon''
''Simon'''s Avatar
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (ProMotiveConcepts)
were did u get yours?
EF sedan squad #167
91 b16 civic sedan
Old 04-05-2008, 09:47 PM   #18
alscrx
alscrx's Avatar
sonsacura
Len is a member on here and works at sonsacura! Pm him or go to their website
Old 07-01-2008, 04:21 PM   #19
mperezkr
anybody know the part number for the top gasket
mperezkr is offline Report Post   Reply With Quote
Old 07-01-2008, 10:30 PM   #20
gringo7718
1991 Honda CRX
gringo7718's Avatar
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (mperezkr)
1988-1991 (XSi) OBD-0 B16 require both vtec solenoid gaskets from a 91 Acura NSX.
Large gasket: #15825-PR3-005
Smaller Upper Gasket: #36172-PR3-005
Modified by gringo7718 at 6:36 AM 7/2/2008
91 CRX B16 J1 trans. Intake, JDM Greddy exhaust, HF front bumper support, 13lb. battery, no A/C.
Tein S-tech/Tokico illuminas. 15x7 Slips Hankook RS-2
gringo7718 is offline Report Post   Reply With Quote
Old 07-01-2008, 10:37 PM   #21
mperezkr
Default Re: DIY CRX JDM B16 Vtec solenoid gasket change (gringo7718)
is this the same for the y8
Old 07-02-2008, 07:24 AM   #22
gringo7718
1991 Honda CRX
gringo7718's Avatar
No.
Old 08-29-2008, 08:00 PM   #23
spooledu24
spooledu24's Avatar
Send a message via AIM to spooledu24
the same thing just happened to me B16A rebuilt with a 2k SI gasket and it ripped after a few months. got the NSX gasket all i can say is it works like butta
HID retrofit club member #0051
spooledu24 is offline Report Post   Reply With Quote
Old 08-30-2008, 04:15 AM   #24
Natural Aspirations
Natural Aspirations's Avatar
Location: Someone once said you can not fix stupid, and I am starting to believe it.
Send a message via AIM to Natural Aspirations
SNAP JDM
Keeping it clean since '04
I hear and I forget. I see and I remember. I do and I understand.
Natural Aspirations is offline Report Post   Reply With Quote
Old 11-25-2008, 04:19 AM   #25
hatchy69
hatchy69's Avatar
Send a message via AIM to hatchy69
So for a OBD1 B16A you would use the 94-97 del sol vtec one or a 99-00 si gasket?
EH Squad Member #85
THC
hatchy69 is offline Report Post   Reply With Quote
Bookmarks
b16, civic, diy, ef, gasket, honda, jdm, leak, number, obd0, part, solenoid, upper, valve, vtec
