#1 | |||||
1995 Honda PreludeJoin Date: Oct 2003
Chris Bolis is a douchebag. He capitalizes on a community's work without giving due credit. ..........Fact: Hondata eBay Paypal Tilton = Wankers My K24 Hybrid Alive as of 18:11 5/26/08, 260whp 210wtq 91 oct tuned |
#2 |
Pirate, just to add.
The pulse width is the raw number of milliseconds that the injector is open, and the duty cycle is just a calculation from that, when you add in rpm. For instance: Say you're at 8000rpm, in a 4 stroke engine, you fire the injector once every 2rpm, so take 8000/2 = 4000; 4000 / 60 = 66.66 rev/s; 1/66.66 = .015s or 15ms per revolution. Now say that you need the injector open for 10ms to get enough fuel in. 10ms/15ms = 66.67% DC Good info, I just noticed the guy on that G23 thread talking about something along these lines. In that light, any duty cycle number you get from an online injector size calculator that is over 100% is just telling you that you need a bigger injector or more pressure. That can exist on paper, but not in the real world. Being over 100% duty cycle means that your injector needs longer than the length of one engine cycle at a given rpm to get enough fuel in. Modified by mgags7 at 2:09 PM 11/21/2007
Matt
#3 |
That's true, you also have to consider that any raw engine RPM has to be divided by 2 for it being a 4 cycle engine. The injector fires once every 720˚ crank rotation, so your 4000 rpm example the actual engine rpm will be 8000rpm / 2.
#4 |
Ahh good call Pirate. I'll edit that in.
Matt
#5 |
Nice one Pirate
Its good to see some good tech here, and good too see someone taking the time to help us noobs out
#6 |
Duty cycle information in Crome tends to be wrong.
That's my 2c. I wish I knew it back in the day, maybe it will help out someone else
#7 | |
Matt
#8 |
Excellent post, cleared up a few questions I had lingering
![]() Definite FAQ material.
Ivan 92 Si, 4th motor http://images.honda-tech.com/set1/smile/emsmilep.gif H23/F22B2 build in progress. fresh rebuild on bottom end. nothing major, just something different. and cheap http://images.honda-tech.com/set1/smile/emthup.gif |
#9 |
I never thought that the cells in the fuel tables of Crome and hondata were ms pulse width values I always thought of the indicated value as arbitrary "fuel values."
*shrug*
#10 |
I think that's the way they're set up. Neptune's numbers are definitely arbitrary values, according to James/HRtuning.
#11 | |
Matt
#12 | |
I found Hondata S200's DC log ok the one time I used it. It did spike to a 100% for no reason though
#13 |
* B A N N E D *
I stand corrected, thank you for the information Pirate. I myself was misinformed to begin with, as I kept reading about the dsm 450's in particular being risky of over working themselves at _hp level. But it does make perfectly good sense than an injector can't be over 100% duty cycle now that I think about it. However you didn't need to bash me or anything titling "how not to look like an idiot" that part I disagree with. The good information is what I'm after, not someone pointing fingers and such when I'm wrong, which is often because I still have alot to learn.
Anyhow, thanks for clearing this up for me. Looks like I'll be sticking with the 450's after all. EDIT: Also, how exactly do you know when it's "time" for bigger injectors as far as upgrading things go? You run so much boost from one setup and are fine on one set of injectors, and then get something bigger and all of a sudden need bigger injectors? Duh, the answer is because you need more fuel at any given point in time, but what exactly determines that? And please don't call me a noob, atleast I'm asking legitimate questions here.
#14 |
added to the faq.
good stuff pirate and matt
#15 |
how do you calculate what your current duty cycle in on your injectors??
Jared -'95 Prelude SE - 13.7 @ 102 Now Rockin G23 Non-VTECCheck out my blog My Flickr Nikon D50 |
#16 |
* B A N N E D *
I'm not giving a direct answer because somehow it'll be wrong and false information, but it's in there towards the top of Pirates first post.
Think open/closed |
#17 |
^no nowhere in his post does it state HOW to calculate what your injectors DC is currently at....
#18 |
you'd need to take the time between engine cycles at a given rpm and divide that by the corresponding pulsewith on your fuel map.
Matt's got it covered in his post where he states 15ms as the time between cycles at 8000 rpm, and 10ms being his pulsewidth = 66.67% duty cycle
-Shawn 12.74@111 All Motor 92 Honda Prelude http://www.roskoracing.com // rosko@roskoracing.com Authorized Skunk2 dealer |
#19 |
ok...so you need a tuning device....
#20 | |
Another thought I just had was, you could most likely use a high-end AC voltmeter to read duty cycle, some of them will actually measure it directly. But, you'd have to multiply the # you get from it by two because it would be measuring duty cycle for all 2 rotations of the engine between injector fires, when the duty cycle we calc is measured over just 1 rotation.
Matt
#21 |
OR the quick and dirty way to just get close would be to use the calculator at RCeng.com. you can backfigure duty cycle by using horsepower, injector size, pressure, brake specific #'s to get a close # if you are just trying to determine where you are at on injector size. obviously just an approximation though.
#22 |
Good info guys. It's nice to see people take the time to share.
#23 | |
* B A N N E D *
#24 |
not exactly sure what you are asking but more power just needs more fuel so when the duty cycle starts to get up around 80% then its time for bigger injectors. an injector can only flow so much in a given amount of time so when thats not enough they just need to be bigger (flow more fuel) so they can flow more fuel in the same amount of time.
the injector calculator on RC's site works really well on determining how big of an injector you will need based off of h.p. goals and #of cylinders and fuel type used.
#25 |
Hey man I am noob to this but you seem to know whats going on so here it goes, I have a 96 lude SRV OBD2, Busted balancer belt got an JDM H22A swapped oil pumps for crank position sensor, everything good there. I have pressure to the fuel rail 34psi, dizzy is fine (spark good) injectors not firing? I have a resistor box on order but not sure if thats the fix? What trips the injectors to fire , I mean how does the ECU know when to send the pulse, Please help!!!
| Bookmarks |
| Tags |
| 91, accord, calculate, cycle, dsm, duty, firing, fuel, injector, injectors, low, normal, pulse, running, width |
