> Forced Induction
Old 12-14-2007, 07:42 PM   #26
Schister66
Man U FTW
Schister66's Avatar
I've said it before...EVERYTHING was the same. The same tuner, the same gear, the same setup, the same timing even....the ONLY difference was the manifold.
Bullseye Powered 1999 GSR
S256 @ 16psi on 9.8:1 LS/VTEC + E85 = 385whp/285wtq
Schister66 is online now Report Post   Reply With Quote
Old 12-14-2007, 07:46 PM   #27
mike@synapse motorsport
H-T Basic Sponsor
mike@synapse motorsport's Avatar
Send a message via AIM to mike@synapse motorsport
Default Re: (Schister66)
Originally Posted by Schister66
Tony, i was disappointed with the slow spool on the topmount, but i assure you that i ONLY switched from a topmount to a SLS Shorty before that comparison. I dont think the spool times are very accurate on that dyno because my current setup spools at ~3800rpm on the street, but was spooling at 4600rpm on the dyno. I dont understand the large discrepensies...i'm just reporting what happened in my instance.
The turbo for both dynos was my GT3255b. The first manifold, the topmount, was a CoreyR topmount. My current manifold is the SLS shorty. Everything else in the setup was left as is....
either that manifold was total crap which is unlikely, or there was an unseen issue with another part of the top mount setup. fire ring missing, boost leak etc...
i honestly dont think a manifold change can make that much of a difference. i saw 0 difference in spool time and power production from my switch, the graphs were pretty much on top of each other. maybe tomorrow if i get some ill post up a graph of my comparisons. even on a top mount it should have spooled that turbo much faster.
mike@synapse motorsport is offline Report Post   Reply With Quote
Old 12-14-2007, 10:17 PM   #28
Chris Tune
Chris Tune's Avatar
Default Re: (mike@synapse motorsport)
i x2 x3 everyone on this... something else was wrong between the changes...
have made the change myself and never had that spectacular difference... but oh well... sometimes sh!t happens
240+ whp all motor or 450+ whp turbo... and thats just for starters.
Originally Posted by DonF’s Agent
First off, youre talking to my guy all wrong. and if you do it again, im going to stab you in the face with a soldering iron.
Chris Tune is offline Report Post   Reply With Quote
Old 12-15-2007, 06:43 AM   #29
gogunkergorilla
gogunkergorilla's Avatar
Default Re: (Chris Tune)
Seems plausible to me. Some of the difference could be conditions such air temp, humidity, coolant temp, oil temp that were not the same in both tests. I'm not surprised though that the short runners spooled a little faster than the runners three times longer. That extra spool yielded gains through the whole powerband.
I still have yet to hear a credible argument of the performance gain of a top mount vs. another type of equal length manifold.
Prelude - 483whp/390wtq @ 16psi - too much power for its own good http://images.honda-tech.com/set1/smile/emsad.gif
VR-4 - 99 conversion, BPU, 16psi http://images.honda-tech.com/set1/smile/emsmile.gif
gogunkergorilla is offline Report Post   Reply With Quote
Old 12-15-2007, 06:48 AM   #30
ls1_datsun
ls1_datsun's Avatar
Default Re: (gogunkergorilla)
A turbo isn't going to make more power because its a topmount, trunk mount or under the dashboard...it doesn't care where it is. Header design is the only thing that matters at the end of the day.
ls1_datsun is offline Report Post   Reply With Quote
Old 12-15-2007, 07:24 AM   #31
SPCBoyles
Default Re: (ls1_datsun)
huh? Weren't we talking about different "header" designs already?
SPCBoyles is offline Report Post   Reply With Quote
Old 12-15-2007, 07:28 AM   #32
ls1_datsun
ls1_datsun's Avatar
Default Re: (SPCBoyles)
Too many people generalize things like:
log<mini ram<ramhorn<topmount
that has no meaning thats all im saying
Old 12-15-2007, 09:00 AM   #33
SPCBoyles
aah....So you're saying the quality of design of the particular manifold, reguardless of the style, is what matters (I think).
Old 12-15-2007, 10:06 AM   #34
Archidictus
Unceasing Measure
1998 Oldsmobile Intrigue
Archidictus's Avatar
Send a message via AIM to Archidictus
You are 100%, completely and totally incorrect. Just like in an NA header, the primary runner length and diameter, the quality and precision with which the collector is implemented and the efficiency of flow are the main characteristics in determining the shape and peak of the power curve with a turbo.
That said, however, there are very few street setups I've seen, worked on or heard of that need anything more than a basic log with good wastegate placement. Unless you're gunning for more than 350whp, it shouldn't matter nearly as much as everyone seems to think it does. A bigger downpipe and exhaust will make more of a difference in a street setup than going from a $170 eBay log to a $1200 Full Race ramhorn at 12psi. I've seen it
But now the summer's dreams are bent like grain against the scythe, and memories of blissful days, they fall like leaves.
Archidictus is offline Report Post   Reply With Quote
Old 12-15-2007, 12:25 PM   #35
ls1_datsun
ls1_datsun's Avatar
Default Re: (Archidictus)
ok i guess you've been around more setups than me...
All im saying is that the key elements in designing a manifold have nothing to do with whether the turbo is up top, down low, etc, etc etc.
You are 100% incorrect if you think there is no difference in a log to a well designed turbo manifold in "street" setups. ..
Old 12-15-2007, 12:34 PM   #36
Boner_Ben
Boner_Ben's Avatar
Send a message via AIM to Boner_Ben
I've made 780whp on my 250 dollar used inlinepro t4 log manifold.
SFWD Civic 9.66@156 retired
www.tempestracing.net
Absolute Pro-Formance.com 410-526-3724
Boner_Ben is offline Report Post   Reply With Quote
Old 12-15-2007, 03:32 PM   #37
ls1_datsun
ls1_datsun's Avatar
Default Re: (Boner_Ben)
I wouldn't consider an inline pro a "log" manifold..
Old 12-15-2007, 03:49 PM   #38
Boner_Ben
Boner_Ben's Avatar
If thats not a log manifold than what is?
Old 12-15-2007, 04:27 PM   #39
ls1_datsun
ls1_datsun's Avatar
A log manifold cylinders 1&4 fire directly into each other and 2&3 into that. Inline pro manifold has an actual merge...
Old 12-15-2007, 05:05 PM   #40
SPCBoyles
I disagree. Ram horn style manifolds are tubular runners routed to a collector. The inline pro is cast stainless steel and there is no collector. It does have "runners", sort of, but "log style" is the closest description you could use for that manifold. Then again, I'm certainly no expert.
Old 12-15-2007, 08:55 PM   #41
RCautoworks
Send a message via AIM to RCautoworks
Its not a log, rather just a cast turbo manifold... thats what I would call it.
Get Tony in here, he loves those dam logs
RCautoworks is offline Report Post   Reply With Quote
Old 12-15-2007, 09:18 PM   #42
SPCBoyles
Default Re: (RCautoworks)
Well we're kind of getting off subject, reguardless of what that mani is called. By the way, RCautoworks, from what I've seen your manifolds are
Old 12-15-2007, 11:24 PM   #43
HiProfile
HiProfile's Avatar
And he's not incorrect - because he's saying he's never seen a street setup that NEEDED a "well designed turbo manifold". People here have shown logs can make MUCH more power than any FWD car can use with street tires. He's also saying an exhaust can do more for making power than a manifold can - and he's right. Look at all the factory turbo forums. A full stainless dp/exhaust costs as much in most cases as a NEW TURBO, yet they upgrade the exhaust first. Subies can do 10's on street tires with a 'bad' manifold - the stock setup pairs the cylinders incorrectly, in terms of interfering exhaust pulses.
BTW the coolest cast mani I've seen is the Greddy/HKS manifold design - it flows like the ssauto mani does, except you're stuck with a T25 flange.
BTW2 I'd guess it was more of an exhaust leak, such as a warped flange. That would explain the slower spool, as well as the slightly reduced power curve everywhere.
1994 Del Slow VTEC - OEM B16A3 - winter beater
1995 Civic EX coupe - turbo D16Z6 - summer beater
1967 Firebird 326 H.O. - SMC 350ci - needs a bigger cam, or turbo...
HiProfile is offline Report Post   Reply With Quote
Old 12-16-2007, 04:42 AM   #44
91jdmhatchback
Send a message via AIM to 91jdmhatchback
Default Re: (HiProfile)
well i will tell you i have seen/worked on/ fixed things on schiters66's car. i can tell you all he did was switch manifolds/dp/dt and went and had it tuned ... THATS IT.
the topmount that was on his car was a cc-fab product and it wasn't that bad besides the wastgate falling off. now i think he just had a bad combo with a long runner manifold and a smallish turbo. and when he switch to a short runner manifold along with his smallish turbo, it just works better in that combination.
cars:
91' crx dx - project RHD
91' civic lx - turbo winter beater
91jdmhatchback is offline Report Post   Reply With Quote
Old 12-16-2007, 06:30 AM   #45
gogunkergorilla
Default Re: (91jdmhatchback)
More misconceptions. You do not match runner lengths with turbos. A good rule of thumb that will optimize any turbo setup is to use a manifold with the shortest and straightest runners possible without compromising wastegate placement or downpipe efficiency. Long runners are detrimental if those conditions can be met otherwise.
Old 12-16-2007, 11:57 PM   #46
91jdmhatchback
so you just said the more complicated version of what i said.
cars:
Old 12-17-2007, 04:55 AM   #47
SPCBoyles
I don't know if it was even any more complicated. It was almost verbatim.
Anyway...so far the only person in this thread that has shown any kind of PROOF to support his theory is Schister66. Everyone else has stated their opinions on the matter, but shown absolutely no evidence to support it. There will apparently be no concession to the top mount having ANY sort of advantage over other manifold styles. It still seems that, in theory, it has advantages over the other manifolds. These theories make all kinds of sense, but with no data to prove these theories to be true, one can only assume that they are total .
Old 12-17-2007, 11:25 AM   #48
Schister66
Man U FTW
Schister66's Avatar
Lets try to keep this discussion professional...
Old 12-17-2007, 12:03 PM   #49
SPCBoyles
hahaha...if I had a fraction of a penny for every unproffessional comment on Honda-Tech, I'd be filthy rich! But I'll try. to me
Old 12-17-2007, 01:36 PM   #50
high_revs
high_revs's Avatar
Send a message via AIM to high_revs
great very informative thread
2005 silverstone S2000
high_revs is offline Report Post   Reply With Quote
Bookmarks
4, bottom, civic, difference, downpipe, full, honda, log, mikes, mini, mount, ramhorn, rsx, top, turbo
