55watt DIGITAL High-Output HID kits, $151 shipped, lifetime warranty!
ONLY $151 SHIPPED! on lowbeam kits! WE GUARANTEE THIS TO BE THE HIGHEST QUALITY HID KIT ON THE MARKET!
No Gimmicks, No gags, No BS!
-These are the brightest HID kits on the market
-These tightest beam pattern of any kit on the market
-A LIFETIME WARRANTY backs the highest quality possible
These exclusive kits feature 55 watt high-output DIGITAL ballasts. At 55 watts of true power, these ballasts will offer more light (30 - 40%) than any other HID kit on the market! Ballasts are 100% digitally controlled, which allows extremely high efficiency, low starting current, and low operation current. This all means super reliability, better longevity, and 100% flawless plug and play operation on all cars, trucks, and other vehicles. Ballasts are waterproof, dustproof, and shakeproof and feature hot-retrike technology to protect already warm bulbs from excessive damage when restarting.
Bulbs featured in these kits are the best among all kit manufacturers, with the least variance available on the market, all within +/- 100 lm (brightness) and +/- 200K CCT (color). Average lifespan rating is 3500 hrs, compare to others of significantly less! Focal points on these bulbs are the best we have ever seen in any other kit, resulting in some of tightest and most uniform beam patterns to come from converted lamps. The resulting beam pattern is UNMATCHED by any other kit we have EVER tested!
All items are brand new, packaged in sturdy aluminum cases for ultra-safe shipping!
CE and UL safety listed, ISO registered manufacturing, E4, E11 TUV mark. All genuine parts are individually serial numbered.
Only the best German proprietary processors, and high quality components from NXP semiconductor, Texus Instruments, International Rectifier, Fairchild Semiconductor are used to obtain the lowest failure rate of any after market ballast in the market to date.
Each kit inlcudes:
- 2x DIGITAL waterproof 55 watt ballasts (Best on the market, <0.05% failure)
- 2x 55 watt HID bulbs (Best on market, <0.16% failure)
- 2x plug and play pigtails for your application
(Bixenon High/Low beam kits include fully integrated plug and play harness)
- mounting hardware
- attractive metal case
- Lifetime warranty on all parts!
Colors available: 2000k*, 3000k*, 4300k, 5000k, 6000k, 8000k, 10,000K*
*Less common bulb types and colors are available by request, some applications have these in stock, some are special order.
Group buys are welcome and encouraged to receive even better pricing!
Things this kit offers that NO OTHER kit can offer you:
1) Brightest output on the market
2) Lifetime Warranty
3) Most precise beam pattern of any kit bulbs
Yes, we will do deals on multiple sets shipped to the same address. We do have 3000k and 2000k for some low beam only applications, it depends on what you need for your vehicle? In some cases, depending on what you need and color you choose it can be made for you if we do not stock it normally.
Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (Rishiras)
We have two choices for H4, the standard is a H/L bixenon kit that has electro-magnetic xenon bulbs to perform both functions. The other option is a single beam version, which I would not recommend for you in your case. The best part is, we do not charge extra for the more sophisticated H/L bixenon kits liek all the other vendors do, same low price!
Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (actek23)
We have been around since early 2004. We previously only provided and worked with OEM equipment because until now there was no real reliable aftermarket parts available out there. We changed that by initiating our own manufacturing, we do not simply rely on the mercy of ultra-cheap manufacturing companies and take whatever we can get like all the other vendors do, we turned the tables to offer a much higher quality.
Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (rsx-ct)
wow... 3 years and still going strong... imma definitely look into your company when i buy my gf's HID kit. thanks!
seriously cant go wrong with lifetime warranty!
Canon Xti ~ Canon 50 1.8 ~ Canon 10-22 ~ Canon 28-135 IS ~ Canon 24-70 2.8 L ~ 70-200 2.8 IS L ~ 430ex + 580ex II
Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (bpr0422)
Yes, they really come in that box!
They are a thin gauge aluminum with a composite laminate layer on the outside for rigidity, and padded inside. The cases do an excellent job to protect the contents in shipment.
Lifetime warranty covers everything? When the ballast/bulb eventually wears out they're replaced free? If so, I'll order 8k H7's soon, that is if you don't carry 10k.
Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (iLood)
Yes, lifetime warranty cover everything except intentional or accidental abuse. Basically you are covered unless they are damaged in an accident.
We have H7 in 8000k and 10,000K
Good to hear. I'll order soon. Are your 8k and 10k basically the same as other are, color wise? 8k being dark blue and 10k being dark blue with a hint of purple.
Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (ef8status)
Yes, we are 100% legitimate, please come by and check out the website, or ask us for some feedback, we would be happy to provide it. On a side note, I don't think you will come across many illegit vendors on these forums as long as you stick the vendor classifieds, we all have to pay to be here.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaMarketPlace.com content, comments, or advertising. HondaMarketPlace.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaMarketPlace.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
