#51 | |||||
My motor doesn't exist. |
#52 |
Just FYI, The problem was the Head Gasket sucked, and it was under torqued, and has been fixed for me, for 24Tein we are unsure of what has caused his repeated failure.
honda EG headbolts ARE re-useable, they are not torque to yield (The don't stretch), they are hardend bolts, just FYI, but I wouldn't recommend re-using them more than once, and definatly not in a custom application such as my build-up where my CR is far higher than stock. ARP studs are far stronger than OEM head bolts, and made life much easier when swapping out the bad headgasket, and they are MORE expensive then OEM head bolts which retail for $7 a piece, while ARP set was $135. You can use a Y8MT IACV, but I didn't have one, so I cut off the metal that was in the way. Yes, 1.5 OBD1 non VTEC Dizzy DEFINATLY FTW Thanks for the info on the Z6/Y8 HG, I was curious if there was a difference. |
#53 | |
My fuel line had a little mounting clip on one side of it, but it didn't give me any trouble mounting to a Y8 Rail. And yes, you cannot use a B7/B8 Rail on a Y8 Intake Manifold due to the diffrent bolt patterns, I'm sure you could drill it out if you really wanted to. |
#54 |
Well, Everything has been ironed out except my low RPM Stutter that worsens after 10-20 min of driving.
Car idles fine and revs freely, Something in my ignition system is funky, or my timing needs to be advanced (More than likely since the head got milled) and the Plug wires are 10.2mm Ebay affair, so I suspect those as well. |
#55 |
Glad to hear yours is running and on the road
24TEN Garage Sale EF/EG Parts and Rims, Click Link: http://www.hondamarketplace.co...65178 Will be jobless after September 18th, 2008 http://images.honda-tech.com/set1/smile/emsmilep.gif |
#56 | |
I suspect my Coil or IAT sensor is the culprit at this point. Purchased a new coil, so I'll post up tonight hopefully with a running car!!! |
#57 |
tune tune tune
00 AP1 Berlina MOB #033 pm7/zc pistons(new) mounted on z6 rods, arp, machined *best offer* |
#58 |
I have a basemap for my setup, tuning won't help me at this point
#59 |
Well, after checking over EVERYTHING I believe I have found out my problem...
Timing. Looks like an Adj. Cam gear is REQUIRED for this setup, and noone can give me a straight answer
#60 |
BUMP! lots of new info!
#61 |
I've been waiting for an update
#62 | |
Why Vtec was pulling fine, while down low it was stuttering, why no matter where I had the cam gear it wouldn't run right why all the fuel/ignition systems work perfectly Looking forward to letting it rip
#63 |
im new to this site so i cant go into the for sale fourms and participate and im very interested in your turbo set up some feedback would be nice like an e mail adress so we could talk about the set up thanks
#64 | |
Here's a pictoral explaination of why you have to use a D15B7/B8 Cam Gear when using a Y8 Head that I yoinked from D-series.org ![]() ![]() |
#65 |
And the IMPORTANT PART for a milled head, Ta-da!:
![]() Going on tonight, gonna play with it till she spins like a top! |
#66 |
So can you NOT use the original d16y8 heads cam gear on say a d15b7 block?
Even if neither have been milled?
88HF...d15b7/d16y8 mini-me 88Si...Still working on that one... 89 CRX Si...194k...Retired |
#67 |
Mini-me's run HARD, especially if u have the set-up my homeboy has: d16y7 block d16z6 head intake headers exhaust, port & polished head and chipped p28 plus EX tranny and stock clutch, this set up is in a 94 eg coupe , beats ls swapped civics all day and ls tegs and i witnessed it beat a teg with a b20 and full bolt ons n clutch by 1 car length
#68 |
great work i love mini me's
my parts for salehttp://www.hondamarketplace.com/zerothread/2310104 90Civic hatch-sold 94Integra RS-sold 90Integra GS-sold 98Civic HX-sold |
#69 |
good write up
a couple bits of info that will be helpful to someone doing this swap... (stock harness) wiring for the vtec oil pressure sensor goes to D6, the vtec solenoid goes to A4 and I got a T splitter for my extra coolant line when I had a Y8/D15b7 mini-me: 99-00 intakes have cold start assist holes that need to be filled. I used JB weld. and those bottom tabs were hitting the IM bracket, prevent ing the IM to line up w/ the head: |
#70 |
did you ever get your timign right?
i have a y7/y8 and i have my dizzy all teh way forward to have it at stock timing. as you i have shit for lower rpm power but great after 4 k. i have an adjustable cam gear also. havent messed with it yet though.
DAP - 15g Greddy kit 257hp/227tq http://www.wvmotorsports.com UltraRare 96-00 ashtray http://www.hondamarketplace.com/showthread.phpt=2542732 |
#71 | |
#72 | |
#73 | |
trsut me my head has been milled and my block has been shaved. sleeved and completely built y7 block, and completely built y8 head. skunk 2 cam gear stage 3 comp cam
#74 |
Yea, if you aren't running an Adj. gear you are gonna be nowhere near right.
#75 |
well i have a y8 head with a d15b.. and i have lag before 5500 rpm.. you think its the 1/2 tooth problem.. and you think a adjustable cam gear will fix this problem? thanks
| Bookmarks |
| Tags |
| 15, block, cam, d15b7, d16y8, dizzy, ecu, gear, head, hp, leg, lines, mini, p05, teeth, y8 |
