> Honda Civic (2001- 2005)
Old 11-08-2007, 04:17 AM   #1
blackKready
blackKready's Avatar
Send a message via AIM to blackKready
Default K20 into EM2.
my k20 em2 transformation , enjoy.
Modified by blackKready at 3:17 PM 10/17/2008
blackKready is offline Report Post   Reply With Quote
Old 11-08-2007, 04:18 AM   #2
blackKready
Default Re: K20 into EM2. (blackKready)
got started tonite , made some good progress. :
whipping out the D , good riddance , lol.
gonzo
dash half out
dash out , lol
cutting a hole from the inside for the RSX wiring harness to enter the cabin , rather the passenger side.
a little tease , little problem , doesnt fit quite perfect , little trimming involved , maybe more , lol , but its going in
story of my life , lol
RSX subframe going on
after power steering line , cables , wiring harness ran in car , blah blah , grabbing the K
finally
not tight or nothing
RSX spindles , brakes , struts , so on. ive retained my civic LCA's , and sway bar.
this is the drivers side cup out of DA style teg , cut away form the chassis , lol. trimmed to rest flush with my chassis when bolted together , fits nice.
cleaning contact points and tacking it in
after half welded in
anyways thats where i stand right now. passenger mount is complete and bolted in and tight. looks great and will do the job fine. more tomorrow guys.
Old 11-08-2007, 04:18 AM   #3
blackKready
FUK YEAH!! , haha. got some more boys. another day done. comming along.
got the dash bolted in tonite , little trimming involved , lol. alot of wiring done. got the drivers side mount fabbed and bolted in. got clutch line made and bled. got front brakes all bled. lots more wiring to do. wiring is pretty much what i have left. shes good to roll.
Old 11-08-2007, 04:19 AM   #4
blackKready
ill pull it out in the spring for that shit. no time now.
we got er done. i got some issues though , but also right now im running it off the civic ecu , which could be causing the problems idk. heres some pics of the almost end result , lol:
type r cluster came today.
i know its a mess still , lol
you can see here , the rsx harness for the wiper motor , brake fluid/clutch fluid low indicator , and cruise control are seperate from the rest. the civic isnt , so i dug out the rsx harness , got rid of the civic harness , relocated my cruise control under the wiper assembly cover and all comming out a rubber grommet.
ahhhh , done finally , lol , sort of. you can see here i took the sensor , whatever it is , maybe you guys can tell me? out of the bottom of the rsx rad , and fabbed an inline place for it. i figured as long as its in coolant it dont matter. also i reused my civic rad so had to get some plumbing fitting to make a line.
now for the problems , maybe you guys can help. car is running in limp mode. idles very high , never checked for vacuum leaks yet. when you first start the car , the tach works and comes up , than 2 seconds it falls to zero and stays there , i dont get that. the coolant gauge wasnt working , once the car was heated up , i turned it off , turned the key back to on , it came up where its supposed to be , than when you start the car , it falls slowly to the bottom , dont get that either , lol. to add , it doesnt always come up either when you turn key on , got an attitude. car wont rev higher than approx 3500 , hard to tell with no tach. the A/C compressor sounds like a dying animal. engine light is on. with the key in on position , the engine light after being lit solid for a long time , will flash 5 times , than continue staying lit. all i can think of right now , tired. any help would be appreciated guys. thanks.
heres a little vid of it running for the first time:
Old 11-08-2007, 04:30 AM   #5
jivi
jivi's Avatar
Send a message via ICQ to jivi Send a message via AIM to jivi
Wow, nice job done there. well lets wait for the guru's to help you out. Matt is on the way i'm sure.
JHMES85361S400683
Made in Japan
S5A1 YAO-NH578
Manf Date: 2000
First batch 7thgen ferio http://images.honda-tech.com/set1/smile/emthup.gif
jivi is offline Report Post   Reply With Quote
Old 11-08-2007, 04:37 AM   #6
imroadk1ll
imroadk1ll's Avatar
well done dude. oh ya one thing u should change ur steering wheel aswell.
04' ES2
95' DC2
w2b: jdm type r rear upper strut bar and stock gs-r intake (must come with bolts)
imroadk1ll is offline Report Post   Reply With Quote
Old 11-08-2007, 04:51 AM   #7
toyomatt84
Sanji
toyomatt84's Avatar
Send a message via AIM to toyomatt84
That would be your Fan Switch. It should be in your radiator, since it measures the coolant temperature in the radiator itself, and turns the Fan(s) on accordingly.
All of those problems (and much more likely, many many more problems) are because of this:
You could very well have destroyed something on your engine. Until you have the proper wiring and ECU for the K, do not attempt to start it again. I can assure you, that you will do severe damage to the engine otherwise.
Other than that, it looks pretty good, and I'd like to see more pictures of your dash.
*free hugs*
IA '10: Midwest Caravan (Click to join us!)
toyomatt84 is offline Report Post   Reply With Quote
Old 11-08-2007, 05:08 AM   #8
blackKready
Default Re: K20 into EM2. (toyomatt84)
ill take some more pics when its aoll cleaned up matt , i love it it looks sweet. as soon as i fond one for a decent price IMROAD , its going on , lol. need a passenger side airbag as well.
matt since you seem to know the K , im still new to the K. hasport as well as 2 other sources told me i could run the civic ecu to get it to honda. i know as well as you , the civic ecu is causing these problems , cause the engine harness is isolated and hasnt been touched so. now i have a question for you matt , a guy on either clubrsx or K20.org told me i could ground a wire off the fuel pump relay , or a wire off the ecu pertaining to fuel pump to bypass immobiliser for now? hes pretty confident in this , says this is how the mugen ecu bypasses it? ever hear of this?
Old 11-08-2007, 05:32 AM   #9
BojeEM2
BojeEM2's Avatar
That is alsome dude. I LOVE that you kept the steering wheel, looks great!!!keep up the good work.It is almost time to kick back and drink an Irish Car Bomb
BojeEM2 is offline Report Post   Reply With Quote
Old 11-08-2007, 05:38 AM   #10
integraa972
integraa972's Avatar
damn that is nice! good job
why don't you just switch to kpro instead of using the stock ecu
94 gsr - sold
91 crx - sold
91 da - sold
integraa972 is offline Report Post   Reply With Quote
Old 11-08-2007, 05:45 AM   #11
toyomatt84
Sanji
toyomatt84's Avatar
You won't be able to run the Civic's ECU, because it's not wired to take the same sensors that the K-series has. The "Flashing" process only eliminates the Immobilizer. You could re-flash a K-series ECU (preferably one relative to your engine), to match the keys coding, but even then it'll only make sure the car starts. It won't ensure proper engine management.
Now, as for the fuel relay bypass trick, I've heard a bunch of horror stories from people who tried this. If you're only looking to use it for a very short time, it would be ok, but I definitely recommend getting a K-pro, or having your ECU re-flashed, to make sure the Immobilizer is disabled. I do not think there is any ECU solution from Mugen for the K-series, so I wouldn't suggest buying anything under that manufacturer just yet, as it may be someone faking the product name.
*free hugs*
Old 11-08-2007, 05:47 AM   #12
blackKready
Default Re: (integraa972)
cause hondata price gouges and wants 1000 bucks for it. we went from 20 bucks worth of radio shack parts to chip OBD1 ecu , to 1000 bucks? lol. maybe some day , but im not paying 1000 bucks. also looking for a serpentine belt that can eliminate A/C if anyone has info on that. ive read that a 2.4 litre dodge belt will work. CMON MATT , HELP ME OUT , haha.
Old 11-08-2007, 05:50 AM   #13
toyomatt84
Sanji
toyomatt84's Avatar
Default Re: (blackKready)
Either way, you're going to want one, simply from the standpoint of tuning and proper engine management. I wouldn't say it's "Price Gouging" as it's the most versatile Engine Management system I've seen, under $3,500. And, being that it's able to handle nitrous, boost, and an endless amount of other features, it's clearly the best choice for an engine swapped vehicle.
*free hugs*
Old 11-08-2007, 07:09 AM   #14
blackKready
Default Re: (toyomatt84)
horror stories as in? what happened to people who done this? i just want to get it to honda without paying for towing. theres 2 wires comming off the ecu for the immob. one is the signal wire , E27. the other is immobiliser fuel pump. i heard you tap into the immo fuel pump wire and ground it and it runs but the key keeps flashing on the dash.
Old 11-08-2007, 10:52 AM   #15
k20whitevic
k20whitevic's Avatar
I have the biggest ****ing problem with this ever! I hate Hasport so much to this day because of the bullshit that they still tell people.
Follow Matt's instructions and you'll be fine.
If you wanted to use and OEM mount, you should have grabbed one from an RSX. It bolts right in, and doesn't look like it was added in. Either way, it looks good.
My Build - HERE
Buy my stuff - HERE
k20whitevic is offline Report Post   Reply With Quote
Old 11-08-2007, 12:11 PM   #16
oddmut
oddmut's Avatar
Send a message via AIM to oddmut
Default Re: K20 into EM2. (k20whitevic)
The RSX dash and center console won't work in a 4 dr huh? it will only swap with a 2 dr right?
oddmut is offline Report Post   Reply With Quote
Old 11-08-2007, 12:26 PM   #17
imroadk1ll
imroadk1ll's Avatar
Default Re: K20 into EM2. (oddmut)
^^u wanna do that on urs huh?
04' ES2
95' DC2
Old 11-08-2007, 12:29 PM   #18
blackKready
i had all the mounts off the rsx , they dont bolt in. not even close. not the side mounts i mean.
man i couldnt tell you if it fits a 4dr. theres no info on this. as far as i researched , im the first person to put an rsx dash into an EM2. if someone could prove me wrong , id love to read info on it as well. how they went about it.
im not sure what you mean about the fuel map not being right matt? i was talking to honda , they are programming the keys , not the ecu. the ecu doesnt actually get programmed , they match my keys with it. thats what they told me. also why you can only have one ecu programmed to your car at a time. so i cant see the fuel/ignition map not being good.
Old 11-08-2007, 01:12 PM   #19
oddmut
oddmut's Avatar
I have to admit, i am very tempted. Also because I like how the RSX head unit faces the driver and not the center. It's more suited for the driver.
yes I would be interested. If i had a second car and some money i'd do a project on it and MAKE it work lol. lot of props for the dash man!
Old 11-08-2007, 05:34 PM   #20
k20whitevic
They do..
My Build - HERE
Buy my stuff - HERE
Old 11-08-2007, 07:43 PM   #21
blackKready
heres some finish pics , more of the dash matt.
how i routed power steering , fits mint.
Old 11-08-2007, 09:13 PM   #22
1llmatic
1llmatic's Avatar
Mugen N1 ECU [37820-XK5-S0N0]
RSX (2002-2006) 2002-2004 Type S, Type R
I had it in my car for 3 years. It makes decent power but nothing compared to kpro tuned results.
Nice work with the swap! I'm really impressed with the dash.
ES1 Civic - Turbo JDM K20a
351whp 273 ft/lbs @ 10psi-T04E/T3 54trim
I-vtec and boost
www.Defcon-Racing.com - My Build Thread
1llmatic is offline Report Post   Reply With Quote
Old 11-08-2007, 09:34 PM   #23
toyomatt84
Sanji
toyomatt84's Avatar
Default Re: K20 into EM2. (1llmatic)
I suppose I should have checked with King Motorsports first, eh?
Anyways, the horror stories I have heard of, are in relation to fuel cutoff as the car is in motion. People have had the fuel pump turn off during driving, and that can cause serious damage to the drivetrain.
PS. I'm really liking the dash, bud. A little more modification and it'll look like it belongs there.
*free hugs*
Old 11-09-2007, 04:52 AM   #24
DGAeveryday
DGAeveryday's Avatar
Send a message via AIM to DGAeveryday
nice build, looks hella complicated!
Hawai'i EM2 Krew http://images.honda-tech.com/set1/smile/embeer.gif
"If you ain't scraping, you ridin' to high!"
DGAeveryday is offline Report Post   Reply With Quote
Old 11-09-2007, 08:04 AM   #25
k24em2
k24em2's Avatar
On a non-turbo car really the only damage that would happen if the fuel pump turned off while driving would be a loss of power...Then the damage would occur as whoever was driving would probably freak out and crash into a post
k24em2 is offline Report Post   Reply With Quote
Bookmarks
37820xk5, civic, cluster, e27, ecu, em2, ep3, es1, ferio, fuel, honda, jhmes85361s400683, jump, k20, k20a, mugen, n1, relay, swapped
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
