> Honda CRX / EF Civic
Old 01-02-2009, 02:55 PM   #26
Slystone
Slystone's Avatar
Default Re: DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes
got DA nuckle kit and no problem at all!
tpisly@hotmail.com
Slystone is offline Report Post   Reply With Quote
Old 01-02-2009, 06:18 PM   #27
cdmef
cdmef's Avatar
Interesting this thread popped up as a different version, just wanted to make sure the INNER tie rods need to be cut when doing an sir swap?
the outers were mentioned being cut above, just wanted to make sure....
Oh also, I can get bearing and balljoint replacements from the 89-91 no abs integras, right?
cdmef is offline Report Post   Reply With Quote
Old 03-04-2009, 04:39 PM   #28
CRX=MC2
1990 Honda CRX
CRX=MC2's Avatar
I drive a 90 crx si, I have a set of Ex knuckles, 92+ legend callipers, 4x100-11" re-drilled rotors! will this setup give me a good big brake kit & will it work on my car? I have not installed yet. Do I have the right suff? Thanks.....
Older Honda cars placed a solid foundation! People seem to forget that fact when they brag about owning newer generation!
CRX=MC2 is offline Report Post   Reply With Quote
Old 03-04-2009, 06:04 PM   #29
CRX Toad
Moderator
CRX Toad's Avatar
That is the setup I run on my track car, and several other CRX's that we have on track. There is no issue and no better bang for the buck.
Hondworks
Need a write up on how to fix your CRX cracked climate control, PM me
CRX Toad is offline Report Post   Reply With Quote
Old 03-30-2009, 12:51 PM   #30
CRX=MC2
1990 Honda CRX
CRX=MC2's Avatar
I ran into a camber issue with my racinghart 17" wheels. I dont know if I want to get the crc ajusting balljoints or an skunk 2 A arm swaped in to fix it! Have any recomendations?
Old 03-30-2009, 01:46 PM   #31
turbo boost
turbo boost's Avatar
why do you guys run the legend stuff? why not just use the teg rotors..and calipers?..or are they smaller then the legend?
404whp @ 17psi
Tuned on crome
11.5@128mph
turbo boost is offline Report Post   Reply With Quote
Old 03-30-2009, 04:07 PM   #32
cdmef
cdmef's Avatar
You can use the legend clipers and rotors to run 11.1" with a bit of work, rather than stock 10.2 integra sized rotors.... along with the caliper being bigger, therefore taking more heat.
A side note, do any of you da knuckle guys run really low? - 1" or more tire tucked - Do you smack you shock towers?
Old 03-30-2009, 04:57 PM   #33
CRX=MC2
1990 Honda CRX
CRX=MC2's Avatar
I think it's going to be ok with good ajust-struts, if you have stock oem ones your a arms would hit like 24-7! And it would only be right, the lower your car rides the greater your risk your gonna run into problems!
Old 03-30-2009, 07:17 PM   #34
Dano2
Dano2's Avatar
Hi guys! keep your DX/Si steering knuckle and use any caliper stamped (16CL16VN) or (17CL16VN) will work too on 9.5" knuckle, this is from S2000 (2003 up), RSX or TSX very easy to install and don't bother to redrill you rotor, use the VW Corrado G60 11" 4X100 with center ring.
You can keep your 15" wheel with this brake setup...and the best part you keep you knuckle.
Dano2 is offline Report Post   Reply With Quote
Old 03-31-2009, 11:01 AM   #35
fireant
fireant's Avatar
Do you know if these work on 15" Enkei RPF1s? Also, what master cylinder or prop valve changes are needed for this?
2000 civic hatchback hypermiler
1991 CRX Si track toy
95 Ford Ranger 3.0 mule
fireant is offline Report Post   Reply With Quote
Old 03-31-2009, 12:02 PM   #36
ricefighter
you got a good brake set up there mang.
is the s2000 caliper two piston like the legend gs? and where can i get the center ring for the vw rotor to fit in my knuckle?
thanks.....
ricefighter is offline Report Post   Reply With Quote
Old 03-31-2009, 09:14 PM   #37
Dano2
Dano2's Avatar
I changed my prop valves (because of my DA rear disk swap) and my master cylinder for a Prelude 88 15/16 for better pressure. I don't know if this setup will fit Enkei RPF1s but i have 15" Rota Slipstream and it's ok! (see pic).
The caliper of the S2k have one piston (but if it's ok for a S2k it's probably ok for my CRX
It's all the same 16CL16VN S2k or not...I realy love the Lego compatibility of Honda/Acura parts...
For the center ring i know you can buy from many good tire store, i have to do some search to give you the exact size (probably 57.1 to 58.1).
I post the size of the center ring soon
Thx
Dano
Old 04-19-2009, 10:48 PM   #38
JOEY F.
JOEY F.'s Avatar
Send a message via AIM to JOEY F.
Wow, that is very interesting that works with DX knuckles. Was there any milling of the caliper brackets when using the S2000 calipers?
www.TUNINGSPL.COM
JOEY F. is offline Report Post   Reply With Quote
Old 04-20-2009, 05:54 AM   #39
xaine
xaine's Avatar
ok, all the post of alignment specs are way!! way off the factory specs.
you know the factory specs are 0 camber 0 toe.
i want specs from a good aligned car before and after
90 Crx Si : b18a1 obd1 swap
92 Lexus Sc300: 2JZ power!!
xaine is offline Report Post   Reply With Quote
Old 04-23-2009, 04:04 PM   #40
flatblack-h22
flatblack-h22's Avatar
Thx
Dano
i have these 16CL16VN calipers and dx knuckles in my hands, now for the center rings size, ahem.
did you have to mill anything? or just trim that front portion
SWED! H2B
flatblack-h22 is offline Report Post   Reply With Quote
Old 04-23-2009, 07:05 PM   #41
redflaredcrx90
redflaredcrx90's Avatar
Send a message via AIM to redflaredcrx90
i have da hubs on my si rex non abs and i got great camber. i found out thur trial and era that the da hub with abs give really bad camber
redflaredcrx90 is offline Report Post   Reply With Quote
Old 06-17-2009, 09:40 AM   #42
tommygee
tommygee's Avatar
Send a message via AIM to tommygee
any more information on the S2000/RSX caliper setup. Is there a special bracket that needs to be made. Any info would be great as I need some new brakes for my car!!
tommygee is offline Report Post   Reply With Quote
Old 06-17-2009, 06:09 PM   #43
tommygee
tommygee's Avatar
cmon guys!! anyone care to enlighten me
Old 08-24-2009, 07:46 AM   #44
WhiteSTi
WhiteSTi's Avatar
I would like to know as well.
WhiteSTi is offline Report Post   Reply With Quote
Old 08-24-2009, 10:37 AM   #45
Clipsed
Clipsed's Avatar
Send a message via AIM to Clipsed
search, there is information on it, I would know, I just read about it a few days ago searching for brake info.
Clipsed is offline Report Post   Reply With Quote
Bookmarks
2000, big, brakes, civic, crx, da, dc, dx, ef, front, honda, integra, knuckle, knuckles, si
