> Honda CRX / EF Civic
Old 11-01-2007, 07:44 AM   #1
CRX Toad
Moderator
CRX Toad's Avatar
Default DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes
Originally Posted by Trakhor
The purpose of this is to show that DA knuckles can be used as opposed to EX knuckles with out any major alignment or suspension issues when doing the 11” brake swap.
It’s important to note that after the initial readings were taken, but before the final alignment was done a upper control arm bolt came loose and therefore the true before and after readings are not known, but since this car is not equipped with adjustable pivots, the change is minor.
The difference between the DA knuckle were noted to be the same as what most people found, about .25-.30 taller, however the steering arm is quite shorter. This should provide a quicker ratio and more effort required to steer the car
The car has not been corner weighted, during this test the ride height was not changed via the coilovers, nor was it checked. With this being said, spending some time to corner weight and level out the car could end up with even better results
The parts I used are as follows;
DA Integra knuckles (Thanks Toad)
DA Integra 290V Booster and M/C
93 Legend Calipers (Brackets milled by DrDisco69)
93 Legend Rotors redrilled to CRX bolt pattern.
Of course this requires 15” wheels
The beginning alignment specs with Si knuckles were
....................LF............RF
Camber____-3.8______-2.3
Caster______3.3______2.9
Toe_______ -0.27_____0.72
After the swap and some tape measure toe adjustments to get back to the alignment shop. Note the steering wheel has been off of center until the final settings were made.
.....................LF........... RF
Camber_____-2.9_____-3.6
Caster_______3.0______2.6
Toe_________-1.11____0.23
These are the final settings that we were able to achieve using the factory adjustments.
Caster______3.0______2.6
Toe_______-0.12_____-0.11
Upon first sight it looks as though the knuckles make the camber all out of whack.
Keep in mind this car had a loose driver side upper control arm as mentioned above between the time the initial specs were taken and the after specs were taken.
If there was a trend of the tall knuckle really throwing off camber curves and such we would see the same trend on both sides of the car. If you notice the values flip flopped from side to side. I suspect that this is due to machining differences between the two knuckles.
This has been a little project that Trakhor, DrDisco69 and myself have been trying to weed out some mis-information that is out there on the interweb. This setup is currently running on Trakhor's Si.
Hondworks
Need a write up on how to fix your CRX cracked climate control, PM me
CRX Toad is offline Report Post   Reply With Quote
Old 11-01-2007, 08:14 AM   #2
IT GUY
IT GUY's Avatar
Default Re: DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes (CRX Toad)
This makes me happy. I was a little worried about my DA knuckes and camber.
IT GUY is offline Report Post   Reply With Quote
Old 11-01-2007, 10:26 AM   #3
90efhatch
90efhatch's Avatar
very nice I was looking into upgrading the front brakes on mine and now I know what I will do. Thanks
90efhatch is offline Report Post   Reply With Quote
Old 11-01-2007, 10:33 AM   #4
Trakhor
Torque Junkie
Trakhor's Avatar
Send a message via AIM to Trakhor
One thing to note here the steering is a little harder to turn when sitting still. This is from the shorter arms on the knuckles. Other than that, the driving feel is the same as stock.
Press F1 for help
Hondaworks http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif
Some people say I'm not right in the head, but I know I'm not left in the head, what does that make me?
I think your a poser, don't like it send me a PM
Trakhor is offline Report Post   Reply With Quote
Old 11-02-2007, 12:34 PM   #5
thevtecnician
thevtecnician's Avatar
Send a message via AIM to thevtecnician
Default Re: DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes (Trakhor)
Great news!
There really was a lot of misconceptions out there about those hubs/knuckles. Its about time someone took the time to actually measure them out. So glad I can keep my da knuckles
Anyone know of a good method of pressing hubs in and out at home?
The lord is the stronghold of my life- of whom shall I fear? when evil men advance against me to devour my flesh, they will stumble and fall.
thevtecnician is offline Report Post   Reply With Quote
Old 11-02-2007, 12:57 PM   #6
Trakhor
Torque Junkie
Trakhor's Avatar
Default Re: DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes (thevtecnician)
If you don't have a press, good luck. chances are something else will get destroyed in the process. I don't know how it is in your region, but you can typically get that done at a machine shop or a really good parts store for cheap....if you know the guy well he might do it for a 6 pack of his favorite brew.
Jason
Press F1 for help
Old 11-02-2007, 01:05 PM   #7
turkishEF
turkishEF's Avatar
....however the steering arm is quite shorter
Would this explain why after i did the Si to DA swap, my wheels were pigeon toed? Meaning pointed out.
We had to spend some time adjusting the endlinks enough just to drive it. A professional alignment is in the works, of course.
turkishEF is offline Report Post   Reply With Quote
Old 11-02-2007, 01:45 PM   #8
Trakhor
Torque Junkie
Trakhor's Avatar
Default Re: DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes (turkishEF)
Bingo, my initial alignment specs were after turning the tierods out 3 turns
Press F1 for help
Old 05-24-2008, 07:17 PM   #9
dannysolis92005
dannysolis92005's Avatar
i just put my Da breaks on today, hows the camber gonna be on them, my car is lowered with eibach prostreet 1.5-1.75
dannysolis92005 is offline Report Post   Reply With Quote
Old 05-24-2008, 11:39 PM   #10
hondahustle
hondahustle's Avatar
Default Re: (dannysolis92005)
Hold up....so what you guys are saying is that the DA knuckles could be used just as good as the EX knuckles?! How would it affect autox or any other driving that relies on turning the wheel? I'm wondering because I really want to autox my hatch and I've been searching high and low for EX knuckles because of hearing that the DA knuckles would be bad for my alignment which would lead to premature tire wear right? But I guess the DAs aren't so bad? Sorry for the rambling people lol.
91 Honda Civic HB
hondahustle is offline Report Post   Reply With Quote
Old 05-25-2008, 10:22 AM   #11
green91
green91's Avatar
Send a message via AIM to green91
I did the same thing a few years ago with before & after alignment sheets with DA knuckles and found similar results. However if you use DA rear trailing arms when doing your rear disc brake conversion it will push the wheel .25-.5 inches outward
green91 is offline Report Post   Reply With Quote
Old 05-25-2008, 01:15 PM   #12
LowFlyin'
1991 Honda Civic
My Garage
LowFlyin''s Avatar
Send a message via AIM to LowFlyin'
I have DA knuckles on my CRX, and the car handles great. I also have Progress coilovers, Skunk2 adjustable UCAs and Innovative's Pro traction bar.
My latest alignment specs are:
Camber: -2.6 -2.6
Caster: 6.0 6.0
Toe: -0.17 -0.17
So, it is possible to achieve a proper alignment after the swap.
Chris
1991 CRX SiR (SCCA Solo II: E-Modified)
1991 Civic Wagon RT4WD
LowFlyin' is offline Report Post   Reply With Quote
Old 10-13-2008, 08:33 PM   #13
crxnatic
crxnatic's Avatar
im sorry what do you mean by brackets milled?????? what do i have to do to the brackets?
crxnatic is offline Report Post   Reply With Quote
Old 10-14-2008, 05:22 AM   #14
CRX Toad
Moderator
CRX Toad's Avatar
Default Re: DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes (crxnatic)
The bracket that goes onto the caliper that attaches the caliper to the knuckle has to be milled. The milling is where the bracket and knuckle meet to move the caliper towards the outside of the car so that everything lines up properly
Hondworks
Old 10-14-2008, 03:57 PM   #15
crxnatic
crxnatic's Avatar
can i do that myself ? and what tool should i use??
Old 10-14-2008, 04:09 PM   #16
DCRB
DCRB's Avatar
Send a message via AIM to DCRB
if you have access to a machine shop or a metal shop at school yes. you need to use a milling machine. this is so you accurately remove the proper amount of metal, and so the edge is flat and level, not hit and miss like a disc grinder.
Build Thread - My 88 ED6
WTB - Two ls meshies, with or with out tires. not four, just two
DCRB is offline Report Post   Reply With Quote
Old 12-31-2008, 12:23 PM   #17
g2_teg_
g2_teg_'s Avatar
does anybody know if the taller knuckle will affect ride height at all?
1991 Acura Integra -- 2000 Honda S2000
-- OEM Honda - Cusco - Tien - ACT --
g2_teg_ is offline Report Post   Reply With Quote
Old 12-31-2008, 01:46 PM   #18
CRX Toad
Moderator
CRX Toad's Avatar
What taller knuckle?
Hondworks
Old 12-31-2008, 01:59 PM   #19
g2_teg_
g2_teg_'s Avatar
the DA knuckle. with it being .25-.30 taller would that change the ride height?
Old 12-31-2008, 09:13 PM   #20
EFRue57
EFRue57's Avatar
Send a message via AIM to EFRue57
Now I know it's been over a year since this thread started but I had a couple of ?'s. Not about the details of your info, but about your title actually. Your title says of course "DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes ". You're aware that Si knuckles and EX knuckles are two different parts, correct? Am I just reading it wrong from how you meant it probably? And also, I see that you posted up the specs on the DA and Si knuckles but where are the specs on the EX knuckles? Or were you just posting up that the DA's could be used, and within factory specs, as opposed to the EX?
Sorry, I know none of this is really important but just wanted to make sure on what I was reading. Thanks.
Originally Posted by BrokeLude View Post
May the lice of 1000 horny homosexual camels infest your nether regions...
EFRue57 is offline Report Post   Reply With Quote
Old 01-01-2009, 05:59 AM   #21
CRX Toad
Moderator
CRX Toad's Avatar
The EX knuckles had the same results as the Si's
Hondworks
Old 01-02-2009, 02:36 AM   #22
zurud
zurud's Avatar
I tried to put da knuckle on my 90 dx sedan. But I got too much toe in that can't be adjusted without cutting the outer tie rod about 1/2."
zurud is offline Report Post   Reply With Quote
Old 01-02-2009, 08:42 AM   #23
jdm_ef9_b16
jdm_ef9_b16's Avatar
Send a message via AIM to jdm_ef9_b16
i put da knuckles on my hatch and had no problems geeting enough to.......
http://s83.photobucket.com/albums/j290/jdm_ef9_sir/ my ef hatch project and best friends crx.
http://speedshoponline.com http://images.honda-tech.com/set1/smile/emthup.gif
http://www.handcraftedracing.com http://images.honda-tech.com/set1/smile/emthup.gif
"No car is ever better. Just some are further progressed" quoted by
jdmboyef9
jdm_ef9_b16 is offline Report Post   Reply With Quote
Old 01-02-2009, 10:44 AM   #24
Tyson
Tyson's Avatar
that is typical of using overseas Si-R or VTi knuckles. not DA knuckles. ive never heard of DA knuckles not fitting properly due to toe adjustment.
odd that you would confuse them. got a pic of the knuckles? wanna sell em?
the extra height is in the upper portion of the knuckle. so it shouldnt affect ride height other than due to the results camber change. which would be minimal.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Old 01-02-2009, 11:28 AM   #25
4drEF
4drEF's Avatar
Like Tyson said, it sounds like you have overseas knuckles.
I did a write up many moons ago (aobut 6 years ago!) showing step-by-step the install of SiR knuckles on my LX sedan. I did have to cut the tie-rod end to get the toe adjustment to dial in. I remember tapping the outer tie-rod (really easy) to gain a few extra threads as well. Never had a problem with them at all.
Wish I could link you to my write-up for the exact length to cut off the tie rod, but it's long gone (had it hosted on Time Warner which I no longer have).
. o 0 0_o 0 o .
4drEF is offline Report Post   Reply With Quote
Bookmarks
2000, big, brakes, civic, crx, da, dc, dx, ef, front, honda, integra, knuckle, knuckles, si
