clutches sprung vs unsprung
Old 10-24-2007, 08:28 AM
NAmodified's Avatar
Default clutches sprung vs unsprung
what is the difference between a sprung clutch and an unsprung clutch?
Old 10-24-2007, 08:37 AM
Darth ModerVader
Padawan's Avatar
Default Re: clutches sprung vs unsprung (NAmodified)
Borrowed from here:
Do I need a sprung or unsprung clutch? Many do not consider this an important issue. A sprung clutch allows it to act similarly to springs on a car. In this fashion, the clutch is “engaged”, slack is taken out of the springs, and then the clutch is fully engaged. The actual amount of travel of these springs in only a few millimeters. The theory is that the springs will dampen the engagement slightly and to soften driveline shock and reduce associated clutch engagement noise. To generalize, sprung clutches are preferred for street use and unsprung clutches are preferred for racing applications.
Old 10-24-2007, 11:22 AM
all-mtr-teg's Avatar
Here's a good read also,
http://www.m24x.com/clutch101.htm
Old 08-01-2011, 01:24 PM
cjh4l22's Avatar
good info.
Mr.Luder
09-18-2007 02:20 PM
preludetospeed
02-17-2007 08:36 AM
W O T
01-24-2005 01:32 PM
vjace
05-24-2004 09:01 AM
Quick Reply: clutches sprung vs unsprung
