#51 | ||||||
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
#52 |
im thinking of turboing my b16a as a daily driver but was wondering how long would it last me if i run it with gsr cams at 12 psi tuned???????? will the stock bottom end give up really fast .........
Modified by 90JDMCIVIC at 2:06 AM 10/29/2007
Quote, originally posted by QUESTOYZ by RHanDy » It's not easy. There are so many different ways to do it. And the only way to do it is to just do it yourself. RIP: Randy Gagan aka QUESTOYZ by RHanDy(11.23.1980 - 07.04.2006) I miss you brotha -------------------------------------------------------------------------------- |
#53 | |
#54 |
Just took my b16 apart on saturday....cracked a sleeve. Good thing I have a friend that is giving me another b16 block. Should be up and running again shortly...
dSoc #38 93' Sol--> Built N Boosted B16A...413whp @ 19psi...:-) www.J-K-Tuning.com & www.innovative-motorworks.com --> get tuned! |
#55 |
man I hope I dont crack a sleeve. This is (hopefully) a one shot deal for me.
If I break an axle or something like that, no big deal, but if I have to rip apart my block, I may just sell everything and get out. |
#56 |
mine did this at only 360whp, but i think i can contribute this to a large boost creap
#57 | |
#58 |
wow
#59 | |
#60 | |
i run 18psi daily on 92oct pump gas stock sleeves with NO blockgaurd or homo shit like that... my tuner said "B16A's dont crack sleeves..." so i trust him
#61 | |
And why dont b16's crack sleeves, how are they different from other b-series sleeves aside from b20's. some motors can make 600hp on stock sleeves and some pop at under 300. Every motor is different, i for one will never turbo a stock sleeved Honda motor ever again. |
#62 | ||
i would count boost spike as a bad tuning cuz it wasnt tuned for that high of boost...or that an unrelated part failed causing a failure of the sleeves... like if you dropped a valve and cracked a sleeve. Quote:
my tuner is one of them, he has a completely stock B18C1 bottom end 450whp... |
#63 |
very nice
my b16a will be boosted soon 300whp here i come :0)
#64 | |
FYI the boost issue was a spike and countered by droping 2psi from the tune once it went to the street, but there is this thing called load, you ever heard of that? most motors see different load on the dyno than on the street. So once you get off HT and get some real first hand expierence then you can attempt to give out some information that has some real knowledge and not just what Jeff evans tells you his shop has done
#65 |
By the way here is a few pics of my setup before I cracked the sleeve...but like I said as soon as I get the new block to the machine shop she should be up and running again shortly there after....
#66 | ||
yeah i over simplify shit sometimes. first hand experience? your ****in kidding me right? i have been doing this for YEARS. i have had MANY MANY turbo setups, on all different kinds of motors... should i also point out that MY PERSONAL car made MORE power than yours ON STOCK SLEEVES along with reving it to 9500rpms?...
#67 | |
#68 | |
#69 |
Oh also what kind of piston to wall clearances are you guys running. I think that might have been one of the reasons my sleeve went...
#70 | |
![]() and intake is of course a Edelbrock VictorX, with the standard flat black treatment... powerband? stock B16 from idle to just before VTEC, and from VTEC on is....hard to describe pulls ****in hard! till about just before the revlimiter where it will break 2-3rd [think 4th too, usually too fast for street ] loose on BFG 225/50-15 DRs
#71 | |
#72 |
thanx yeah if poor tunning is why you crack your sleave then i have not as much worries as i had before...... by the way how much hp and psi would a stock b16 handle before it gives out or run into problems.........
#73 | |
#74 | |
Thanks buddy.
99 Si (boosted) Sold 450whp / 325wtq - 57 trim Stock Sleeves 05 Berlina Black S2k - 509whp / 357wtq - gt30r Stock Motor |
#75 |
I am getting some B17 cams, is there any diff in the B18C cam?
| Bookmarks |
| Tags |
| acl, b16, cams, cp, eagle, gsr, ls, mani, pistons, pr4, ramhorn, rods, s362, sleeves, stock, t4, turbo |
