> Forced Induction
Old 12-21-2008, 08:29 PM   #251
Civic89stdB16
Civic89stdB16's Avatar
Default Re: Post up your turbo B16 and feedback on the smallblock.
were r u all at. this tread cant die. keep it alive.
Civic89stdB16 is offline Report Post   Reply With Quote
Old 12-22-2008, 09:09 AM   #252
anton_
anton_'s Avatar
heres mine.
very low comp, 8,0-1
garrett 57trim itr cams, eagle h-beam wiseco pistons
3" downpipe and exhaust
tuned with neptune, pump gas 20psi daily driven
From Sweden
Crx vtec turbo.
garrett 57trim. itr cams 354WHP
anton_ is offline Report Post   Reply With Quote
Old 12-22-2008, 11:46 PM   #253
blinx9900
blinx9900's Avatar
My LS piston'd b16 is still running strong at 333whp on 91 octane if anybody cares...
ek9.org <--- a place for the ek/ej lovers
[b]FS: Racing Hart C2's 17x7 4x100
otaku squad member #004 http://images.honda-tech.com/set1/smile/emsmile.gif
blinx9900 is offline Report Post   Reply With Quote
Old 12-23-2008, 01:14 AM   #254
Civic89stdB16
thats great. im getting ready to get mine put together. 81.5mm pr4 pistons though. love the cheap reliable setup.
Old 12-23-2008, 01:22 AM   #255
blinx9900
blinx9900's Avatar
Thats exactly what i have 81.5mm pr4's in a b16a block I hope you saw my past threads or at least know that you should grind down your valve reliefs, i am using CTR cams and was hitting my pistons the first time around... being one of the first LS piston'd b16's i had to learn the hard way...
Old 12-23-2008, 02:04 AM   #256
rmcdaniels
rmcdaniels's Avatar
GSR cams should be fine with the stock PR4 reliefs though, right? I need to check my valve-piston clearances, but I heard that I'd be fine -w- B16 or GSR cams, and I have a couple of sets of them sitting around.
Every ship is a minesweeper, once.
rmcdaniels is offline Report Post   Reply With Quote
Old 12-23-2008, 02:16 AM   #257
blinx9900
blinx9900's Avatar
I have yet to see anybody confirm it, i always had ctr cams because i originally had a b16b but changed the block for a b16a.
Not sure if this will help any but this is all the information i have:
my setup:
-b16b head unmilled
-b16a block with oem rods and pr4 pistons 81.5mm
-.50 cometic head gasket
After about 500 miles i pulled the head to do valve guide seals and saw that the valves were hitting the pistons on the intake side ONLY, mind you i still managed 317whp at 15psi with a 57trim t3/t4 and 91 octane.
I had 4 bent valves but i would have NEVER known if i didn't pull the head, it ran so strong. Here are some pics so you can see how much mine were actually hitting:
not too bad, all 8 intake valve reliefs had these dings:
Some careful dremelling:
Problem fixed, car had run great ever since, in fact it never actually ran bad, imo the problem is not the depth of the valve reliefs but the size, i just opened mine up outward more. This is kind of why i think everybody should do it, It's because the LS heads have smaller valves so naturally the relief in the piston will be smaller and cant accommodate the vtec valves, i don't think cam size is the issue here, i hope this helps, good luck.
Old 12-23-2008, 02:19 AM   #258
rmcdaniels
rmcdaniels's Avatar
Yeah, I really should have done that, but the motor's already together. I've got to pull the cam caps to put some cam cap alignment dowels in it anyway, so I'll check my piston-valve clearances when I do that.
Old 12-23-2008, 02:25 AM   #259
blinx9900
blinx9900's Avatar
Well worse case scenario you will have to do what i did, mask everything off and carefully grind the pistons while there still in the car but hopefully you will have no problems
Old 12-23-2008, 06:57 AM   #260
See Are X
stock b16 @ 14psi.
Revhard log mani, t3t4 57trim/63ar, 3" dp/exhaust
teamULTRASPEED
'92 Civic hatch
327whp - 11.6 @ 120mph
See Are X is offline Report Post   Reply With Quote
Old 12-23-2008, 07:51 PM   #261
crxfreak1117
crxfreak1117's Avatar
Send a message via AIM to crxfreak1117
my b16a
golden eagle sleeved/o-ringed block
81.5 je pistons 9.2:1
eagle rods
arp main/head studs
honda head gasket
itr intake manifold
bbk 62mm thottle body
precision 1000's
t3/t4 57 trim
peakboost intercooler
turbonetics cast turbo mani
hks bov
turbonetics evolution wastegate
tuned on crome at 18lbs made 384.1 hp
time for a bigger turbo then goin for WAY MORE!!!
89 crx dx boosted-current...1998 240sx se-current...92 240sx-sold...93 integra-current...88 crx dx-rip (rust)...88 crx hf z6 swap-sold.....95 civic couple-sold
crxfreak1117 is offline Report Post   Reply With Quote
Old 12-24-2008, 06:26 PM   #262
jdm602
jdm602's Avatar
Send a message via AIM to jdm602
Here's my 00' SI.
BONE STOCK B16A2
Peakboost FTW Ramhorn Kit
Garrett T3/T04E 57 Trim
Ramhorn Mani
3" Downpipe
Walbro 255
PTE 880's
E85
Tuned on Crome Pro at 12 psi.
Dyno'd 351whp/240tq uncorrected. SAE 329whp/224tq.
heres the graphs:
SAE:
Uncorrected:
heres the kit:
heres the pics of the setup:
Stock lol.
jdm602 is offline Report Post   Reply With Quote
Old 11-10-2009, 08:49 PM   #263
GEN2 LS
GEN2 LS's Avatar
Send a message via AIM to GEN2 LS
bump from the dead thread!!!!
I thought about coming down to set up a booth and sign autographs but I'm currently down to my last 2 cans of douche repellent and thought that might not be enough to keep everyone there from trying to swing from my nuts.
GEN2 LS is offline Report Post   Reply With Quote
Bookmarks
acl, b16, cams, cp, eagle, gsr, ls, mani, pistons, pr4, ramhorn, rods, s362, sleeves, stock, t4, turbo
