#1 | ||||||
"He that blows the coals in quarrels that he has nothing to do with, has no right to complain if the sparks fly in his face." - Benjamin Franklin Last edited by It Wasn't Me; 09-29-2009 at 05:28 PM. Reason: Merged DIY with opening post. |
#2 |
so my srs light came on today in my 04 civic lx. if the light comes on, that means something is wrong right?
so should i check to see whats up, or just reset it? everything is stock, except suspension and a sub (stock deck, sub hooked up to rear speaker). |
#3 |
if you didn't install anything under the seats or remove the seats w/key in ignition then just go the dealers. they will fix it for free.
Super Non-JDM EM2 | all show, no go | ^_^ |
#4 |
are you sure they will just fix it?
can anyone confirm or add input.
#5 |
dealer only fix for free if its because of the seat belt. bc seat belts have lifetime warranty.
2005 EM2, 1995 DC2 |
#6 |
My SRS came on the second time and from there it not goes off. I try resetting it and still will not go off. Someone told me if the SRS keep coming on then the air bag have to be replace. I don't if this true.
#7 |
How about i took my seats out and my air bag light came on now what?
Is it the same steps someone message me plez
LowNSlowEm2 |
#8 | |
yes, its the same. next time, disconnect your battery before unplugging your seats. i installed rsx seats just fine with no SRS light.
The pleasure of a dream is that it is a fantasy. If it happens then it was never a dream to begin with. Quote:
#9 |
So I dissconected the battery keys out.
Remove seat take off the "buckle assmebly" Plug "buckle assmebly" back in leave it sitting on the floor. Hook batt back up and start. I have a SRS light on? whats the deal. |
#10 |
1990 Honda CivicJoin Date: Dec 2008
is this method the same for all vehicles? i have this problem with a '00gsr, but i disconected the airbag while removing the steering wheel, i dont think the keys were in it at the time though. all i know now is the SRS light wont go away. this is great diy info i appreciate the time spent posting that procedure, thanks
90 civic Si JDM dohc ZC |
#11 |
My Light Came on today, first time ever, I just used the speaker wire trick, and the light stays off now, just went out for a hour drive and the light ever came on, not sure what caused the light to come on in the first place but its off now.
great DIY
2001 Honda Civic DX-G |
#12 |
to add to this, my mom took my car in for the airbag recall a week or so ago and I dont remember what the tech said, but the srs light MIGHT have had something to do with that. My mom had to take the car back a second time for them to take care of it, so i imagine it wasnt as simple as just turning the light off, but it was fixed free of charge
#13 |
I made my own SCS service connector, also known as "SCS short connector." See http://sites.google.com/site/hondalioness/srs
Elle, 91 Civic LX, 93 Civic DX, 03 Civic LX Last edited by honda.lioness; 11-09-2009 at 05:19 PM. |
#14 |
2004 Honda CivicJoin Date: Aug 2008
After having done this to may car before, trying to see the indicator lamp, and pulling the SCS connector from the harness, while being stuck under the steering wheel, I like your idea of being able to comfortably see the lamp while toggling on and off instead of pulling the connector apart.
#15 |
^^ Exactly. I read other reports on this and the warning from the manual that a paper clip is a bad idea because of all the juggling needed in a tight timeframe. I did not think I would be better off with the OEM tool either. Plus I figured I might be needing the tool a lot. So I built the little device above. I am working on a 2003 Civic LX which came to me with the SRS indicator light on but no other signs of an accident or airbag deployment. I messed up resetting the first time because I was trying to read the directions simultaneously. This works poorly given the 4-second windows. The second try I just toggled the switch whenever the SRS indicator light changed from off to on or vice versa, knowing to stop toggling once the light blinked twice. Resetting was a success. After driving ten miles, it has not come on again, so I am hopeful all is well with the SRS system.
Elle, 91 Civic LX, 93 Civic DX, 03 Civic LX |
#16 |
You two have stubby arms or something? I have absolutely no problem holding/viewing the plug while I'm sitting in the driver's seat. Using the SRS connector from this position is extremely easy. You hold the MES plug in your right hand, the SRS connector in your left, slide it on and off while you're watching your SRS indicator on the cluster. Pretty simple.
The speaker wire is a good alternative for most people. You can choose the length, and it's only a matter of connecting/disconnecting bare wire ends. Pretty simple. This method doesn't require a toggle switch, a multimeter, the knowledge of how to use a multimeter, or a trip to salvage wires and pins. I imagine that the paperclip method wouldn't be much harder than using the SRS. If someone has a hard time holding the paperclip without it moving around, or the prongs becoming misaligned due to their grip; you could tape the paperclip to something. Maybe the end of a popsicle stick? The idea is to have the paperclip on some sort of foundation in order to reduce (or eliminate) flex in the paperclip. And to also give the person using it a better handle on the situation. IMO: The toggle switch idea is kinda neat. However, it may be a bit more effort than it's worth for the occasional DIY'er. I think it would be best utilized in a shop-type environment where it would be used on a more regular basis. If someone's having to reset their SRS light so often that it becomes bothersome... maybe they should fix their car! ![]() I like to tinker, though. I may do this just for schitzengiggles.
#17 | |
Elle, 91 Civic LX, 93 Civic DX, 03 Civic LX Last edited by honda.lioness; 11-09-2009 at 05:23 PM. |
#18 |
i just used 2 bits of speaker wire approx 18"'s each length, just looke dright ahead at the light, work first try, had no problems at all.
#19 |
i went to the junkyard and found the speaker wireharness off a 92 prelude cut it off and work just as good
I love the smell of burnt Rice |
#20 |
I just got the warranty work done at the dealership, srs light is still on. The dealership said they were unable to communicate with my ecu. Any Ideas?
01 Lx, 03 rsx-s swap |
#21 |
i simply unplugged the two plugs from under my 05 civic ex 2dr seats and removed both. re-plugged back in and put seats back in. how can i shut the srs light off?
#22 |
You were supposed to disconnect your battery, before you unplugged your seats.
I don't see what the problem is. The DIY has clear, step-by-step instructions. Other people can seem to figure it out.
#23 |
So my light came back on, it was off for about 3-4 since i did the reset, so i took it to a garage, they read the code, its the seat belt buckle itself thats causing the light, anyway Honda wont cover it under warrenty, and they want $230 for the part itself, i got a used one for $50 and i'll install it myself and reset the code myself.
I cant believe such a common problem exists and they wont do anything for you.
| Bookmarks |
| Tags |
| 07paz-001010a, 07paz001010a, 2001, 2005, acura, civic, connector, diy, honda, light, lx, mes, rsx, srs, wont |
