| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Dealer Listings | Garage | Vendor Directory |
#1 | |||||
BK INDUSTRIES - Honda and Acura Specialist |
#2 |
i have the popping noise pulling in and out of parking spots. i assumed it was the bump stop issue. but my car doesn't fall within the vin range. honda wont do anything because i have comptech springs.
ill pull my car in the shop after work and see if i can locate it. |
#3 |
You will of course get some pad shift one time when changing directions, but I would be curious to see if you have the right to left "click".
#4 |
Actually, I had something similar happen in my 06 civic. The sound came from the steering column and wasn't really a clicking sound but a rubbing sound against something like a ribbed vacuum hose. It was really subtle.
I took it in and they had to replace something in the steering column. I can't remember what part it was, but I can look for my paperwork if you want. |
#5 |
I have an '07 Si that makes an odd noise that seems to be coming from the steering column. It is happens more when going up or down hills. It sounds like a geiger counter detecting radiation - weird I know but that's only way I know to describe it.
#6 |
My 06 civic make noises when i turn too
![]() it's coming from the steering column as previously said...
http://www.nonewbs.com |
#7 |
I have had that problem too at the beginning...a clicking noise when you turn?
Definitely from the steering column. my lexus had the same problem when i first bought it used. heard it when test driving after purchase, lexus tech fixed it for free. ![]() msot likely it will be under warranty |
#8 |
UPDATE...
We decided to put a new rack in the car, and it seemed to fix it just fine. Weird for a car with 400mi onit!
#9 |
New rack?
#10 |
Honda fixed mine the other day. I don't recall the specifics but I will look at my invoice when I get home and list exactly what they did.
C Squared- San Diegan and Longhorn por vida. "Friends don't let friends apex early." http://images.honda-tech.com/set1/smile/emsmile.gif |
#11 | |
#12 |
Holy &$*
#13 |
So for my situation, I had the cable reel assembly replaced and the noise disappeared.
#14 |
Well I haven't figured out what the problem is, but I have noticed that when it's making the noise I can apply a little upward or downward pressure on the steering wheel and the noise goes away until I release the pressure. Any ideas?
#15 |
umm, i recently noticed the same problem. It's weird because if only happens like you said (turning the wheel right and then left). I own a 06 Civic SI and it seems that once I drive for a bit, the sound goes away. Any input on this?
#16 |
Was posting on 8th civic and someone gave me a service recall for it. the attachment is at http://www.*************/forums...82916
#17 |
We've seen a number of bad upper strut bearings clicking on 06+07 civics. They'll only do it with the car on the ground. Been replacing the whole strut assembly.
| Bookmarks |
| Tags |
| 2000, 2006, civic, clicking, clicks, hear, honda, left, noise, prelude, rubbing, sound, steering, stop, turning, wheel |
