#2401 | |||||
Sohc Crew |
#2402 |
please read this thread from pg 1
R.I.P Booga aka Shorty (King of NYC) F.D.L.R (For Da Luv of Racing) WHEN THE GREEN LIGHT DROPS THE BULLSHIT STOPS B.I.T.S racing /Midnight Auto |
#2403 | |
Bottle Fed Racer....... |
#2404 | |
I hope your not thinking you need a 100psi to spray 1 stage. Can't you add fuel (increase the injector pulse width) with crome too? Is it a port kit or a nozzle in the intake tube?....doesn't matter, 255 is plenty, it will probably run rich anyway.
#2405 | |
![]() pull your plugs, if they're fine. not melted/exploded/peppered. make a pull and shutdown on top, make pics and then we can make some educated guesses:p also what's your plug gap, ignition setup?
Imma build the 1st european d.d. juice-only 10sec eg coupe progress sofar:12.3@119mph 320whp stock block+streettires Brad Penn supplier of the Dutch import-scene
#2406 |
no i just plan on spraying it...no boost for me.
QUOTE=Transpoquick;40547335]Even with the biggest cam you can get, and a port and match...Yes 255 is plenty, no boost right?, you'll be fine unless you plan to run boost too. I hope your not thinking you need a 100psi to spray 1 stage. Can't you add fuel (increase the injector pulse width) with crome too? Is it a port kit or a nozzle in the intake tube?....doesn't matter, 255 is plenty, it will probably run rich anyway.[/quote]
Sohc Crew |
#2407 |
so watz the best nitrous times. post them up.
#2408 |
Cornfield, your good use the 255, I ran one for awhile, car ran rich, took it out, put it back in, turned down the pressure, still rich, took it out, put.....this isn't sounding good is it?, anyway the car wouldn't run right w/ a 255 untill I put in a 59300 Comp Cam, BUT I'm using a stock ECU, therefore adjusting injectors is not a option.
Long story short I sprayed a 125 port shot for years with the stock pump!, feeding off the rail. If you really want to spray alot of nitrous...a couple stages, say 125 and 250 then your getting into a dedicated fuel system. Use the 255 but I bet you will have to adjust injectors maybe to the point where it seems like your stock ones are too big. What kind of Cam do you have?
Bottle Fed Racer....... Last edited by Transpoquick; 11-07-2009 at 05:59 PM. |
#2409 |
im also running the 59300.
Sohc Crew |
#2410 |
you will be ok zccivicex just take the necessary precautions and make sure the fuel is there.
#2411 |
Nice, another person stuffing American parts in their Honda.
Little bit of modification involved to install that Cam, worth it though IMO.
#2412 |
1999 Acura IntegraJoin Date: Oct 2007
Are you on E85?
HB |
| Bookmarks |
| Tags |
| 82mm, bore, dc2, direct, dpfi, flexible, fogger, honda, jacobs, lines, mastermind, nitrous, port, sleeve, stock |
