***The Official Nitrous Thread***
#2176
re: ***The Official Nitrous Thread***
it depends on how you have it setup.
mine is setup like this:
system armed (ecu and progressive controller now know they gotta pay attention )
parameters met.......interpet.........
and when everything is processed and everything is in check it simultaniously triggers the output (that let's the controller know it's ready for pulsing) and the extra fueling needs
even take the progressive controller out of the equation and the interpeting, processing and responding is done before the relays of the solenoid is activated and the changes in fuel are being made...
#2177
Wolve, in regards to that picture(s) you posted...Is there a WON typical hardline post solenoid, how long is it or how far away from the throttle plate? To me you said #1 was gone and #2 was low, looks like you blew it right past 4-3 caught some in 2 and put most of it in 1?
EDIT: This is also the reason conical pattern dry nozzles were developed.
#2178
i repositioned the nozzle with a normal 90degree nozzle spray pattern in mind, it slipped my mind tough that the WON discharge tube is specifically designed to discharge a as dense as possible to minimize phasechange along the way (perfect for direct port or how it was previous on my setup )
i will display my "fantastic Paint skills" to explain my foolish design flaw:
the top one is a conventional 90 degree conical nozzle that 'everyone' uses (that spray pattern i had in mind with my positioning of the nozzle)
the bottom one is my actual situation wich obviously is far from ideal (stupidstupidstupid)
#2179
combined with the factor that each cilinder is getting the same amount of fuel but obviously not the same amount of nitrous
means wideband showing perfectly good afr's troughout the run but probably running in the 8:1 region at cil4 and 15:1 in cil1 combining a nice 11.5:1 on your wideband
again stupidstupidstupid
a harsh lesson in the following statement:
assumption is the mother of al f*ckups!
#2180
Most 90* nozzles are fan spray actually, only a select few adopted the conical design so far, to my knowledge. I agree, thats the problem with using 1 wideband.
While the car is down maybe you can clean up the wiring and engine bay some friend
#2181
money makes the world go round
if i'd have enough of it my car would have 4 widebands + 4 egts for on the dyno
cleaning up engine bay.........awww....... if i'd only have the time
i'd love to do a wiretuck, but events always come up 'to early' and things need to be done fast and lowlow budget...
daily driving it does not help much
but hea, most people who do take the time to make everything pretty and how they want it, take 3-4 years to completion and by then have to sell it and never drive it. i'd rather drive it
goal for next season is 10's on spray (stock sleeves)
in 2 years the goal is, a sleeper style, full interior, full glass, 'comfortable' and finely detailed 10 sec streetcar on streettires (nitrous only offcourse )
#2182
I meant the Nitrous wiring I see strung out and the used oil bottle as a catch can.
http://www.dynotunenitrous.com/store...?idproduct=145
Only dry Nozzle I see on their page...funny looks IDENTICAL to a NOS fan spray though!
http://www.harrisspeedworks.com/prod...&cat=10&page=1
Thats more of a conical design, just missing the draft angle on the discharge. I am sure more people are doing it now, just 5 years ago though you'd be hard pressed to find anything but a 90* fan.
You just described my car in the last sentence.
#2183
the one my mate got in (dynotune)has the same shape and layout as the harrisspeedworks kit only blue with the same pointy head
the harrisspeedworks has a very nice bowly spraypattern
very nice, i like that, share pics
picture my car in two as a stock black ej2 just how it came rolling out of the factory on 14" si rims and lowered...these are the only hints people are gonna get.
#2184
Be hard to run 10's on a 225 DR in FWD, let alone street tires! How do you plan to manage that or do you not plan to run the car on a radial?
#2185
i have a h22 type s pistons my wide band read when the throttle body is open 12.9-13.4 but i want to know what is the read (safe) when i push the botton for the nitrous i have 50 shots wet system
#2186
I got a question for the "nitrous experts". Which b series head is better for nitrous, GSR with the smaller chambers or b16/type r?
#2187
depending on your tune 1-2degree retard on pump gas
your name indicates you prob have a GSR, it's fine!
if you don't have a head...intake mani compatibility and desired C/R are more of a concern tough
if you're insisting, if i had to start from scratch and choose a head, i'd pick a GSR one. i like the intake port geometry (porting potential) and the fact you can run the same C/R with less dome on the piston
#2188
thank's your info it's perfect but my car is to rich my wideband read 10.2-10.3 when my throttle body is open let's tune!! (6)
#2189
nah I dnt have a head yet and that screen name is old lol. It makes sense that GSR would be better but you just gave me more info as to why the GSR would be better. Since the B16/type r heads have bigger chambers, wouldnt it make sense that you could "cram" more air/nitrous to be combusted? Im new to nitrous and want to be educated
#2190
This thread sucks...........IMO.
People that want too control the amount of power their nitrous system makes are wasting time and should just go buy a turbo.
Nitrous is for racing, use it wide open.
I personally never had a problem with "fuel spike", click back some pages to see a real nitrous system.
People that want to install any kind of nitrous system on a street car and potentially use it there should stay way off on the side of the road when riding their bicycle so I don't run them over.
#2191
but your probably right...
we secretly all want to be like you and run a real nitrous setup in a gutted racecar with cage and kirkeyseat, because our dinky toys can't even come close to a real nitroussystem in a reallife racecar.
we all need a idol like you, so maybe we eventually come close to you
cmon man, after 6 years of nitrous experience you've only reached mid twelves in a allout racecar
the second bottle i ever filled up i make 320whp (probably about 80 more then you make)
the third bottle i ever filled up i run a 12.3@119mph banging of the revlimiter in 4th (on oldold crusty radials hitting a 2.1 60ft)
that's two tenths quicker and a whopping 14mph faster then mister proffesional with 6 years of nitrous experience
some slicks and a 1.6-1.8 60ft would've gotten me solid into the 11's (and you're still dreaming of a low 12 one day )
and oke, i made 1 stupid mistake. but that's somewhat unavoidable when you start pushing boundaries.
no wonder you never had problems with fuel spikes and only had burnt valves a couple of times. you're not making any power! and you still not making any after six years!!!
with my fooked up nitrous distribution (and even fueldistribution causing terrible lean conditions) engine failure started to occur at over 280whp
those are powerlevels you can only dream about on your proffessional dinky toy
i respected you and your setup for what it was, but that stopped when you started bashing people who try and push boundaries or want to logicly put a setup together.
come and brag when you have something to brag about. and not some allout racecar with 6yrs R&D that get's outrun by a full interior grocery getter on street tires on a simple,single and smallish dry shot on pump gas
#2192
i liked nitrous!!! 50 shot it's nothing you said, but in 3rd gear is huge power..
#2193
go try and make that extra 50 NA
it'll cost you
you'll be bored with the 50shot soon enough tough, wanting more and more
but first get the 50 shot running properly, you'll love it
keep checking the plugs tough, wet single foggers can have uneven fueldistribution amongst cilinders, check the fuel ring at the base
it'll cost you
#2194
it'll cost you
it'll cost you
#2195
WTF???
Pushing boundaries? more laughable ****. You two D&^Ks can talk about boundaries all you want on the computer.
#2196
your car is'nt a gutted out racecar? look at this (does'nt excactly look like a daily driven grocery getter to me)
your farfar away from even needing a 6-point, my best guess is that you won't get there either. everybody has to set attainable goals but dajum. if after six years you've only come to an 106mph setup
talking crap on the computer, hear yourself...
and i supposedly not even have a real nitroussystem
but i still have to try hard to let you win if we'd line up
#2197
if your just going to say negative **** keep it to yourself or take it to the pm's. so far since you came on here you haven't added anything positive to this thread just a bunch of bs. now behind your attitude i can tell there is some constructive criticism. why do you leave the bs to the side and fill this thread with some insightful information and check the drama at the door.
#2198
i don't think you're a pro. you sound like you think you are a pro
your within 2-3 mph of my stock block NA mph and about as quick as me when i'm on old crusty streettires and misshift to second
although wolve your right, he does have decent numbers for a nitrous only sohc z6. but all that doesn't matter when he brings bs to the table since he has been here. either way this can go on forever so just leave it alone bro. we already know who talks the talk and who walks the walk in here. dont let him make you stoop to his level.
#2199
http://www.hondaddy.com/forum/viewtopic.php?f=2&t=209
I'm #847, Thats bragging.
Who are you racing wolve? for real I'm mean not w/ hondafairys.
Sorry OP did'nt mean too mess your thread but....you call posting pictures of my kit and a welded blockguard not contributing.
#2200
