#1 | |||||
#2 |
This vehicle is a 2000 Acura Integra Type-R. The badge number is #748. The color is Phoenix Yellow. As you can see, the vehicle has been modified with tasteful modifications. I am the second owner. The vehicle was purchased from my friend in California on November 2005.
I am not afraid to be honest about the vehicle. A lot of meticulous work has been put into the vehicle previously and with myself. The vehicle was formerly turbo. However, it was returned back to naturally aspirated. The block was machined by the same people who do T1 Race Development’s machine work. It was assembled by a professional. All tolerances were plasti-gauged. All tolerances are within Honda range. The vehicle was previously tracked by its original owner, but not with me. I did have intentions to do so but never had time to do it. For the people who have never owned an ITR, its not how you have driven it, its how the vehicle was taken care of. This car does not need any work what so ever. Its ready to be driven daily or tracked. Here is my modification list. Exterior OEM JDM HID front end conversion - entire core support was changed out, the original paint job was done by M.O.B in Southern California, the bumper cover was punctured by a truck but was repaired, front bumper cover has been resprayed OEM JDM Red Emblems - front and rear OEM rear Honda emblem 17x7.5 +42 offset SSR competitions Tires - 215-40-17 Bridgestone S03’s OEM rear Type-R wing OEM side Type-R decals Interior Porsche GT2/GT3 Recaro seats Autopower 6pt bolt-in roll cage OEM shift knob OEM armrest with original serial badging Canadian airbag tray Integra RS inner door handles Alpine CD player Splash short hub adapter Nardi 350mm Sport Rally suede black with red stitching - Horn does work Longacre 14” convex mirror Suspension TEIN Type-RE with aluminum top hats (14K-F/10K-R) Ingalls rear camber adjustment Skunk2 front camber adjustment OEM USDM rear sway bar Carbing 3pt strut bar Brakes Stainless steel lines Cobalt Sport GT pads OEM front and rear rotors Drivetrain USDM ITR tranny Gear-X FD 4.928 (uses USDM ITR 1st gear, not JDM 1st gear) ACT 6 puck unsprung ACT disc Fidanza Flywheel Performance/Engine Neptuned Version 2.0 with adjustable launch control, redline 8100 USDM ITR block USDM ITR cylinder head Blocked bored out to 81.25” Deck shaved 0.0028” Compression 11.5:1 USDM ITR 81.25” pistons Integra LS rods Integra LS crank OEM Honda Integra LS bearings USDM ITR intake box with K&N cone filter JDM ITR 4-1 exhaust manifold with upper heat shield + skidplate Apexi N1 catback Injected Motor Mounts C&R radiator with slim fan JDM Beatrush heat plate The following were performed/replaced within 5000 miles Valve adjustment Honda headgasket Honda Water pump Honda Oil Pump Honda Timing Belt Honda Oil Pickup Honda Oil Pan Hot tanked engine block Items Removed Both airbags ABS sensors + front harness - modulator still intact Windshield wiper reservoir Power steering reservoir Cruise Control Rear windsheild wiper Rear back seats Rear deck lid Rear seat belts Front and Rear Brake heat shields Do not have OEM front seats Do not have OEM steering wheel Break In Process There are different theories how to break-in a new engine. The following is how I broke-in the engine. Between mileage intervals, the vehicle was driven normally, but rarely brought into VTEC under 100% Before startup, I primed the vehicle with oil pressure by disconnecting the main relay and distributor. At initial startup, I kept the RPM’s at 3000rpm until vehicle achieved normal operating temperature. I shut the vehicle down. Changed the oil and filter. I changed the oil and filter at 25 miles, 50 miles, 100 miles, 250 miles, 500 miles, and 1000 miles. The car does not burn oil. I use Castrol GTX 5w30 with Honda filters. On my previous track car, Mobil 1 Synthetic burned, Castrol GTX never did! I know many Honda Challenge/NASA contestants who use Castrol GTX as opposed to Mobil 1 Synthetic. I can arrange shipping at the purchaser’s expense. There is 0 warranty provided with the vehicle. The vehicle's condition is as best described. If you have any questions regarding its current condition, please ask! $18995 + SHIPPING ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Modified by migs at 9:18 PM 9/27/2007 |
#3 | |
#4 | |
#5 | |
#6 | |
#7 | |
#8 | |
Modified by migs at 10:51 PM 10/30/2007 |
#9 |
I'm selling my 1998 ITR, #1007. It has a CLEAN TITLE, 123k, and I'm the 2nd owner of the car and it's located in MN. It has the following...
Interior 4 point autopower rollbar jdm itr rear seats jdm itr red recaro srd's (mint) 3 point simpson harness all 5 itr oem floor mats including the optional rear mat in the truck (has itr stitched on it) Engine bay 2002 k20a2 swap with 51k. (i have a copy of the title/reciepts from the donor) hybrid racing wire harness hybrid racing fuel lines (black cloth lines) hybrid racing clutch line golden eagle pro fuel rail aeromotive fpr hasport mounts hasport axles rbc intake manifold karcept tb kit kpro rsx radiator aem intake dc sports hybrid header hytech dc2 catback modified to fit the kswap jdm itr red valve cover with a spoon kevlar cover karcept shifter kit oem itr strut bar jackson racing ps pulley tien hood dampner's Suspension/Wheels full comptech coilover (pretty much koni yellows/GC) omnipower front camber kit stainless steel brakelines powerslot rotors Desmond Regamasters (16" +45) with 95% SPT's 205/45/16 Volks extended lugnuts (blue) Exterior OEM HID JDM ITR front end Everything is in good condition. Power steering also works as well. No a/c (the car didnt come with it from the factory). It was professionally dyno @ a local shop @ 205 whp and 147 wtq. There is more potential but I opted for the dc and 2.5 piping due to noise and police. There's probably a few things im missing but thats the bulk of it. I am in no desperate need to sell this car as I have a company car, but I would like a down payment for a house. As of now, I just have pictures from HIN that locals took, but I will have more soon. Im looking for $19k as is or the price can be negotiated with parts being taken off. ![]() ![]() Modified by pennies_hatchie at 1:50 PM 9/28/2007
K24 Powered ITR #1007 l Canon 40D l 24-105 F4 L l 50 F1.4 |
#10 | |
#11 | |
#12 | |
#13 | |
#14 | |
#15 | |
#16 | |
#17 | |
#18 |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">ebay: http://cgi.ebay.com/ebaymotors...ZWDVW
Vehicle Description ******2001 PY Integra Type R NJ****** -53,000 mi on Car, 46,000 on motor. -Completly stock car except for Eibach Springs providing a 1.5in. drop. -Car has brand new tires. -Car has salvage history due to missing motor and front end. -Car has been restored to factory specs and is in full working condition, AC and all.. Contact Dario @ 732-433-9533 Miles: 53000 Body Type: Coupe Transmission: Manual Interior: Black Warranty: No Year: 2001 Title: Other VIN Number: jh4dc23171s000316 Get the Vehicle History Report Condition: Used Exterior: Yellow Engine: 4 Cylinder 1.8 Liter VTEC Inspection: -- Fuel Type: Gasoline Standard Equipment: Rear Spoiler Power Door Locks ABS CD AM/FM Radio Power Windows Air Conditioning TYPE-R 2 Wheel Drive Dual Air Bags 4 Cylinder 1.8 Liter VTEC </TD></TR></TABLE> |
#19 | |
#20 | |
#21 |
#22 |
FOR SALE:
2000 Acura Integra Type R, 58,621 Mods: Engine: New JDM ITR pistons New Rings All New Honda bearings New Honda gaskets Mugen 2 layer HG Hondata IM gasket Greedy Timing belt Stock head (untouched) AEM Cold air intake DC 4-1 header(seen better days!) 5Zigen Cat-back Chipped Kenji P72 ECU Hasport engine mounts New Alternator. 165amp New belts Trans: Exedy 8lbs flywheel Exedy stage 1 clutch kit New axles L&R Outside: OEM JDM conversion, done by Auto Body World in Tollsen,AZ 6000K HIDS JDM fender liners(not cut USDM) Tinted windows: 35% on windshield, 20% on front windows, 5% on rear windows and hatch New Tires (front, rear 60%) Paradas Prelude SH wheel (On when I bought It) Inside: Stock Except for the shift knob Last owner took # badge, replaced with blank JDM Fog light switch/button Stock Cd player Kicker Door speakers Alpine type s rear speakers This car has a rebuilt title. I bought it with a rebuilt title assuming it was clean 3 years ago. I belive it was hit in the right front, It pulls to the right may need lined up?. Im going to see what it will take to get this fixed. Also someone hit me lightly in the left rear, still has a mark on it and the paint is flaking alittle. I rear ended someone last year and had the front change to a JDM. Theres 2 small door dings on the passenger side. The drivers side skirt has spots where there paint flaking off from the work that was done to the front. The engine was rebuilt completely by myself. Im a auto mechanic and have 7 ASE. This was my first honda. Its runs very well, I belive it need tuneds as the chip was for the stock engine. I've lost intrest in the whole tuner scene. I love this car but Im at the point in my life where I gotta get rid of some toys. Im asking $9,500 for the car but will consider offers. Im not intrested in trades. Here your chance to own an ITR on the cheap! E-mail or PM me. Kicker139db@yahoo.com ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
"If driviing a Type R doesn't make the petroleum in you blood boil, you should collect your push rods and go home" Dave Colman, SCC http://images.honda-tech.com/set1/smile/emthup.gif Sold My 2000 ITR http://is.rely.net/1-92-65076-l-NREc...mLFY3DaZnA.gif |
#24 | |
Link: http://www.hondamarketplace.co...age=1
AIM & Xbox Live = Doostur (Playing MW2 & Forza 3) 2001 NBP ITR Turbo - 655 WHP 1997 AS SE Toyota Supra, 6 Speed, Turbo |
#25 | |
Link: http://www.hondamarketplace.com/zerothread/2117106
| Bookmarks |
| Tags |
| 16, 205, 40, acura, bernardino, ca, integra, marks, nexen, prolumen, sale, san, shell, trunk, vin, virginia |
