> Welding/Fabrication
Old 09-14-2007, 10:20 AM   #26
*Boostwerks*
*Boostwerks*'s Avatar
Send a message via ICQ to *Boostwerks* Send a message via AIM to *Boostwerks*
Bingo.
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com
Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
*Boostwerks* is offline Report Post   Reply With Quote
Old 09-14-2007, 10:30 AM   #27
Justin Olson
Justin Olson's Avatar
Send a message via AIM to Justin Olson
Default Re: (Boostwerks.com)
My major concern would be the turbo selection. That turbine housing is going to be questionable for flow on the gt3082r. I would have run a GT3076r personally as the largest turbo with that divided .78 a/r.
Justin
77 Datsun 280z w/ 2JZ swap in progress S480 Turbo
Justin Olson is offline Report Post   Reply With Quote
Old 09-14-2007, 10:41 AM   #28
*Boostwerks*
Default Re: (Justin Olson)
Justin
Same here honestly. The reason I chose the 3082 was because my buddy was selling his (slightly used) for $800. It was simply an offer I couldn't refuse.
There was someone on here that made very good power with one on slightly less boost than what other 76's to make the same power. The spool up seemed almost exactly the same, and torque didn't fall off like other 76 graphs I've seen. This was a built 1.8l gsr. The way I figure, is that the .78 housing should flow almost as much as the .82ar, yet be more efficent at the same time due to the cylinder division. This is all my "theory" of course, but from what I have seen out there, the logic fits. After all, I'm not looking for 600whp from this setup. I just want a nice 300whp powerband on low boost to be safe on my 11:1 CR stock block B16. My old SC61 was just too damn laggy.
And like I said, if I can find anyone who makes a large A/R housing, I will by all means get it. The .78ar is just the only ratio ATP offers.
Old 09-14-2007, 02:14 PM   #29
Vince64
that full race mani is done right. Its divided all the way to the v band.
http://www.full-race.com
http://www.ecomodder.com
70 mpg or die
Vince64 is offline Report Post   Reply With Quote
Old 09-14-2007, 02:43 PM   #30
DESTROYER
DESTROYER's Avatar
was there a point to that statement or are you just swingin nuts?
Clever Comprehension - My blog
DESTROYER is offline Report Post   Reply With Quote
Old 09-14-2007, 03:09 PM   #31
.RTErnie
.RTErnie's Avatar
Send a message via AIM to .RTErnie
Default Re: (DESTROYER)
he's just swingin' away. Bryson's collector looks to be better finished than the F-R one.
Eric Urness
R/TErnie Race Engineering 541.980.6022
SRT-4 and Neon Turbo Manifolds, Tuning, and Fabrication!
.RTErnie is offline Report Post   Reply With Quote
Old 09-14-2007, 04:07 PM   #32
ebydrc
Banned
Send a message via AIM to ebydrc
Default Re: (.RTErnie)
i think he was just useing the pubic hair for floss
ebydrc is offline Report Post   Reply With Quote
Old 09-14-2007, 06:06 PM   #33
*Boostwerks*
Default Re: (Vince64)
Pics? Even if it is, it would make almost no difference. Once the WG Opens there is still a point where the the cylinder flow can cross (although it's likely not to be much of anything). The only way to truely eliminate it, is to have dual WG's. To say what benefit that would have over a single WG is anyone's guess. If someone would want to test that...be my guest.
Old 09-14-2007, 06:13 PM   #34
ls1_datsun
ls1_datsun's Avatar
I'll be testing a gt3076r in the next month here with the following housings:
standard t31 .63ar garrett housing
ATP divided .78ar housing
Tial .63 Stainless V-band housing.
It will be tested with variations of the manifold.
For the standard t31 housing and Tial v-band housing
Single gate 60mm
For the ATP twin Scroll Housing:
twin scroll merged to 60mm gate
twin 44mm wastegates
ls1_datsun is offline Report Post   Reply With Quote
Old 09-14-2007, 08:34 PM   #35
Vince64
no nut swinging. I just wanted to say that why go though the trouble of making a divided manifold when the WG collector will allow gas transfer between the two different banks. Isnt the point of a divided manifold to separate the pulses?
this is a suby up-pipe but you can see it divided all the way to the flange. It just seems like the right way to use a single WG on a divided manifold.
And yeah dual WG's would be the best bet but add on another $300 and then make the space to put it and another dump tube.
70 mpg or die
Old 09-15-2007, 11:45 AM   #36
*Boostwerks*
Default Re: (ls1_datsun)
Single gate 60mm
Dang...I was just being sarcastic lol. I didn't think someone would actually go through all that trouble to test something like that. But I can't wait to see the results of that! Keep me updated if you can!
I understand what your saying man. I just don't think it would make much of a difference is all. I might be completely wrong though, and ls1's tests should definetly reveal any differences.
However, I would like to make it clear though that I will be trying to keep the WG tubes completely divided (just like the full-race setup). Like you said... why go through all the work to divid the collector, and not put a divider in the WG tube? It certainly can't hurt anything, and wouldn't take much work to do.
Old 09-15-2007, 12:40 PM   #37
tony1
H-T Basic Sponsor
tony1's Avatar
Speaking of which, looks to me like it's probably pretty thin in areas based on the before and after pics. Look at how much it hangs into the path of flow in the first pic, once that's ground down it's gotta be pretty thin in that area, no?
I'm pretty sure that's why FR doesn't port them out like that, to keep the strength. Good fitup and no grinding > bad fitup but smooth after grinding.
T1RaceDevelopment.com
Check out the new site!
The ID2000 is here...
tony1 is offline Report Post   Reply With Quote
Old 09-15-2007, 01:32 PM   #38
*Boostwerks*
Default Re: (tony1)
The fitup is actually A LOT better than what that pic makes it seem. The corners I just put a lot of filler in there so i could blend the roundness of the pipe to the squareness of the flange (hence the blob in the pic). I had a straight on pic of the collector before It was ported, but unfortunetly my GF deleted it so the card would have room to take a pic of our cat.
It isn't very thin at all though. Theres a little less than an 1/8" of pipe between the ported pipe, and the outside of the pipe. Considering 1/8" is the size of the pipe, not much was ground out at all.
Old 09-17-2007, 11:16 PM   #39
_k20a2_
_k20a2_'s Avatar
Correct me if I'm wrong but when in boost the wastegate's sole purpose is to vent exhaust gasses. They're not mixing and going back to the turbine. As long as the tubes are divided all the way to the wastgates valve you should have no problems. Otherwise gasses would mix when the wg is closed.
DC5-T
_k20a2_ is offline Report Post   Reply With Quote
Old 09-17-2007, 11:38 PM   #40
mchuang
mchuang's Avatar
Default Re: My personal divided T3 manifold "build thread"... (Boostwerks.com)
Looks pretty nice, cant wait to see it perform. Let me ask you what turbo are you using that has a divided t3 flange, because I have yet to see one. A link would be nice also.
mchuang is offline Report Post   Reply With Quote
Old 09-18-2007, 07:23 AM   #41
weiRtech
weiRtech's Avatar
i've seen some holset t3 divided flange turbos. perhaps that is what bryson is using? they are honking big.
my RWD CRX2000 build thread
weiRtech is offline Report Post   Reply With Quote
Old 09-18-2007, 08:20 AM   #42
ls1_datsun
ls1_datsun's Avatar
Default Re: (weiRtech)
atp has a t3 turbine option in divided .78ar. Borg warner also offers divided t3's in more ar options.
Old 09-18-2007, 09:29 AM   #43
drumking15
drumking15's Avatar
Send a message via AIM to drumking15
ya they are massive...not quite quite a gt42...but w/ the offset of the turbine housing it makes fitment a lil tricky
and this divided setup would be perfect for my old holset...never did get to run it in a divided setup...but it worked well w/ an eq. pressure manifold
OEP 4 Life...no other way to be http://images.honda-tech.com/set1/smile/emthup.gif
drumking15 is offline Report Post   Reply With Quote
Old 09-18-2007, 05:53 PM   #44
*Boostwerks*
Default Re: (_k20a2_)
Isn't that what I said? I said they would mix, but honestly it wouldn't be much of anything...hence why i think it wouldn't make much difference. At any rate, I'm going to divide it all the way to the flange.
Theres actually a lot out there. But I'll be using a GT3082R with the .78ar ATP housing. The GT37 actually comes with a divided T3 as well. IMO, It's all about the divided setups. I'd really like to get a larger A/R housing for the turbo to really take advantage of the divided benefits, but unfortunetly there isn't one out there.
For sure man. Once I get everything worked out, I'll be able to add these manifolds to my collection.
Old 09-18-2007, 06:01 PM   #45
drumking15
drumking15's Avatar
thats awesome news for the holset guys back when i had my nuekin mani i created some rough designs of a divided setup that i wanted to build...but blew it up...and then got out of the game till im out of school
Old 09-20-2007, 07:18 PM   #46
*Boostwerks*
I hear ya man. It's taken me so long to get my car finished because I've been trying to finish up my degree as well.
I'll have more time this weekend to get some runners built...WOOT!
Old 09-20-2007, 07:34 PM   #47
Autoworks
Autoworks's Avatar
coming along nicely
Is this going to be a chassis specific mani as well?
http://www.GO-AUTOWORKS.com
88' Civic HB D16 10.99 @131MPH
09'-2010 Import Face-Off Race Sponsors...Keep the Sport alive, Come Race with US!!
Autoworks is offline Report Post   Reply With Quote
Old 09-21-2007, 12:20 AM   #48
RC000E
RC000E's Avatar
Default Re: (Autoworks)
Is it done yet....is it done yet?????? HURRY UP!
N/A time!
RC000E is offline Report Post   Reply With Quote
Old 09-21-2007, 09:55 AM   #49
servion
servion's Avatar
Looks good man! I wish you could get yourself a bigger hotside a/r.
Servion Tuning with Revolutions Performance
Need proper tuning in Colorado? NepTune, AEM EMS, FAST, BS3, PowerFC, Motec, Haltech, Autronic...
10.2@146
servion is offline Report Post   Reply With Quote
Old 09-21-2007, 12:58 PM   #50
QuarterMileMaster
QuarterMileMaster's Avatar
Send a message via AIM to QuarterMileMaster
Default Re: (servion)
Subscribed!
J2ned Turbo Kits - You'll See...
QuarterMileMaster is offline Report Post   Reply With Quote
Bookmarks
holset, manifold, sr20
