> Honda CRX / EF Civic
Old 09-06-2007, 04:47 PM   #26
STREETWERKZ
STREETWERKZ's Avatar
Default Re: New EF products from Hasport - hydro conversion & stock replacement mounts (brian g)
very awesome!
if only i still had the D series.... i would have bought these in a heartbeat.
i did purchase your K series mounts though.
Honda S2000 For Sale *socal*http://hondamarketplace.com/showthread.php?t=2612334
STREETWERKZ is offline Report Post   Reply With Quote
Old 09-06-2007, 05:22 PM   #27
949
do you know who makes the motor mounts for the 4wd wagon? i have the stock setup and just wanted a stiffer engine mount.
949 is offline Report Post   Reply With Quote
Old 09-06-2007, 06:22 PM   #28
doublethink
doublethink's Avatar
Default Re: (949)
how do the wagon mounts differ?
if only the tranny mount is different, then youd at least have 2 poly mounts, and then get a new from the dealer tranny mount, with fresh rubber.
or fill the old one with window weld.
[1985 CRX Si -Sold] [1989 CRX DX -Junked] [1990 CRX DX (b16a) -Wrecked] [1990 CRX DX -Parted] [1991 CRX Si -Parted] [1988 CRX HF -Sold]
2004 s2000
Berlina MOB #040
doublethink is offline Report Post   Reply With Quote
Old 09-06-2007, 06:29 PM   #29
KrenzyRyan
KrenzyRyan's Avatar
Send a message via AIM to KrenzyRyan
Right on Brian. Its great living so close to such an awesome company.
Aren't you Joe Locash's brother?
KrenzyRyan is offline Report Post   Reply With Quote
Old 09-06-2007, 06:46 PM   #30
JDMegCoupe
JDMegCoupe's Avatar
Does this mean I can put my D16z6 from my 95 EJ into my REX and get a B searies engine for the EJ, so I can save the my sohc? If so I'm going to be very happy
JDMegCoupe is offline Report Post   Reply With Quote
Old 09-06-2007, 08:29 PM   #31
Bense
Moderator
Bense's Avatar
Send a message via ICQ to Bense Send a message via AIM to Bense Send a message via MSN to Bense Send a message via Yahoo to Bense Send a message via Skype™ to Bense
which axles are used with this kit?
cable 88-91 axles or hydro 92-00 axles.
does this keep the engine in the stock location?
Bense is offline Report Post   Reply With Quote
Old 09-06-2007, 08:41 PM   #32
brian g
brian g's Avatar
Default Re: New EF products from Hasport - hydro conversion & stock replacement mounts (Bense)
Stock axles with either tranny.
Yes
Actually my brother works here with me at Hasport. Joe was an employee here until recently and has a shop next door.
As long as you have a manual tranny our mounts will work. Otherwise, just buy a rear mount, it will eliminate most movement.
brian g
http://www.hasport.com
brian g is offline Report Post   Reply With Quote
Old 09-06-2007, 08:51 PM   #33
949
i have the manual tranny. so it doesnt matter if its 4wd or not?
i have the stock D16 with cable tranny.
whats your web site?
is there a contact info?
Old 09-06-2007, 09:47 PM   #34
nihkon
nihkon's Avatar
Default Re: (949)
Super rad! I had been searching for these for quite some time now. Neato!!
nihkon is offline Report Post   Reply With Quote
Old 09-06-2007, 10:58 PM   #35
RockinthEFhatch
RockinthEFhatch's Avatar
Default Re: (nihkon)
I have a B series but this is still awesome and I'm all for D-series builds
'91 CRX Si
RockinthEFhatch is offline Report Post   Reply With Quote
Old 09-07-2007, 12:18 AM   #36
661rex89si
661rex89si's Avatar
Send a message via AIM to 661rex89si
sweet now i can run a hydro tranny on my sohc. great product its about time so when are these coming out.
"ALL THROTTLE NO BOTTLE WELL JUST MAYBE"
EXOSPEED FTW!!!!!!!
661rex89si is offline Report Post   Reply With Quote
Old 09-07-2007, 07:44 AM   #37
Synchro
Synchro's Avatar
Default Re: (661rex89si)
Brian is the man!
Synchro is offline Report Post   Reply With Quote
Old 09-07-2007, 08:12 AM   #38
brian g
brian g's Avatar
They're available now.
According to my parts list of your car, it appears that the tranny mount is different. So you could only do the rear and driver-side mounts. If you can send me a picture of the transmission mount and how it bolts to the framerail, I can tell you if there is another option.
(602) 470-0065
brian g
Old 09-07-2007, 07:28 PM   #39
Mista Bone
Mista Bone's Avatar
Send a message via AIM to Mista Bone
Nice job B........
helps get away from the stock 88-91 non-hardened diff pin.]
"D" Tranny Guru
Mista Bone is offline Report Post   Reply With Quote
Old 09-07-2007, 08:11 PM   #40
bossman032
Default Re: (brian g)
nice finally it came out right.
does the front mount need to be cut or anything? is engine placement same height as stock mount?
bossman032 is offline Report Post   Reply With Quote
Old 09-07-2007, 08:15 PM   #41
dr_latino999
Global Instigator
dr_latino999's Avatar
Send a message via AIM to dr_latino999
Default Re: (bossman032)
There will be no front mount with hydraulic transmissions.
One Step closer to finishing my short block: "Houston, 77mm CP's are in the sleeves, over."
Project D16 On Crack
dr_latino999 is offline Report Post   Reply With Quote
Old 09-07-2007, 08:32 PM   #42
661rex89si
661rex89si's Avatar
Default Re: (dr_latino999)
but will the engine movement be bad without a front mount
EXOSPEED FTW!!!!!!!
Old 09-07-2007, 08:48 PM   #43
Mista Bone
Mista Bone's Avatar
Hasn't been an issue with the B16 swaps......
"D" Tranny Guru
Old 09-07-2007, 08:51 PM   #44
661rex89si
661rex89si's Avatar
well then it should be a problem then
EXOSPEED FTW!!!!!!!
Old 09-08-2007, 04:57 PM   #45
brian g
brian g's Avatar
The mounts are now up on our online store for those who are interested.
You can go here:
http://hasport.com/shop/index....fb340
By the way, we decided to lower the price from $349 to $299.
Anyone who bought them at the higher price will receive a $50 gift certificate at the Apple Store (jk)
brian g
Old 09-08-2007, 05:51 PM   #46
allhonda
allhonda's Avatar
my god looks like all hell just broke lose!!!!!! good work man!!!!!!!
my buid: http://honda-tech.com/zerothread?id=1911999
allhonda is offline Report Post   Reply With Quote
Old 09-09-2007, 11:27 PM   #47
bossman032
Default Re: (allhonda)
engine vibrations?
Old 09-10-2007, 09:11 AM   #48
Tippyman
Tippyman's Avatar
engine vibrations?
Obviously, depending on the grade of urethane you get, the vibration will vary.
-95 Miata DD
-91 Civic Turbo
Tippyman is offline Report Post   Reply With Quote
Old 09-10-2007, 09:25 AM   #49
BIGTUNA
BIGTUNA's Avatar
Send a message via AIM to BIGTUNA
Default Re: (Tippyman)
About time someone makes D Hydro mounts for a EF. LOL im tired of fabbing my own mounts. Can the mounts be ordered solid or with an extremely tough urethane insert?
This is the kit I made using old Place Racing Hydro B series swap mounts in my current CRX. Works great but they are too soft.
(This pic was taking during mockup so forgive the wiring ect.)
13.20 @ 102 150 hp of raw sohc fury
BIGTUNA is offline Report Post   Reply With Quote
Old 09-10-2007, 10:43 AM   #50
brian g
brian g's Avatar
Default Re: (BIGTUNA)
Like all Hasport mounts the kit is available in 62A, 70A and 88A. You can even mix and match if you like.
brian g
Bookmarks
brian, civic, conversion, dseries, ef, fix, hasport, honda, hydro, kit, mounts, series, striped, tech, trans
