> Honda CRX / EF Civic
Old 09-01-2007, 05:10 PM   #51
UltimX
UltimX's Avatar
Send a message via AIM to UltimX
Default Re: (gibsanez)
Originally Posted by gibsanez
Shitty 110 mig. Took it to work and plugged it full of stainless rods.
Thanks for the concern though, it would be no good to me if it just snapped and dropped my alt. onto passing pavement.
Most definatly, or if you ran over the alt distroying a wheel or something worse!
FS: d16a6 head complete, LS head minus rockers, eibach sportline springs & aftermarket struts, Catalytic Con., sparco speed seat, NEW Traction bar, aftermarket header. 1800 lbs and dropping...
UltimX is offline Report Post   Reply With Quote
Old 09-02-2007, 07:11 AM   #52
gibsanez
gibsanez's Avatar
Default Re: (UltimX)
A stock rad WILL fit, at least with my bracket .
Here are my top hose angles, I'm going to cut up the stock one to see If i can fit it without bending, if not, I'll be making a trip to the auto-parts store with my bent piece of solder.
The rear hose I can probably get away with a 45 and a short nipple or something.
And my hood waiting for surgery.
Originally Posted by Rude Awakening View Post
i accidentally a daughter
gibsanez is offline Report Post   Reply With Quote
Old 09-02-2007, 07:59 AM   #53
redzcstandardhatch
redzcstandardhatch's Avatar
Send a message via AIM to redzcstandardhatch
great job man...
custom EF traction bar and a cheap K24 for sale too! PM!
WTB: useable h22 of h23 block/girdle..no crank needed
redzcstandardhatch is offline Report Post   Reply With Quote
Old 09-02-2007, 09:44 AM   #54
lilsicsoul
lilsicsoul's Avatar
Send a message via AIM to lilsicsoul
stikii!!
lilsicsoul is offline Report Post   Reply With Quote
Old 09-02-2007, 12:20 PM   #55
gibsanez
gibsanez's Avatar
Default Re: (lilsicsoul)
Hokay, so I measured the distance from my pedal to my TB with a piece of wire, and it comes to roughly 31". I measure the length of my Integra throttle cable, and it comes to 39". Great.
Anyone happen to know the lengths of some other honda throttle cables?
Old 09-02-2007, 01:03 PM   #56
thevtecnician
thevtecnician's Avatar
Send a message via AIM to thevtecnician
I used a da throttle cable worked perfect. You might just have to move the mounting bracket if that makes sense.
Cheap swaps/tucks/ troubleshooting in the twin cities!
http://minneapolis.craigslist.org/hn...466984857.html
thevtecnician is offline Report Post   Reply With Quote
Old 09-02-2007, 01:08 PM   #57
gibsanez
gibsanez's Avatar
Default Re: (thevtecnician)
I can't seem to figure this out, I myself pulled a throttle cable right out of a 91 integra, and this is where it end up pulled taught. I could put the bracket right there, but the cable will rub on the top of the iacv.
Old 09-02-2007, 01:19 PM   #58
thevtecnician
Your problem is in the bracket for the cable.experiment with it. Try putting it on backwards
Old 09-02-2007, 01:27 PM   #59
gibsanez
gibsanez's Avatar
You can see that picture right? When I pull the cable taught, that is where the holding point for the cable ends up. If I put the cable bracket in any position closer than this, I have slack in the cable. If I try any of the stock holes in the intake mani, I have like 6" too much slack on the TB side.
Old 09-02-2007, 01:57 PM   #60
88ED8
88ED8's Avatar
Send a message via AIM to 88ED8 Send a message via MSN to 88ED8
that cable worked for me cause my TB has many mounting points... you should maybe try to get a 90-93 accord cable, might fit better
AEM Fuel Pressure Regulator for sale!!! $85 shipped http://hondamarketplace.com/showthread.php?t=2684333
88ED8 is offline Report Post   Reply With Quote
Old 09-02-2007, 04:22 PM   #61
skunked
skunked's Avatar
Send a message via AIM to skunked
Default Re: (88ED8)
Does the throttle cable wrap "under" the t-body throttle wheel? That should get rid of the slack.
2.2L H2B NA DC2 S/P 12.1@110
http://www.quartersportsdrag.com/
SINISTER RACING
skunked is offline Report Post   Reply With Quote
Old 09-03-2007, 06:02 AM   #62
gibsanez
gibsanez's Avatar
Default Re: (skunked)
Ok, lets try this again. The following pictures are of the cable secured into the pedal, and onto the firewall grommet. This is the farthest away I can mount the cable bracket, using the oem holes in the intake mani and the bracket.
Edit - If I install it in reverse order, as in TB, then bracket as far away as possible using oem holes, firewall, and THEN pedal, the cable extends past the pedal by 4".
Old 09-03-2007, 08:38 AM   #63
thevtecnician
You know now that I think of it I used a civic/crx si cable. Look at this pic. Thos two holes(one of which has a bolt in it) is where the bracket would mount up.
Just like on the h, the bracket is close to the throttle body
http://s34.photobucket.com/alb...3.jpg
Old 09-04-2007, 04:25 PM   #64
SIXTY
SIXTY's Avatar
This is my upper rad hose. It is just two 90 deg bends clamped to a piece of pipe. And i think that i aslo used a civic si throttle cable.
760/SEVEN_SIXTY/BUILT
High Desert service for Motor Swaps/Builds
PM for all inquiries
SIXTY is offline Report Post   Reply With Quote
Old 09-06-2007, 04:48 PM   #65
gibsanez
gibsanez's Avatar
Default Re: (SIXTY)
Alright, this Is what I ended up doing with my throttle cable. I wrapped it under the wheel past the correct location, to the second hole for the kickdown cable from the old auto tranny. It's kind of funny that I think this looks right haggard, yet I had no problem cutting a large pocket out of my frame rail.
I managed to get some more of my dash together, mainly my gsr cluster back in. I have a 2000 SI center console already fitted, I just have to find a way of mounting it to the floor.
My front cross-member didn't clear the front of the engine where the old front mount went.
Also hoping to finish my batter relocation before the weekend is over.
And finally, my rad hoses. This is with a full size stock civic rad, with the full size stock fan. If i had a slim-fan or even a push fan on the front, I wouldn't be doing that many angles, but whatever, $14 in hose is better than a whole new fan when mine already works. I ran out of hose clamps, so that's why a couple are missing
And the rear
Old 09-06-2007, 05:01 PM   #66
pumpkinkidd
pumpkinkidd's Avatar
Good work
Curse Free Inspired Y-49
pumpkinkidd is offline Report Post   Reply With Quote
Old 09-08-2007, 01:08 PM   #67
gibsanez
gibsanez's Avatar
Default Re: (pumpkinkidd)
More Updates
Finished my battery relocation, just have to vent the bastard and secure the batt inside the box. I tested it by putting my key in the ignition and successfully retrieving a Municipal Waste CD that had been stuck in my cd player for about 6 months.
Got all my hose-clamps on, got a clutch cable bracket on and adjusted it all up. Also bled my brakes, and got my axles in, so it's almost ready to go back on the ground.
Here is the spot underneath the lower control arms where I had to clean out to make room for the bolt. I'll have to mount the bar underneath, to make room for my crank pulley.
My late night motivation
Old 09-08-2007, 02:03 PM   #68
1989CivicSi
1989CivicSi's Avatar
Great progress. It's already apparent that this car is purpose and not show build (at least yet) which gets a big from me.
keep it up!
EFsquad member: 010
1989CivicSi is offline Report Post   Reply With Quote
Old 09-08-2007, 04:38 PM   #69
gibsanez
gibsanez's Avatar
Default Re: (1989CivicSi)
keep it up!
Thanks boss
I doubt I'll be winning any shows anytime soon with a flat black DIY cowl hood . Right now it'll just be my monster of a DD, which is all I've really wanted from it.
Hoping to get my ECU back and start this bitch monday or tuesday.
Old 09-08-2007, 04:57 PM   #70
91ed9
91ed9's Avatar
Send a message via AIM to 91ed9
why dont you make a bracket to extend the cable instead of rapping it around the throttle .... bc that might get stuck/ it might not
just my .02
but its coming along nicely! what are you doing with the hood just a little bump where the whole is.
91crx si- junked 91crx dx-Sold!
2006 Audi A4 Tein coilovers,Custom FMIC Apr stage 2 software, 2.5" testpipe, 3" custom single exhaust, South Bend stage 2 clutch, 16lb lightwieght flywheel
91ed9 is offline Report Post   Reply With Quote
Old 09-08-2007, 05:27 PM   #71
88ED8
88ED8's Avatar
good progress.... can't wait till I grind my lca
Old 09-09-2007, 06:49 AM   #72
gibsanez
gibsanez's Avatar
Default Re: (91ed9)
just my .02
I may do that in the future, but it does actually move quite freely. If I'm going to have any problems, they'll probably show up right away.
I STILL can't decide what I'm going to do with the hood. I'm still stuck between a bump or a cowl dealy. Currently I'm leaning towards a fiberglass bump.
I used a mini-grinder for the first one, and it turned out really slutty, so I did the second with a dremmel and it turned out much nicer. You're going to have to loosen the nut on the front of the x-member to get an extra 1/2" to line the holes up. I'll get some pikcha's.
You're going to need longer bolts. Also, you should try and thread them from the bottom first to clean out the bottom threads before you go to line everything up, it made everything a lot easier.
Old 09-09-2007, 08:24 AM   #73
YeeJ6
YeeJ6's Avatar
Send a message via AIM to YeeJ6
comin along very nice!
!!HYBRID WORKS!! l EK SQUAD!! l QSD l
For all your honda/ import needs
(707) 712-4427
YeeJ6 is offline Report Post   Reply With Quote
Old 09-09-2007, 03:37 PM   #74
gibsanez
gibsanez's Avatar
Default Re: (Spoonspeed)
Loosen up the front first to give yourself some room to play.
Tighten it back up and get an alignment!
Old 09-12-2007, 04:44 PM   #75
sauceja
sauceja's Avatar
subscribed.
Honestly that hood looks pretty good like that. But I wouldn't go with a bubble and look like the DSM boys.
Make a cowl that has a c curve in it that blows back over you exhaust header to keep temps down.
Someone really needs to solve the hood problem. I am going to pick up a crx in a couple weeks and might be doing something similiar.
keep up the good work.
My Build
FS: honda Service Manuals and ETM
Leaving the game for a bit! I will return stronger!!
sauceja is offline Report Post   Reply With Quote
Bookmarks
1990, 92, acura, civic, da, ef, h22, h2b, headers, honda, hondatech, hood, integra, swap, write
