#26 | |||||||
#27 | |
#28 | |
#29 | |
#30 |
I pulled the cable myself out of the integra, so I atleast know for sure that it's the right cable. This is where the adjuster sits when the cable is attached to the gas pedal and the throttle body.
#31 |
and your sure it's hooked up correctly at the pedal? That's allot of slack, like 6-8" huh?
#32 |
I'll double check the pedal, but I know it went in well. It is a lot of slack
#33 | |
#34 | |
I cut the nub off at the end of the bolt, plus flattened out the bump I took a picture off, and it fits like a glove. ![]() ![]() ![]() ![]() How is this for an eye-ball DIY? ![]() ![]() I'm going to have to modify my front cross member to fit the bottom of the bracket, had I anticipated that I would have made the bracket shorter and more compact. Eventually I'll go to a full traction bar setup or make my own to get rid of the slack-ass hole I have to cut in the stock x-member. The pictures almost look like I'd be cutting RIGHT into the spot where the rod and bushing are, but luckily I'm beside it. I'm not proud of having to cut my x-member up, that was not enough planning on my part. If anyone else plans on making their own bracket, make it short as possible. ![]() ![]()
#35 |
whoa alternator clearance!
great DIY!!!
Honda S2000 For Sale *socal*http://hondamarketplace.com/showthread.php?t=2612334 |
#36 |
You're not worried about that silicon on the oil pan?
I only say this because if it sprung a leak in that spot you'd lose enough oil to hurt the motor. Great build, this is cool. Looking foward to see the hood.
[1985 CRX Si -Sold] [1989 CRX DX -Junked] [1990 CRX DX (b16a) -Wrecked] [1990 CRX DX -Parted] [1991 CRX Si -Parted] [1988 CRX HF -Sold] 2004 s2000 Berlina MOB #040 |
#37 | |
#38 | |
#39 |
I ended up double-nutting the original bolts that I was using for my alt. bracket, and moving them into the higher spot, and re-drilling my bracket. This way, i no longer have to cut my front cross-member. I'll get sum pixx.
#40 |
looks a lot easier than the H/F to D swap... did you have to notch the frame rail for the crank pulley? Can't believe how much more room you have compared to my f to d
NOOB to Honda-Tech, not to Honda's '90 CRX Si Olive Green, Bisi F2D turbo (soon to be in a WAGON, WHUT!) Yeah, I rock a Honda tattoo... (vw in avatar is not mine, just a dream car) |
#41 | |
Like I said before, I moved the alt. bracket higher, so now there will be no cutty-cutty of the x-member. Yay! I am converting to a half-rad because I need the room for my alt. ![]() ![]() ![]() ![]() |
#42 |
much better up there IMO
#43 |
H2B=
#44 |
If you remove the iab's from the intake manifold it will drop an inch and the wiring will be easier. Also get an sir hood or sir style hood. And then use spacers
Cheap swaps/tucks/ troubleshooting in the twin cities! http://minneapolis.craigslist.org/hn...466984857.html |
#45 | |
It actually gave me quite a bit of clearance.I'm getting a half rad tomorrow, I need the clearance for my alternator. I'll take mega pixx of my hoses and whatnot. I'm trying to get my hands on a stock 2-1 off of a prelude. The angle will be WAY off though. What I'll end up doing is using a stock 2-1, cutting it right after the O2 bung, and welding in a couple pieces of a 45 degree pipe or something to match it up with the flange on my cat. The SiR hood won't work. The bumped portion isn't wide enough. I'll show you. This was after about 20 minutes of fitting. It looks like I'll be able to get away with 1/2" or 5/8" spacers in the rear. I won't be leaving the big hole there, I'm disputing putting a bubble, or a small cowl there. I don't know yet, any suggestions are welcome. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#46 |
looks good. i think you or who ever is doing the welding on that bracket needs to lower the wirespeed, crank up the amperage, or both. just tryin to help. can't wait to see it done.
FS: d16a6 head complete, LS head minus rockers, eibach sportline springs & aftermarket struts, Catalytic Con., sparco speed seat, NEW Traction bar, aftermarket header. 1800 lbs and dropping... |
#47 | |
Thanks for the concern though, it would be no good to me if it just snapped and dropped my alt. onto passing pavement. |
#48 |
Ya that shyt looks nice.. great swap....
Selling b20b's longblocks $625 H22a's complete swaps $1900 OBD0 b16 dizzy 80 obo... H&R Coilover/struts setup 500+shipping http://www.honda-tech.com/zerothread?id=2103822 |
#49 |
Rainman
1991 Honda CRXJoin Date: Mar 2006
Use an sir hood (no indented center section) then make the same cut, make a cowl center section or bubble, then you shouldn't have to crank the back up.
Im interested to see how this turns out! Modified by SIred91 at 4:49 PM 9/1/2007
I'll have the tuna. EFsquad#104 |
#50 |
i think even a cowl on what he has now would look killer.
| Bookmarks |
| Tags |
| 1990, 92, acura, civic, da, ef, h22, h2b, headers, honda, hondatech, hood, integra, swap, write |
