BULB SIZE: H1, H3, H4/9003(low), H7, H8,H9, H10, H11, H13/9008(Low),9004(Low), 9005, 9006, 9007(Low)
9004=HB1, 9003,H4=HB2, 9005=HB3,HB3A, 9006=HB4,HB4A, 9007=HB5
Link to check your car bulb size
(Some factory or OEM fog light might not included)
(Beware some car have two differnt option, factory standard HID or halogen capsules)
(Bulb size H4656, H6054, H6024 and etc, these bulbs call seal beam. Can't convert to HID unless it convert to halogen capsules) [b]
[b]HID CONVERSION KITS $ 89.99 SHIPPED
HID COVERSION KITS INCLUDED:
2 x Ballasts
2 Xenon Bulbs
10 Zip ties
2 Heavy duty heat resistant double sided self-adhesive pads
2 ConnectorS
Manual
Warranty Card (Required for warranty replacement)
Reminder: No relay harness included in this kits.
Payment:
Unfortunately our website is down
so please send the payment to my paypal account williamh12781@gmail.com
please specific the bulb size and kelvin you need
Contact: Primary
California, LA County
William
Local Pick Up & Installation availabe
please contact local seller
Cell:909.569.5656
email:williamh12781@hotmail.com
Paypal: williamh12781@hotmail.com
(If you place an order let me know ur blub size and temperature)
Honda-tech IM me anytime if you need me
Email will be the first priority
Washington, Lynwood
Andrew Pham
206.852.9214
THANKS TO PHOEBE (MATRIX), FIONA (TC WHITE) AND JOHNSTON (CIVIC SI)
KEVIN (MAZADA 3 BLUE), STANLEY (TC BLACK)
COLOR: 3000K, 6000K, 8000K, 10000K, 12000K
Pleasse note: when installing the kit with the (Low) beam only, you will loose your high beam , however, the adjustment in the capsule will compensate for the lost of the high beam, and it will be alot brighter than your halogen high beam and yet not blinding. Please Dont forget to specify the following information!!!
Features
This Kit is mannufacturered under strict quality control and the factory is ISO-9001 certified. The ballast and the burner in this kit have passed the most stringest OEM specific test by Toyota (Denso) of Japan, and they uses these ballast for the OE market in the Southern Americas region and some of the southern Asia countries.
100% water proof construction, you can submerge the entire kit under water and it will function correctly
Integrated one piece Ballast, simplified wiring which eliminates any unnecessary confusion during install.
More than 16+ bulb types, we will have the right bulb type for your vehicle
0.3% failure rate, compared to 5-10% failure rate of other HID Conversion kits currently out on the market, the reliability is comparable to that of OEM HIDs
Color temperature output has tolerance of +/- 100K, the tolerance is unnoticeable by human eyes
Superior lumen output compare to its competitor
Best quality burners from Bosch Japan
Choose from 5 different color temperature, you will indefinitely find the color out put of your choice
Power consumption: 35watts
Voltage: 85V +/- 17V
Luminous flux: 2800
Service Life: up to 3000hrs
Input Voltage: 9V-16V
Working current (Steady state): 3.5 A nom
Ignition voltage: 24kV Peak Max, 18kV Peak Min
Lamp Frequency: 450 Hz
Warranty
The ballast and the bulbs will come with one (12 months) year warranty under normal use. Warranty will cover all normal defects, any physical damages will void the warranty.
Shipping Terms and Conditions
1. Payment methods
A) PLACE ORDER IN OUR WEBSITE WITH VISA, MASTER, AMERICAN EXPRESS, DISCOVER, CHECK CARD (MUST BE VISA OR MASTER), CHECK (TAKE 3-5 TO CLEAR) OR MONEYORDER
2. Shipping
A) Free shipping (within US) 3 - 5 days ( All item must ship to one paypal confirmed address)
B) Express Shipping
USPS EXPRESS 1 TO 2 DAYS $ 24.99 W/ INSURANCE
FEDEX EXPRESS NEXT DAY $ $ 34.99 W/ INSURANCE (WITHIN US ONLY AND WILL NOTICE AHEAD IF SOME LOCATION WOULDN'T ABLE TO DELIVER ON TIME)
3). International shipping (Must call In, and additional charge will apply )
4). 7 days return policy apply on all items ( from the day received ).
5). 20% Restocking fee, shipping expenses apply to all functional returned products.
Modified by Xenon911 at 8:53 PM 7/29/2008
Modified by Xenon911 at 12:28 PM 10/3/2008
Modified by Xenon911 at 12:31 PM 10/3/2008
Modified by Xenon911 at 12:35 PM 10/3/2008
Q. Can't I just purchase a stronger watt halogen bulb to get a brighter light?
A. XENON H.I.D. lamps are 35 watts while traditional halogen bulbs are 55 watts. Even though XENON H.I.D. lamps draw less wattage and current, they produce 3 times more light than its counter part, halogen bulbs. Lower wattage does not mean less light output, Xenon are much more efficient, in another word, more power is being put in to more functional use, similar to a smaller liter engine are capabile of producting more power than bigger engine with more liter because it is more efficient. Increasing the wattage will make the bulb a little brighter however it will create excess heat and it will damage your housing and harness. Also, AMPS = WATT(55watts in most cases)/ BATTERY VOLTAGE OUTPUT (12V). So as you increase the wattage on your bulb you increase the current draw on your entire electrical system. This is critical in motorcycle applications.
Q. Can I Install the kit myself?
A. For anyone who is mechanically inclined, this installation is considered "do-it-yourself". While a typical installation takes approximately an hour and some application can even be installed in 20 min, it can vary depending on application (conversion or auxiliary). Our kits are ready to install right-out-of-the-box and come complete with everything that you will need. We also provide you a full set of easy-to-read, step-by-step instructions to guide you.
Q. What is the difference between genuine XENON HID lights and Xenon gas-filled bulbs?
A. High Intensity Discharge (H.I.D.) is a type of lighting technology that replaces the filament of the light bulb with Xenon gas. The gas is ignited to produce an arc of light, when high voltage is applied. The amount of light output is three times that of a standard halogen bulb. The lamps also glow at a higher light temperature (closer to natural sunlight) that gives it its distinct color and appearance, and on the other hand, the Xenon gas filled bulbs are still traditional filamented bulbs, however they replace the halogen gas with xenon gas so it appears whiter and last abit longer when its operating at higher wattege .
Q. Could I re-install the original halogen bulbs after the XENON H.I.D. kit has been installed?
A. With the growing popularity of leasing vehicles, a big concern is whether or not you can bring the vehicle back to its original factory condition. Our kits install with little or no modifications to your vehicle. If need be, the entire kit can be removed and the original halogen bulbs replaced. This kit can be re-installed into another vehicle that uses the same bulb size, therefore, the install is 100% reversable.
Q. What about the quality of your product?
A. The are extensive technology being put in to the making of these ballasts and bulbs, thanks to the effort of many Hella engineers for the ballast and Philips engineers. These kits are trusted by OEM dealer and they installed these kit in their car and seller it for thousands more, and now you can get the same quality kit at fraction of that price.
Q. Why cann't replace the halogen bulb in my vehicle with XENON HID lamps with out having to purchase the entire kit?
A. Motorcycles and automobiles currently use a 12 Volt electrical system for their headlamps. XENON HID lighting systems require over 20,000 volts to ignite the bulbs. Once lit, they only require 85 volts to keep running. Our kits include a power pack that is necessary for the lamps to turn on. The input of the power pack is 9-16 volts. It is an integral part of the system. You DO NOT require any additional components to install the xenon HID lamp into the original socket of the halogen bulb.
Q. What's the warrenty period for these HID kits?
A. The ballasts and bulbs come with 12 months warranty from all factory defects. If any component fails within warranty period, we will replace the defective component immediately. Contact us with a description of the problem and we will be happy to assist.
White 92 Civic CX (Kinda Stock) (NOT For Sale
White 02 Civic SI ( My daily driver ) EP3 Squad #44 (FOR SALE $5500) email pythoner@tds.net
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaMarketPlace.com content, comments, or advertising. HondaMarketPlace.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaMarketPlace.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
