Ideal for street and race applications, Skunk2 Rear Lower Control Arms for the EP3, DC5 and Honda Element replace your stock arms while retaining factory suspension geometry. Skunk2 Rear Lower Control Arms are designed in 3D CAD, using Finite Element Analysis (FEA), and are engineered to be stronger and 25% lighter than the stock piece. The LCAs are forged aircraft quality AL2024 billet aluminum and are CNC machined. Skunk2?s LCAs feature steel mounting plates to equally distribute the clamp loads for a more durable and secure connection and feature low deflection polyurethane bushings many competitor's LCAs are tightened directly to the aluminum and have a tendency to over stress the material and loosen over time). All Skunk2 Lower Control Arms for the EP3, DC5 and Element include new Skunk2 bolts and sockets required for installation. Skunk2 Lower Control Arms are available in JDM Gold, Clear and Hard Anodized Finishes.
MSRP: $238.07</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
Skunk2 Honda Fit Short Shifter Adapter
Skunk2?s innovative engineering has developed a cost effective short shifter solution that rivals all other competitors in performance per dollar. The skunk2 short shifter adapter for the Honda Fit is comprised of cadmium plated steel hardware and is designed to reduce shifting throw by 22%. This is achieved by adding a 17mm adapter to the bottom of the shifter and raising the shifter box to compensate. By maintaining the factory length on the upper portion of the shifter, no additional torque is required to shift between gears. *OEM assembly and skunk2 shift knob not included.
MSRP $59.85
Skunk2 PRO-C Coilovers feature the latest advanced shock technology and a carefully designed dampening curve for a shock that dramatically improves handling. The Skunk2 PRO-C Coilovers feature an adjustable mono-tube design with an oversized, micro-polished, hardened steel shaft and piston with a precision honed internal bore and low friction triple seal ? resulting in an extremely responsive and durable coilover. Each PRO-C kit features precise 12-way adjustable valving and one-piece forged shock body for added strength and reliability. Skunk2 PRO-C Coilovers feature shortened shock bodies and shafts to maintain proper suspension travel on lowered vehicles and are adjustable to allow height adjustments without affecting pre-load. Included with the Skunk2 PRO-C Coilovers are either CNC-Machined camber plates with spherical bearings or top mounts with polyurethane bushings (depending on application). With Skunk2 Coilovers, enthusiasts can quickly and precisely set adjustments to improve the vehicle?s handling, response, cornering, stability and balance.
MSRP: $1,423.10
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way.
Copyright/trademark/sales mark infringements are not intended or implied.
