#26 | |||||
90 CRX 12.0 @ 113 yea my kids are Proud! Pics of my car here! http://www.honda-tech.com/zerothread?id=971694 vid 12.1 pass. http://guelphracing.nstemp.com...X.wmv |
#27 |
awesome. lets see pictures of that sheet metal plug
#28 | |
#29 |
1995 Honda CivicJoin Date: Apr 2006
would it be reverse if iw anted to add a sun roof?
1990 civic hatch std-under the knife-stock si motor 5spd black si interior 1995 civic coupe ex- stock(hopefully not for long) 2005 dodge neon sxt-junk |
#30 | |
If the brackets are not in exactly the correct location, it will never close correctly!!!!! I'm pretty tricky, but I wouldn't try it!!! Wes Vann |
#31 |
yea i'm not but i had a body shop quote me a grand to chop both roofs and instal the si roof on my dx. i thought that was much. he also told me NOT to cut my si by myself. i think it jsut wants the extra time and money. i dunno
#32 |
[url] http://www.compositesfab.com/i...ID=71 [/URL
what about doing something like this?(dont burn me,im new to exterior mods) |
#33 | |
http://www.honda-tech.com/zerothread?id=1863781 |
#34 |
Nice Writeup dude
I was thinking about doing this mod...but I was also thinking about putting in the sunroof plug - and using a non-sunroof headliner?
#35 |
1999 Acura Integra |
that's crazy, nice diy to share with us.
i'm also doing the pillar seatbelts soon in my 90 rex quite soon
My vouch thread: http://www.honda-tech.com/zerothread?id=1774613 The Daily Driver: http://www.honda-tech.com/zerothread/2339681 |
#36 | |
#37 |
Lam: on your website you talk about the green outline. This is the section you had to cut away from the roof skin. Is it just the seam sealer that bonds that area to the roof? Or you talking about it's welded? I'm doing this on my sedan so this is basicly the same. last night i started preping my new roof. Also you said it could be possible to use rivits.
95 EG Civic (R.i.P T-Boned) 89 EF Sedan (Current Project) "keep a full interior and still be fast!!!! leave the stripped interiors to the real racecars!!!!" -sikefcrx89 "don't be a ricer! keep your bumper support kids, it might save your life." -dem0nk1d |
#38 |
I'd have reservations on saying that rivets would be a good method.
If it is possible to do, (I'll get into that) then you should count on using steel (or even stainless steel) rivets, not aluminum ones. You will have to have to have a strong arm to "pull" all the rivets, due to steel ones being a lot stronger. I'd question if the head of the rivet gun would fit in the groove that goes along the side of the car (covered by the rubber trim pice). You wouldn't want to put the rivets in facing upward as that would prevent the installation of the rubber trim piece. Do some research on "cleco's". These are clamps that are installed in holes drilled for rivets to hold the items together while drilling the other holes. You install the cleco's as you drill the holes, then remove them when installing the rivet. I think the addition of a slow setting structural adhesive between the panels should be used. Drill the holes while using cleco's, remove the panel, put down the adhesive, and then put in the steel rivets before the adhesive sets. Wes |
#39 |
My ???? is would it be easier to just remove the sun roof and make a cap, weld it is and make a support beam under it? I know I would have to use a little filler but.
I am just asking because I want to do something like this but not real able to take the whole roof off, well at least I never have. Maybe not confident enough. |
#40 |
The amount of working creating the roof "peak" (it's not a flat area) would make it more difficult!!!
The only thing about doing the roof skin swap that most people don't think about is the cost (and work) involved with removing and replacing the windshield and also all the interior parts that have to be removed. The actual removal and replacement of the metal isn't that hard (just time consuming for me). Wes |
#41 |
Nice write up, you made it look easy..
#42 | |
Has anyone removed all of the sunroof components and simply latched the panel on, making it removable? Or removed the motor and cables, etc and making it manual?
Both I think, are interesting options, more weight could be saved with a cf panel. -Chris
#43 | |
yeah i wish i done rivets or a similar method. like wes pointed out, the problem is getting the rivet gun into the tight hole under the trim. i was researching for a narrow head rivet gun in the market. but didnt come up with any luck. |
#44 |
1989 Honda CivicMy Garage Join Date: Sep 2004
pics are gone.
can someone reload? |
#45 | |
#46 | |
Want to Touge? oh, Japanese for what? I thought it was getting to 1st base? BAR certified B18C1 CRX Track Car 10/13/04 sold =( |
| Bookmarks |
| Tags |
| add, belt, conversion, crx, delet, delete, eliminate, honda, hondatech, light, pop, replacement, seat, sunroof, swap |
