> Acura RSX DC5 & Honda Civic EP3
Old 07-05-2007, 08:22 PM   #1
bocian
bocian's Avatar
Send a message via AIM to bocian
Default 02 RSX type S: seats were removed now SRS light is on, how do i reset it?
just as the topic says, i know about the paperclip trick however it says that it will not work if the srs was tripped from the seats being removed. anyone know a way that will get this done without going to the dealer?
thanks in advance!
bocian is offline Report Post   Reply With Quote
Old 07-05-2007, 08:24 PM   #2
bocian
bocian's Avatar
Default Re: 02 RSX type S: seats were removed now SRS light is on, how do i reset it? (bocian)
Old 07-05-2007, 09:13 PM   #3
JDMk20R
Send a message via AIM to JDMk20R
thanks in advance!
You can't reset it because the srs plugs are still unplugged. You'll just have to take out the bulb, put tape over it or just roll with it on.
JDMk20R is offline Report Post   Reply With Quote
Old 07-05-2007, 09:52 PM   #4
risktypeS
risktypeS's Avatar
Default Re: 02 RSX type S: seats were removed now SRS light is on, how do i reset it? (JDMk20R)
or put 2- 2 ohm resistor into the plugs and fool the srs by closing the loop.
here's how to reset it:
http://forums.clubrsx.com/show...reset
If you want your car to be cheap and fast it wont be reliable... If you want your car to be reliable and cheap it wont be fast... If you want your car to be fast and reliable it wont be cheap...
risktypeS is offline Report Post   Reply With Quote
Old 07-05-2007, 11:41 PM   #5
Aco512
Aco512's Avatar
lol, you are so wrong lol
but yeah, do the paper clip trick
i did it when i took out my passenger seat to run at the track last year
2006 Milano Red RSX Type-S
Aco512 is offline Report Post   Reply With Quote
Old 07-05-2007, 11:57 PM   #6
JDMk20R
Default Re: 02 RSX type S: seats were removed now SRS light is on, how do i reset it? (Aco512)
that's wack then lol, because it wouldn't reset when I had my Speeds and Sparco wheel. Wait, are we on the same page? Are we talking about putting them back in and then resetting? If so then yes it will work. But running an aftermarket setup it didn't.
Old 07-06-2007, 01:07 AM   #7
Aco512
Aco512's Avatar
ah, i gotcha
Old 07-06-2007, 04:13 AM   #8
bocian
bocian's Avatar
Default Re: (Aco512)
duh.... thats my fault, i should have clarified, they are back in and the light is on, from what i read, it seems as though the paper clip thing should work
Old 07-06-2007, 05:53 AM   #9
risktypeS
risktypeS's Avatar
It does work if you put 2-2ohm resistors into the srs plugs. It closes the loop for the srs and then you reset it.
Old 07-10-2007, 09:39 PM   #10
flipsyde
flipsyde's Avatar
i did the paperclip trick this past weekend and it worked for me. took me about 15 minutes though, you gotta time everything just right.
flipsyde is offline Report Post   Reply With Quote
Old 07-12-2007, 10:46 AM   #11
Davanca
Davanca's Avatar
Send a message via AIM to Davanca
Default Re: (flipsyde)
I don't understand why you guys need to do that. I've taken my seat out plenty of times at the track and when i put it back in the light always went away once the seat was back in. Try and make sure you have everything plugged in properly, and make sure you plug the srs clips in with the car turned off.
Na Guys Are Like The Marines, We Are The Few And The Proud.
Davanca is offline Report Post   Reply With Quote
Old 07-14-2007, 05:37 PM   #12
Todd00
Default Re: (Davanca)
Timing is the *key* to getting that trick to work correctly. Quoted from the other forum:
"When the light shuts off the first time, pull out the pin right away, you only have a couple of seconds to do it. When it comes back on again, right away put it back in. When it goes off again, pull it out right away, it should flash once, you're done."
I'll add this thread to the FAQ.
Todd00 is offline Report Post   Reply With Quote
Old 07-23-2007, 03:02 PM   #13
vrrodri
vrrodri's Avatar
I tried the paper clip 6 times but each time it flashes twice at the end and comes back on 2 seconds later and stays on....my SRS module is fine. I went through all the steps, everything worked until the last step.
ANY IDEAS
I have a EK hatch
vrrodri is offline Report Post   Reply With Quote
Old 07-23-2007, 06:06 PM   #14
Todd00
Default Re: (vrrodri)
ANY IDEAS
I have a EK hatch
An EK hatch might be/probably is a different procedure. Try asking in that forum.
Bookmarks
02, 2002, accord, acura, light, passenger, removed, reset, resistor, rsx, seat, seats, set, srs, type
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
