*Rosko's H23vtec build* N/A 12.0:1, Sk2 Pro2, Euro R, RDX Injectors, Alaniz ported, Camp1320 header
#626
Re: *Rosko's H23vtec build* N/A 12.0:1, Sk2 Pro2, Euro R, RDX Injectors, Alaniz porte
It's nice to see actual lift numbers for these different cams, thanks for posting your measurements. How do you lock the VTEC rocker to take measurements with the engine together and in the car? Do you use the air pressure method (messy in my experience), or have you come up with another trick? Good luck on the dyno!
#627
Ya, that's basically what I do too. It's kind of a pain to take half the head apart two or three times just to check something like lift or coil bind, especially with the engine in the car and having to mess with the timing belt, etc. I was hoping you had a trick!
Oh, and for comparison's sake I recently measured a set of JDM Type S cams with the VTEC pins locked: 0.430" exhaust and 0.468" intake, at the valve with 0.006" and 0.007" lash.
#628
I got everything buttoned up last night, just gonna look everything over tonight and maybe put on a few miles and get the oil changed. Dyno tomorrow!
#629
#630
#632
he made 240 according to a text he sent me. first track day is eddyville on the 8th.
#633
Yup, peak hp was 241. I overlayed the graph I had from a year and a half ago (pro2 cams, camp1320 header) and it was just about line for line except the pro3's and SSR header carried the power another 500 rpm. I expected more of a difference being that the design of the two headers are completely different, but suprisingly there wasnt much. I also did some open header pulls which were only good for a few ponies more, so at least I know my exhaust isnt too restrictive.
I tested my new manifold as well, for those who don't know its a dual throttle body setup (60mm each). The lower plenum has been machined out, then I built a billet plenum and billet twin bore throttle body to go on top. I plan to do some more testing on it with another plenum and a spacer or two. The manifold made huge torque gains down low, up to 20lb-ft in some places. I was pretty happy to say the least, but peak torque occured at 4600 so I want to do some more testing to raise that up a bit further in the power band since this is a drag motor. Peak hp also died off a little sooner at 8200, rather than 8500 with the Euro-R.
I got a few passes in at the track this weekend as well, with a little more testing 12's should be easy.
I'll have pics and graphs up later of everything, I've just been waay too busy to get on here.
#634
very nice cant wait to see the graphs and time slips
maybe i shouldnt dissmiss my camp1320 header after all
i was thinking about selling it...... but im still thinking
im going to do a comparassion of it against a hy-tech replica
nice job
nice job
#637
Heres the graph, this is my Euro-R with 70mm throttle body vs my modified stock manifold with a billet plenum and 60mm top mounted twin bore throttle body. Overall peak hp was roughly the same, but the dual tb setup killed the Euro-R in the low end. I plan to do more testing with this manifold to see if I can move some of that torque a bit further up. I will make a shorter plenum as well as a spacer and test and tune each one individually and compare the powerbands then go from there.
Euro-R = 240.5hp @8300, Peak torque 163.5 lb-ft @7500
Dual TB = 241.2hp @8200, Peak torque 172.1 lb-ft @4600
Heres a few shots of the new manifold...
#638
you are the effin man.
I think you need to shorten the runners on the stock manifold, cut about 1 inch off imo.
also maybe you need more plenum volume. either way the craftmanship is off the charts!
#639
moderator emeritus
damn that low end is nuts buddy! As always, nice stuff shawn. You said you got to make some runs at the track. You dont have to say the ET, but what was your trap? And what setup did you use at the track?
#640
Shawn, if you decide to sell the prototype, let me know. That power band should work fine for me.
#641
Nice stuff! I like the alternator bracket too, did you make that? What does the stock part of that manifold look like inside? Did you cut out most of the dividers between the short and long runners? It's neat to see threads like this one, thanks!
#642
Thanks,yeah we will see, I will add a spacer to the current plenum and see what giving it more volume does, I have a feeling the plenum doesnt really act like a plenum with this kind of setup though. The lower part has had the dividers machined out and the webs that are left have been machined a bit lower as well, making the runner shorter and giving the plenum more volume. Based on the calculations Matt, Blake and I did long ago this should have more volume over a stock manifold, but we will see what even more does. It all unbolts and seals with o-ring gaskets so it should be pretty easy and fast to switch out on the dyno.
#643
In the 1/8th mile it went 86mph, best et was 8.38. On my 13.03 1/4 mile run from a year and a half ago the 1/8th mile et was 8.35 and that was with a much better 60ft. I only got 4 runs in on saturday too, but going back tonight and looking for an 8.20 pass.
#644
I did cut out all the web of material between the front and rear port on each runner, and then I machined a concave surface (best way I can explain it) onto the tops of the dividing webs leftover, essentially lowering the plenum of the manifold and shortening the runner. I'll post a pic later when I'm at home, it will make alot more sense haha. But basically I took the time to measure and model all that up and cnc it out. Then I went back in by hand and blended things smooth. The runners of the manifold were pretty much untouched.
#645
Rosko, your work is just amazing. You make me jealous. :p Your work is always top notch.
#647
that is nice
I wonder also if later on after more testing if you would put this into production?
#648
moderator emeritus
dh-racing.com check them out specialist in h-series very strong build and alot of products just new top mount throttle intake mani somethang serious for the h-series fans bump and good luck with the setup....hope the cams dont bring you any problems when running it ....
#649
WOW nice work man
#650
nice way to advertise crappy parts in build thread.
how was eddyville last night? you get to the low 8s?
