*Rosko's H23vtec build* N/A 12.0:1, Sk2 Pro2, Euro R, RDX Injectors, Alaniz ported, Camp1320 header
Old 07-01-2007, 07:56 PM
Rosko's Avatar
Default *Rosko's H23vtec build* N/A 12.0:1, Sk2 Pro2, Euro R, RDX Injectors, Alaniz ported, Camp1320 header
Well I've been pokin around at this for quite some time waiting on this or that but now it looks like its all going to be coming together over the next few weeks. I'm looking to drop this into a hatch someday when I turbo the lude so I didn't want to get too crazy with it and keep it somewhat streetable. Right now the build will consist of...
IB sleeved block
88mm wiseco H22 pistons 12:1 in this setup
micropolished H23 crankshaft
IB H23 rods
Alaniz ported head
Skunk2 Pro2 camshafts
Skunk2 complete valvetrain
Euro-R intake mani
Acura RDX fuel injectors
Sk2 70mm throttle body
Camp1320 header
MSD DIS4 (distributorless)
AEM EMS and wideband
At this point the block is all assembled and waiting on the head to return which should be here tomorrow. The only problem I've ran into so far is with the block. Its been a bit of a pita but I had Import Builders sleeve the block back in the fall, and it had sat on my shelf until early spring. When I finally got around to measuring it up I discovered a problem with one of the cylinders being out-of-round. Two trips to the machine shop later I ended up with a cylinder a little bigger than I'd like to see, but its better than where it started. Pics of the block...
The bottom end consists of an H23 crankshaft, IB H23 rods and coated 88mm 11.5:1 Wiseco H22 pistons (which will yield 12:1 with the h23 crank/rods and thicker headgasket)
Pistons installed, you can see the pistons sticking out roughly .02" since they are H22 spec. After I get the head and cc the chambers I will be able to know which headgasket thickness to run. Right now its going to be somewhere near .06" thick to keep the compression under 12:1
Another bump in the road was getting the oil squirters installed properly. Normally I don't run the squirters since the stock H23 rods have the oil hole in them, but these aftermarket IB rods didn't. I wanted to use them since I have plans to keep this somewhat streetable. It literally took me about two hours, installing them and uninstalling them, getting them all bent and aimed properly without hitting anything.
Installed a new oil pump and water pump. For the balance shafts I just cnc'd up the blockoff plates and inside the block spun the bearings 180 degrees to block the oil holes. I can never justify spending money when I can make stuff myself
I'll post up more pics as the parts come in
Old 07-01-2007, 08:16 PM
Hawkze_2.3's Avatar
Default Re: *Rosko's H23vtec build* N/A 12.0:1, Sk2 Pro2, Euro R, RDX Injectors, Alaniz ported, Camp1320 hea
<-----Jealous
How is your ignition set up?
Old 07-01-2007, 08:54 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">&lt;-----Jealous
How is your ignition set up?</TD></TR></TABLE>
I use the AEM EMS so I have multiple coil output capability (3 channels on my particular box, but it can be modded by aem to 4). I use only two outputs (wastefire setup) feeding into a MSD DIS-4 ignition box (4inputs and 4 outputs, though I only use two) After that coils 1+4 are wired in series and so are 2+3 which are Honda CBR954 motorcycle coils. I still utilize the stock cam/crank pickups only they are mounted in a custom billet enclosure where the stock distributor would go.
"wastefire" simply means that any given cylinder fires every 360 degrees of crank rotation rather than every 720 like a distributored setup. The coils are wired in series so that when cyl 1 fires on the compression stroke, cylinder 4 is firing on the exhaust stroke and vise versa.
Old 07-01-2007, 08:59 PM
xxmastermindxx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">"wastefire" simply means that any given cylinder fires every 360 degrees of crank rotation rather than every 720 like a distributored setup. The coils are wired in series so that when cyl 1 fires on the compression stroke, cylinder 4 is firing on the exhaust stroke and vise versa. </TD></TR></TABLE>
is there any benefit/purpose to that?
Old 07-01-2007, 09:10 PM
Rosko's Avatar
As opposed to coil per cylinder? Not really, I would have liked to run CPC but at the time I didn't know AEM could add the additional driver. I can still control each coil individually, but a downside is that the coils are firing more than they need to so overheating could be a problem and maybe spark plug life? I doubt it though.
I think just about all cars today are ran distributorless. Alot are ran in wastefire too, like Chevy inparticular with their dual tower coils (3 on a V6)
Old 07-01-2007, 09:17 PM
ProjectBB6's Avatar
Nice... any certain horse power goal you are trying to reach with that setup?
Old 07-01-2007, 09:32 PM
P13_mein's Avatar
what a waste of a closed deck block...throw some boost!
setup looks great
but your headgasket is probably goin to be as thick as a sandwich
did you consider ITB's?
Old 07-02-2007, 05:04 AM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein &raquo;</TD></TR><TR><TD CLASS="quote">what a waste of a closed deck block...throw some boost!
setup looks great
did you consider ITB's?</TD></TR></TABLE>
I'm boostin the next build and its gonna take a waaay better set of sleeves than these
Someday I'll have my ITB's reworked and get them back on, but for now I just want a good solid tune with the Euro-R.
The headgasket will be about .06" thick, originally I planned to use E85 so I wanted the compression to be up there in the 13's, but its still pretty hard to find around here so I decided to just run it on 92 octane with a thicker gasket.
Old 07-02-2007, 05:20 AM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectBB6 &raquo;</TD></TR><TR><TD CLASS="quote">Nice... any certain horse power goal you are trying to reach with that setup?</TD></TR></TABLE>
Eventually I'd like 250, but its probably gonna take the ITB's and a different header to get there. If it gets around 225 as is I'll be happy.
Old 07-02-2007, 07:19 AM
Mykizism's Avatar
looking good shawn.. keep up the good work
Old 07-02-2007, 08:31 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">originally I planned to use E85 </TD></TR></TABLE>
You're in iowa and can't get e85? Wow, I figured if you could get it anywhere that would be the place.
Anyway, looks good so far. Good luck and keep us posted!
Old 07-02-2007, 08:57 AM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">
Anyway, looks good so far. Good luck and keep us posted!</TD></TR></TABLE>
Yeah no doubt, there are a few stations that sell it but they are all out of my way and about a half hour drive to get to.
Old 07-02-2007, 09:35 AM
Missing Gears's Avatar
glad to see you scuffed up the pistons by hand rather than just throwing them in out of the box
you shouldnt have any problem seeing 225. i think you may be suprised w/ the potential outcome. looks great, keep up the good work.
Old 07-02-2007, 01:46 PM
mgags7's Avatar
I agree...I think the numbers will be good and high, that thing should make great torque.
Do you have any flow numbers on the head?
Is the IM gonna be able to keep up with flow with the head you think?
Looks great
Old 07-02-2007, 05:47 PM
Rosko's Avatar
Default Re: (mgags7)
got the head and header today
I thought that I would be getting flow sheets but I didn't see any in the box. I'll just assume it flows alot
The Euro-R may be a bottleneck, but I'd rather try it and find out rather than assume its not. If nothing else i'll start reworking my ITB's and see what they do. Theres a new dyno shop in town and I'll be doing the tuning there. When it comes time for the ITB's I'll do some back to back runs and see what happens.
Modified by Rosko at 1:32 AM 7/16/2007
Old 07-02-2007, 05:52 PM
ECX
* B A N N E D *
ECX's Avatar
Looks like a great setup thus far, keep us posted!!!
Old 07-02-2007, 06:14 PM
Default Re: (ECX)
hey rosko, you may want to consider champhering the edges of the combustion chambers slightly. when i was running that identical bottom end setup my pistons were out of the hole about the same and i had a problem w/ the pistons actually hitting the edge of the chambers. the pistons were just barely kissing the head. i would have never known except after each pass at the track it would idle slightly off and i was finding aluminum flakes while checking the plugs. eventually the ringlands gave way and then i was finding oil on top of the pistons. suprisingly the motor still ran strong even w/ broken ringlands on all 4 pistons. although i cant remember exactly what thickness gasket i was running, i think it may have been a .050 cometic. after that experience i opted for h22 rods w/ custom pistons
if they were stock 87mm bore it never would have happened because the pistons obviously would have had clearence to fit into the chamber a bit if needed. i thought i had plenty of clearence but the pistons expanded more than i had planned for. just something to consider and maybee check over a few times during assembly
Old 07-02-2007, 07:07 PM
Rosko's Avatar
Default Re: (Missing Gears)
^^ good advice I'll be sure to check that out. I thought about just machining the counterbore to match the bore, any thoughts on that?
I don't think it will be an issue with the .06" gasket I ordered but if I ever go to a thinner one and run E85 I'm sure it will be an issue.
Old 07-02-2007, 07:12 PM
moderator emeritus
98vtec's Avatar
Default Re: (Rosko)
good luck shawn, maybe i will finish mine after i fix my mishap
Old 07-03-2007, 10:21 AM
chitownrida's Avatar
sick buildup
cant wait for results
Old 07-03-2007, 10:54 AM
flyrod's Avatar
Default Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">^^ good advice I'll be sure to check that out. I thought about just machining the counterbore to match the bore, any thoughts on that?</TD></TR></TABLE>
Pirate cut his chambers to handle pistons sticking out of the deck, and Six Sigma Racing cut the pistons down. A thick gasket should achieve the same thing; I would just measure the clearance and decide what to do from there. You could set the head on the block without a gasket, turn the crank slowly and let the pistons lift the head off the block. Measure the gap and that is how thick your gasket has to be for zero clearance. You can also experiment with bits of shim stock and feeler gauges to situate the head nice and level with the pistons just touching, then go from there. If you do cut the head, note that the piston crown and gasket bore is significantly smaller than the cylinder bore (at least on the oem parts).
Old 07-03-2007, 11:21 AM
Rosko's Avatar
Default Re: (flyrod)
Yeah thats what I was thinkin, but I don't want to create any sharp edges there either. On the last head that I did myself, I designed the chamber in Solidworks so that the sides of the chamber matched perfectly with the bore. That head unfortunately got destroyed though.
Old 07-03-2007, 11:26 AM
Rosko's Avatar
Default Re: (Rosko)
Heres the pics of my Alaniz head that came yesterday
And heres one of the Camp1320 header...
Old 07-03-2007, 11:30 AM
moderator emeritus
98vtec's Avatar
Default Re: (Rosko)
is that alaniz head the one i sold you?
Rosko's Avatar
Default Re: (Rosko)
Tomorrow I'll assemble the head onto the block with the thinner gasket that I already have and see how things look. I'm anxious to play with my degree wheel kit!
The new cometic gasket should be here mid next week hopefully.
Quick Reply: *Rosko's H23vtec build* N/A 12.0:1, Sk2 Pro2, Euro R, RDX Injectors, Alaniz ported, Camp1320 header
