#51 | |||||
#52 |
i took the amber off and masked it. it keeps the paint from bleeding past the amber. I used a black krylon paint. takes bout 20 mins to dry
#53 |
oh cool i already have krylon fusion lying around... i thought it was only for plastic though. I'm guessing you had to sand paper the area down pretty well??
And also did you paint any area under the amber once you removed it>? thanks |
#54 |
I scuffed the area pretty well, with 600 grit. Did 3 coats until the paint smoothed out. And yes I painted the line that separates the blinker and the top surface of the reflecter. Take your time masking, I spent a few hours until i got it right where i wanted it to be.
#55 |
for those of who removed the amber, did you also remove the white reflector as well?
Will people still be able to see my signals without the amber I'm doing mine exactly like thinknology |
#56 |
I kept the clear reflector in there cause I like the chrome on the black...but if your taking out the amber peice then you will need a new bulb thats the amber color or else you just have a bulb under there and it doesn't have a color to it and may get you a ticket.
Here is what mine looked like after I got done.
#57 |
okay so i'm done!! wow that took me from noon Saturday all the way until noon sunday. I was extra careful but i had the most difficult time putting the screws back onto my bumper because all the screws were all different (previous owner fault?) other than that, it wasn't too bad when it comes to removing the bumper.
I think i am very happy with the results... and my turn signal bulb actually lights up yellow so no need for the amber! Modified by kcari at 3:27 PM 10/21/2007 |
#58 |
so what are the statistics for the 04 05 civic headlights? i might try doing this this coming weekend...
#59 |
![]() ![]() I kind of miss the amber... Oh yeah, btw did you get rid of all the black tar and applied your own silicone? or did you just reheat the tar up and pressed? Modified by kcari at 8:30 AM 10/23/2007 Modified by kcari at 7:31 AM 10/26/2007 |
#60 |
feeling the blackhouse
#61 |
Hello. I'm new here. I did mine 3 months ago and removed the gum with hairdryer.
I did great on my left headlight. ![]() ![]() It didn't have any amber so i got candy orange paint to make it amber. But I have this nasty problem. I screwed up my right headlight lens. It has gotten dirty and all moist. I'm gonna open it this weekend and clean out the moisture and seal it up properly. ![]() ![]() Did any of you guys have this problem? I tried heating the mess up thinking it was just glue/gum but it didn't come off. It feels rough. its on the exposed side of the lens. I can really use a good advice. |
#62 |
did you get all the black tar gunk out before you resiliconed or did you just heat that gunk up and pressed the lense back in?
#63 |
well at least you have to add new silicone on there.. and my old set did this.. but with GA's crappy heat, i need to buy a new set here soon rather than used one's to keep in healthy shape. i wish ours were made of glass
I ♥ My Nikon Nikon D80 18-55 / 55-200 VR / SB600 --D T A-- |
#64 |
2004 Honda Civic |
bz-kurb, if I were you I'd also look into wetsanding and buffing the topmost portion of your right headlight before that oxidization becomes irreversible.
#65 |
yeah i need to add silicone coz i still need to open the Headlight to remove the moisture. But the moisture is not my concern coz its easy to wipe off. I'm more concerned on the stains on my lens. I just bought 3 pcs. of 2000 grit sandpaper to wetsand it and a can of rubbing compound but the one i bought says its waterproof. Is it safe to wetsand using a waterproof sandpaper? I really need to clean the lens. Its really blurry when the headlight is turned on....
#66 |
@kcari
I just reheated the tar/gum. Its not tar on my headlight coz here in the Philippine domestic market they use gray gumlike goo... I'll get some silicone this weekend to properly seal off that lens so that it won't leave any nasty moisture... |
#67 |
2004 Honda Civic |
To be honest, that entire headlamp could use it, but do whatever you're comfortable with. Fix the topmost section first (which is the worst), and if you're comfortable, try the entire headlight.
If you can't properly buff and this is your first time with a buffer, THIS IS PROBABLY NOT FOR YOU. IMO you need to at least have your buffing skills down before you attempt wet sanding. What you'll need 1. Your sandpaper (1500+ is ideal, the finer the better. I personally wouldn't go harsher than 1500. If the sand paper is black on the back (not beige or orange), then that is what you want. 2. Car wash soap. 3. Water. 4. A car wash mit 4. A bucket to hold it all. 5. Buffing compound (at least a medium cut) 6. Foam buffing pad (at least medium cut) 7. Rotary buffer. 8. Couple microfibers. 9. Couple terricloth towels. Let the wet sand paper soak in the bucket of car wash before hand for a couple minutes. Fold the paper until it is about as wide and as long as your first three fingers. Most wet sand paper comes in 9" x 11" Sleeves. 1.Wash, rinse, then wash the headlight again. Keep it as wet and soapy as possible. 2. Using the wet sand paper, apply even pressure, even strokes. Don't use a block because you're on a semi curved surface, use your fingers. You can sand parallel to the hood (sanding lengthwise) which is probably ideal, but if you're more comfortable going the height, that's up to you. 3. Check your progress often and be patient. Grab a dry terricloth towel and see how much oxidization is left. Use your better judgement. You only have several millimeters of clear to play with. If the sand paper starts to "squeak", shift the paper and use a fresh section. 4. When you're satisfied and the headlight surface is dry, buff the headlight out. I say use a medium cut at the very least, but if you're pickier you can use a variety of finishing pads with soft foam and soft finishing polishes. 5. After you've buffed the surface (and all the fine "scratch" hazing is gone, check in a variety of lighting conditions if possible), wash the surface again and dry. 6. At the very least it's a good idea to apply wax. Waxing the headlamps often makes them hold up remarkably better in the long run. If you're picky, a good glaze would be a good idea before you wax. |
#68 |
thanks for the quick reply. Its really good to have a guide on how to do this. I have no experience with buffing but I have a buddy who knows and will be glad to help out. We'll try to fix it during the weekend. I'll post some pix after we're done.
#69 |
hey kcari, off topic, but where ever did u get that red h, and still have it fit ur grille, me wants
cacapoopoopeepeeshire |
#70 |
I don't remember if its from an ep3 or a type r integra. The fitment is not 100% but its close to 95% or so, just have to play around with it and glue it. I just brought my original emblems into a local jdm ricer store and they found the closes match. I don't remember if i had to cut the pins or not in the front, but deffinitely had to in the rear. They weren't cheap either and suffered through weeks of fear that someone might jack me.
#71 |
HEY DOES anyone think its a tad ridiculous that for almost every front end mod you have to take off the whole darn bumper off. im telling ya. i just replaced my grill with the ctr grill and was totally caught off gaurd by all the damn work needing to be done lol. oh well at least the bumper is easy to take off, just takes awhile
13D Lead the Way! 2003 k20'd Ex Coupe PSN G3T-SH3LL3D |
#72 |
yes... i hate it too.. especially putting the bumper back on. it doesn't exactly snap in place without force from both sides. Always need a friend...
#73 |
Bumper is pretty easy usually only takes about 10 min and its on the ground given that you have done it before and know what direction to head in.
#74 |
i blacked mine out this weekend. the oven works great to get teh silicone to release.
i'd have pix except both my digital cameras got stollen so i no more pictures
#75 |
Congrats on the lights soory bout the digi cams though
. the oven thing works great you just have to keep on eye on them. Did mine few months ago. love it
SHOWSTOPPERS USA http://images.honda-tech.com/set1/smile/emthup.gif 915 REP http://images.honda-tech.com/set1/smile/emthup.gif 4D00R FR3SHH |
| Bookmarks |
| Tags |
| 2009, accord, black, blacking, blackout, blinkers, civic, covers, diy, front, headlight, headlights, honda, lenses, rsx, smoke |
