Disconnecting shift linkage
I was trying to figure out how to disconnect the shift linkage from the tranny of my 1995 ls, but I couldn't manage to figure it out.
There is a single shaft going directly into the tranny that is covered by a boot.
The shaft has a hole through it, but no other markings.
Any help is much appreciated!
take center console out. unbolt the 2 bottom bolts where shifter is. then take some sort of screw driver big enough and hammer the pin out thats connected to the tranny. and don't be a ***** you have to hammer it real hard.
Re: (1.8L_allmotormilitia)
Step 8:
To remove the shifter linkage, pull off the snap ring that covers the lock pin with a pair of pliers or a screwdriver, then with the correctly sized punch, hammer out the lock pin from underneath. Don't lose it!
Taken from http://www.c-speedracing.com/h...p.php
Re: (Blueblotch)
If you have a spare A/C compressor bolt, they work GREAT to hammer out the pin. the long *** 12mm headed bolts with a small taper. Long so you wont hurt your hand (thats what she said?). That's if you dont have a punch.
Re: (InLtegSra94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InLtegSra94 »</TD></TR><TR><TD CLASS="quote">You don't have to take out your center console...that's so much extra work...</TD></TR></TABLE>
yeah i wasnt sure what that was all about
Re: (My_EFsedan)
I still havent gotten mine out yet, I am at a loss. I couldnt fine a 8mm punch at the auto store so I tried a smaller one. Guess i am going to hunt down the exact one.
Anyone have useful tips on this?
Re: Disconnecting shift linkage (anahaevia8)
the part you are having trouble with is obviously the pin holding the linkage to the tranny shaft...take one of your A/C bracket bolts out and hammer the pin out from the bottom of the car. I only had to hit it about 3 times and it slipped right out...good luck...
preludedriva
16
08-08-2007 03:48 PM
99, civic, disconnect, disconnecting, integra, linkage, ls, pin, punch, remove, series, shift, tranny, trans, transmission
