#1 | ||||||
Team 3Flex racing vouch thread http://honda-tech.com/zerothread/2148656 Justin C. Samson ||| Myspace ||| AIM - onetwo FRESH |||MENSalmanac.com @ jj. |
#2 |
man i wish the k20 oil filter was where the r18 is
the jdmslug 1990 crx si b16-t |
#3 | |
FG*Squad #208 turbo Si + S2k + 350z |
#4 |
can't you make a lil tube so when it shoots out you can raging waters that shit to where you need it to end up at? oh btw, if you guys see any typos lemme know. i have a tendency to do that.
#5 |
Great post! There is one thing that I learned changing the oil on my wife's '06 Pilot that may apply here. To avoid having to unscrew the drain bolt by hand the last few turns, and getting hot oil all over my hands, I use a 6" extension with the 17 mm socket (minus the ratchet) to remove the the drain bolt.
I have considered adding a drain spout and valve to replace the drain bolt, but am concerned that it may break off or vibrate loose. It would make adjusting the oil level easier if too much oil is added by mistake. It would also make sampling and changing the oil a little easier as well. |
#6 |
excellent write up!!!!!!
#7 |
great write up
i always spray brakelean around the oil pan bolt and oil filter once they are back on so there is no smell of burning oil if you miss any while wiping the area clean. isnt the r18 4qrts of oil?!. could be wrong...i forgot how much i put in. i think thats what the manual says
injen - jlb motorsports - options auto - frank's fab shop current: '00 ap1 & '98 ej8 ---- '07 fg1 = totaled ---- '94 accord = sold |
#8 | ||
thanks guys!
#9 |
You forgot to say to start your car up and get it up to normal temp, then drain it.
#10 |
lol i had to use the oil filter wrench
#11 | |
it doesnt have to be normal temp, but just warm. if you get it to normal temp, the drain bolt will be to hot to remove. the socket will stick to it and it will strip. and if its normal temp you will have a chance of burning yourself.
#12 | |
good write up my man.
definately have an oil filter wrench if honda has changed your oil prior to a DIY attempt (its on there pretty tight). Quote:
#13 | |
i just wanted to make sure that shit was on there.
#14 |
Whats up with the lumpy assy, cheapy, looking oil pan?? LOL. What honda couldn't put it into a press so that it has a nice shape too it, looks like they took a piece of metel welded or pressed a mounting plate on it to bolt it on and left it as is. lol
#15 |
some suggestions:
-being the oil filter is in an easy spot to access (LUCKYYYYY!), you can use the socket tool. it also looks like you can use the ole' huge screwdriver in the filter method where you hammer a screwdriver into the housing and then turn it for leverage. if that doesn't work and all it does is start to tear the thin metal filter housing, it was put on too tightly. my nissan was too hard to use a filter socket to get them off, no clearance, but I use K&N filters which have a convenient 1 inch "nut" cast into the filter housing to allow a socket to turn it off. works great. if only other filter makers did this. and frams have a nice grip end, too bad theyre about the worst filter to use (i hear they flow good, but thats because they dont filter for shit). and another tip. open one of the bottles of new oil, dip your finger in it (just the tip ), and give the seal on the new filter a rim job. helps it seal better, shouldnt run it on there dry.but good writeup.
'97 Nissan 240sx - KA Turbo '08 Mazdaspeed 3 GT |
#16 | ||
the autozone i went to didnt have a fram filter that was for the civic. at least according to the worker there. n yea i did notice the grip. ill do the finger oil dripping next time, thanks!
#17 |
ok.... on your 8th point:
mine's an EX 2006...and doesnt have the oil life meter...how could it be? ive tried and posted a video on another thread, but no luck? is there some kind of ecu stuff? oooooHHHHHH and btw...my dad also has an EX2006, and guess what? theres no oil life meter.....so.... whats the deal?????????????????????
5 legged |
#18 |
so you've pressed sel/reset and theres nothing that says oil life meter?!
dealership time y0
#19 |
awesome thread
06 AMB FG1 LX 5MT |
#20 |
dont know if anyone pointed this out, but may i also add, let your car run for 5-7 minutes or so to get the oil flowing to ensure an accurate read from the dipstick to see a more accurate reading :D
Black 07 Honda Civic EX Coupe -nothing done. yet |
#21 |
yeah, ive done it on both my car and my dad's....
theres no oil life meter in either..... it goes from total odometer to trip A with exterior temp, and trip B with exterior temp, then back to total odometer.... are ther some option or procedure to turn it on? like fiping the key from I to II or something?
5 legged |
#22 | |
#23 |
im in mexico.....
any other ideas on the oil life meter?
5 legged |
#24 |
sticky?
#25 |
you screwed up by putting too much oil in the engine. the car only use 3.9 quarts max with an empty oil filter. putting 4.5 quarts in there is not "incase" shit happen, but you're actually destroying your car.
ever wonder why some older cars leak oil everywhere under the hood? you're going to destroy your front and rear main seal. too much oil very bad for the engine.
http://www.nonewbs.com |
| Bookmarks |
| Tags |
| 2004, 92, change, changing, civic, diy, filter, honda, main, odyssey, oil, pan, quart, r18, rear, seal |
