> Hybrid
Old 06-08-2007, 01:57 PM   #1
Bense
Moderator
Bense's Avatar
Send a message via ICQ to Bense Send a message via AIM to Bense Send a message via MSN to Bense Send a message via Yahoo to Bense Send a message via Skype™ to Bense
Default Drain plug relocation nut (oil pan h2b h2d f2d f2b)
To those guys that are doing swaps that the lowest point of their oil pan is no longer in stock location, I found these nuts from honda that will assist you in your needs.
Yes, you can use any normal M14-1.5 nut, but they are a little harder to come by and they won't have a flange on it like these:
Part numbers are in the pictures:
#1 90213-S5A-003, sells for $0.50 off of hondapartsdeals.com
#2, 90213-S3Y-000, sells for $1.53 off of hondapartsdeals.com
#3, 90382-SJK-000, sells for $1.94 off of hondapartsdeals.com
From left to right, #1, #2, #3
If you don't know what this is for, you don't need it.
I'd reccomend #2 IMHO.
Bense is offline Report Post   Reply With Quote
Old 06-08-2007, 02:20 PM   #2
88ED8
88ED8's Avatar
Send a message via AIM to 88ED8 Send a message via MSN to 88ED8
Default Re: Drain plug relocation nut (Bense)
and what plug/"drain" bolt would one use?
AEM Fuel Pressure Regulator for sale!!! $85 shipped http://hondamarketplace.com/showthread.php?t=2684333
88ED8 is offline Report Post   Reply With Quote
Old 06-08-2007, 02:30 PM   #3
Bense
Moderator
Bense's Avatar
Default Re: Drain plug relocation nut (88ED8)
Stock. That's why I found these M14-1.5 nuts
Old 06-08-2007, 08:54 PM   #4
redzcstandardhatch
redzcstandardhatch's Avatar
Send a message via AIM to redzcstandardhatch
same nut i just used on mine! where was this 3 days ago! haha
you rock my socks bense
custom EF traction bar and a cheap K24 for sale too! PM!
WTB: useable h22 of h23 block/girdle..no crank needed
redzcstandardhatch is offline Report Post   Reply With Quote
Old 06-08-2007, 09:23 PM   #5
sauceja
sauceja's Avatar
Default Re: (redzcstandardhatch)
What bit did you use to redrill hole and how did you weld it on? tig, wire?
Did you have to strip the black paint to get to clean metal??
Did you locate on inside of pan or outside? Outside seems more realistic for oil drainage but the inside of oem pans don't allow for complete oil draining which sucks.
Those are my questions.
In for pics of completed project pan.
My Build
FS: honda Service Manuals and ETM
Leaving the game for a bit! I will return stronger!!
sauceja is offline Report Post   Reply With Quote
Old 06-08-2007, 09:59 PM   #6
Bense
Moderator
Bense's Avatar
Default Re: (sauceja)
I dunno, 9/16" or something. It doesn't really matter if you use the stock plug + this nut. Weld it on the outside. Just don't put it on the bottom like me, i slammed it into the ground and ruined my pan so i had to buy a new F23 one for my F20B.
I will have to pull this pan off to drain all the oil for now. But i'm gonna get another one and keep this one as a spare in the back of my hatch, my pan sits that low.
Old 06-09-2007, 10:11 PM   #7
sauceja
sauceja's Avatar
Default Re: (Bense)
Sorry but I LOL'd
I saw the picture in the H2B thread of your pan and WOW. Kinda low.
So just drill hole and weld nut on front side of pan about 1/16 inch above the scrape line and your good but don't hit a curb,bump,pothole or your Fukked.
Or fabricate a skidplate and modify it to act as a jdm radiator flow plate to force air over your radiator and exhaust manifold to keep the coolness flowing.
Projects coming along great Bense. Now if only I could get my expensivemans R finished.
My Build
Old 06-10-2007, 05:48 AM   #8
Bense
Moderator
Bense's Avatar
thanks bro
And I just added prices above the pics
#1, 90213-S5A-003, sells for $0.50 off of hondapartsdeals.com
Old 06-11-2007, 05:21 AM   #9
2point2
2point2's Avatar
Default Re: (Bense)
Good post. This also applied to many "H2H" EFs.
I'm currently using a power steering pumped rigged to a drill with a tube shoved into to low part of the oil pan. sucks the oil out.
Turbocharged CRX w/Stock H22
10.73 @ 137mph
Pics and Info
2point2 is offline Report Post   Reply With Quote
Old 06-11-2007, 10:41 AM   #10
HeikDiesel
HeikDiesel's Avatar
Send a message via AIM to HeikDiesel
Default Re: (Bense)
Hey so I need a f23 pan gasket for my f20b. What year and model of USDM accord came with those?
Originally Posted by CRXREFIC
wrong its DOHC B16 lol if you watch the video down the page.... you can see the inside the rice box.... oh yea i think they fuk up the turbo setup because the turbo gauge its going negative pounds
HeikDiesel is offline Report Post   Reply With Quote
Old 06-11-2007, 11:18 AM   #11
Bense
Moderator
Bense's Avatar
Default Re: (HeikDiesel)
98-02 had the f23. If you have the steel pan it doesn't use any gasket it at all, It just uses honda bond all the way around
Old 06-11-2007, 11:26 AM   #12
HeikDiesel
HeikDiesel's Avatar
Default Re: (Bense)
Im pretty sure it was alum but all it had was honda bond so I guess I better go give it the magnet check
Old 06-16-2007, 12:34 PM   #13
RCautoworks
Send a message via AIM to RCautoworks
Good post , thanks Bense
RCautoworks is offline Report Post   Reply With Quote
Old 06-19-2007, 03:38 PM   #14
9WON4
9WON4's Avatar
Default Re: (RCautoworks)
91 CRX "The Recesion Special"
A little knowledge is more dangerous than NO knowledge. A little knowledge will make u "think" you know something.
9WON4 is offline Report Post   Reply With Quote
Bookmarks
bense, civic, custom, drain, f2d, h2b, honda, m14, nut, oil, pan, plug, relocate, relocation, relocator, weld
